£400 to change glow...
[Closed] £400 to change glowplugs on my camper - reasonable?
 Ewan
Hi all,
I've been quoted £400 to change the glow plugs (four of them) plus the relay on a renault trafic. Seems a bit high for a two spanner haynes job.
Is this reasonable? If not anyone care to recommend a garage that does vans near woking?
Thanks!
Posted : 09/07/2017 8:33 am
2 spanners you say?
Diy?
Posted : 09/07/2017 8:37 am
Access to the top of the engine is pretty difficult in Renault Traffics, so simple jobs can become very time consuming. Some models had problems with water sitting on the top of the engine and the resulting corrosion making plug and injector removal even more difficult.
Posted : 09/07/2017 8:51 am
I've just had a look in the Haynes manual for my Vivaro and it seems more faff removing stuff to get to the Glow Plugs than actually taking them out.
Quick look on Euro Car Parts and the parts are about £100 all in.
Like Maccruiskeen said, they are vulnerable to water ingress so perhaps they have quoted in case they hit problems ?
Posted : 09/07/2017 9:05 am
Shop around for a couple more quotes locally and see if you get any wild variation. I'd say - given the issues that can arise - you'd want to be clear whether the price 'quoted' is a fixed price for the work and you're not writing them a blank check to cover them snapping a plug in the head (or crack the head itself) and spending their way out of trouble. I've known traffic owners have bills in the 000's for injector work.
Posted : 09/07/2017 9:13 am
Get some other quotes then?!
I'd say that's a fairly standard price for the trafic/vivaro vans. They can be hugely stubben to remove.
Posted : 09/07/2017 9:25 am
 Ewan
Ah ok - I knew the injectors can be a pain in the arse but I thought the glow plugs were ok. Would do it DIY, but to be honest i've not got a free weekend between now and when we go away in the van.
I'll try and get some more quotes - was hoping for some recommendations around woking way (+- cyclable distance).
Posted : 09/07/2017 10:16 am
Notorious for tips swelling and ending up shearing off as they are undone on the cylinder crown as well as the water ingress issue
It's a 2 spanner job if all goes well but these engines esp if aging seldom go well. Saw a vivaro hanging by an unclamped injector from a forklift last time I was in at my local garage. .......
Posted : 09/07/2017 10:33 am
 poly
Ewan - surely if the job takes a weekend, or even a day 400 is reasonable price - it's only a rip off if you could do in an evening.
Posted : 09/07/2017 10:34 am
The entire weight of the van ? 😯
I got my Vivaro from a local specialist who has a tool that removes the injectors under pressure with a stupid amount of PSI behind it. It confused me as to how it works, but it was connected to air line then a massive compressor
Posted : 09/07/2017 12:35 pm
The only 2 questions with glows are, how hard are they to get to, and how likely are the little bastards to be stuck or snap. My engine was apparently designed by someone who'd also spannered on scabby diesels so it has big burly snap-free injectors and glow plugs that you can get real tools to easily and that thread in and out, great success. Not everyone's so lucky
Posted : 09/07/2017 3:11 pm
The last Glow plugs that I changed at home needed a deep 8mm socket. 1 had a swollen tip and snapped off. I took a chance and managed to drill most of the tip out until it dropped into the combustion chamber 😯
Made quite a noise until the bits got burnt up and spat out of the exhaust.
Luckily no Injector or Exhaust valve damage.
As for my Vivaro, £1500 for 4 Injectors at trade price.
Posted : 09/07/2017 8:20 pm
 Ewan
Well I got two other quotes - one for 386 and the other for 394, so 400 seems fair enough. Both garages caveated their quote with "if it's straightforward..."
Posted : 10/07/2017 2:06 pm
I paid £130 to change 1 on my Astra at a Vaxhall dealer. That included the £50 charge for the diagnostics which told them it was an issue with the plug.
Posted : 10/07/2017 2:21 pm
the joys of vivaros.
i must admit i felt a big sigh of relief when my ivecos F1A injectors came out without any dificulty .
apparently much like brakes many people use copperslip when fitting the things - this is entirely the wrong thing and when coupled with heat they get stuck - as well as if they have not got a good seal and have blow by - the gunge causes them to get stuck IE merc vitos and sprinters.
As for injectors - a good local specialist can be a godsed. i found airylea diesels to be really helpful when i had issues with the iveco - ran perfect but i was getting diesel in the sump and following some simple tests they give me i narrowed it down to a duff injector - and while i was there i stripped them down and gave them an ultrasonic bath. a single replacement cost 160 quid
Now she runs like a bought one.
