£1600 audio etherne...
[Closed] £1600 audio ethernet cable
So is that a yes or no? 🙂
Surely you conducted listening tests before coming to the conclusion that:
One upside of getting into loudspeaker design was discovering that when it comes to speaker cable you'd be very well served by standard 13A mains cable!
Posted : 11/03/2014 10:00 pm
I'd need to get rid of the electrolytic caps in my home hi-fi speakers before a listening test on cables would have value! 😛 13A mains cable has very good DCR, inductance and capacitance for most loudspeakers if the runs aren't extremely long.
Posted : 11/03/2014 10:11 pm
So that's a 'no' then is it?
And why would a cable comparison have no value?
Posted : 11/03/2014 10:18 pm
Can you tell the difference between different types of speaker cable in your home setup?
Can anyone, genuinely, double blind yada yada, as long as the cable is able to carry the current required and not long enough to cause problems from resistance yada yada?
Posted : 11/03/2014 10:25 pm
Have you tried?
Posted : 11/03/2014 10:30 pm
Just answering a couple of points raised with my earlier post...
This is classic meaningless diversionary twaddle.
Come up with some measurable effects that those cables produce and you will have us, otherwise it's just marketing bollocks.
I was referring to a complete 'system' rather than cables themselves so went a little off topic. However it's a pertinent point when doing blind or open listening tests. Aspects such as sound stage and imaging are not 'measurable' however I've found them to be a very good means of discerning the improvements (or not) offered by different system configurations. Yes it's subjective but having spent years in the retail environment and done thousands of demos it has always proved to be useful for clients.
Cables can very easily change the tonal character of a system and the cable manufacturers capitalise on this,
Really? What happens to the electrons in a $200 interconnect compared to a $20 interconnect that makes such a difference?
I'm not going to be drawn too much on this but when I refer to 'tonal character' I'm not referring to quality but how bright, smooth etc. a system sounds. Whilst I'm firmly in the camp that cables have a placebo type effect in that quality is perceived rather than improved, we used cables to make minor adjustments to systems to tailor the sound to the clients ear. Minor as they were time and time again this process worked so from experience there was (and still is) some impact cables play. Cost of cable was never a serious factor though, just a well manufactured cable.
£1600 on an Ethernet cable is utterly laughable. FFS a £0.20 patch cable will have to be manufactured to the same spec or it won't meet the category requirements. hmmm, we usually use blue cables for our network connections, we should try red, maybe that will sound better?
Posted : 11/03/2014 10:51 pm
Have you tried?
No, because I know the wiring inside my speakers, or to the terminals on the amp, is just normal (can't remember the awg) wiring, so anything in between that isn't thin or made from cheese can't make any difference without the assistance of magicke. And I'm certainly not spending loads of money on fancy named cables to confirm that! It's just electricity, flowing through metal.
Posted : 11/03/2014 11:11 pm
ask1974 - Member
Very similar to my experience - small but repeatable differences.
bigjim - Member