Posted : 10/07/2017 3:48 pm
Local garage attempted to change the glow plugs on my 2010 Trafic.
They were seized solid and going nowhere. Options were to smash the head or get a new engine, so I took it up to a Traffic/Vivaro who specialist managed to remove them with a special compressor based tool along with the injectors.
The whole job hit me with a £2k service bill.
Posted : 10/07/2017 4:10 pm
 Ewan
This is all sounds depressing! I knew the injectors were a ballache but didn't realise the glow plugs were. As far as I'm aware (and I have the full service history) they've never been changed so shouldn't have copper slip on them (the haynes manual does suggest using copper slip tho!).
I asked whether 400 quid was reasonable on various facebook Trafic groups and various people suggested I was getting my pants pulled down. Given that the other quotes came in the same, I guess i'll go with the garage i used for the service (who diagnosed the glow plug service).
I do have the option to not doing it for some time - i've noticed for the past year that it can be hard to start the van (turns over quite a few times before catching) when it's cold. I only worked out it was the glow plugs when i plugged in one of those OBD bluetooth adaptors off ebay which reported the glow plug error code. The garage then confirmed it.
I'm taking it to france at the end of the month, so i'm of two minds to try and get it fixed before or after? Fairly good chance of having to start it in reasonably cold places (maybe 10 degrees C) as we'll be up mountains.
Hmmmmm.
gringojimi - who was the specialist?
Posted : 10/07/2017 4:42 pm
If the quotes are dependent on it being a straightforward job then I'd ask to just pay for the labour involved when it's done rather than a flat price which may well go up anyway.
I've never seen four plugs fail at the same time along with the relay. I would rather test each plug, the relay and the wiring loom individually before changing the whole set.
I'm not criticising the garage, I just don't know how they confirmed your findings.
Posted : 10/07/2017 5:14 pm
 Ewan
I think they are operating on the principle, if you're doing one, you may as well do the lot. Certainly that is what they told me with the relay - they tend to go, so you may as well do it at the same time.
Is it easy to test the glow plugs?
Posted : 10/07/2017 5:42 pm
Wait, have you decided that it needs 4 glow plugs based on just the code the reader shows?
You're in Edinburgh? Not got Rentec to look at it?
Don't shell out anything until you actually know what the fault is- I don't think you've said yet? I'm a bit worried reading the above that you've got advice from the Renault/TVP forums out there, bought a code reader, and are going for the fix yourself. From my own experience, with some notable exceptions, those forums are populated by diddies.
My Trafic shows a code for a duff glowplug (2010) and there is an occasional bit of white smoke on startup in cooler weather- but not now. Been there since I bought it 2 years ago.
Posted : 10/07/2017 6:19 pm
I can understand their approach, I like to do the same when working on my cars. But having sheared a glow plug before and otherwise generally struggled with them I would be wary if changing them for the sake of it.
Live testing with a DC clamp ammeter on the individual wire to each plug to see what power it's drawing is an option.
Otherwise a simple resistance test from the positive contact of the plug to earth with a multimeter is the way to begin. Make sure the glow plug being tested is isolated from the loom so that you're definitely testing just the plug. Open circuit is obviously a failure, what the normal resistance is for your ones I don't know tbh. But as it's virtually inconceivable that all have failed a bad one will stick out.
If they all appear to be good then test for continuity from their contacts on the loom back to the relay socket. Once you know the loom is good the relay can be tested by checking for voltage at the plugs when they're switched on.
This is all very generalised advice. The garage undoubtedly have more experience with Renault Trafics than I do but that is how I approach such problems as a home [s]bodger[/s] mechanic. It may be that the hassle of just getting to the plugs is such that it's the major part of the job and so it makes sense to do them all, I don't know.
Replacing parts until the problem goes away is expensive and wasteful. Again, I'm not saying that's what this garage would do, but it does happen.
Posted : 10/07/2017 6:24 pm
 Ewan
Nope, it struggles to start for ages, so I got a code reader. When it was due it's service i mentioned it and the garage plugged in its diagnostics machine and said new glow plugs.
Posted : 11/07/2017 6:48 am
yep sure sounds like the code readers right .
sounds like unburnt fuel from the cylinder being put out the exhaust when cold until the cylinders warm enough for ignition
Posted : 11/07/2017 8:01 am
The guy I got my Vivaro off would sort it for you but he is near me in Bolton.
He buys vans from all over the place so he may know someone near you, let me know if you want his number etc.
Posted : 11/07/2017 8:27 am
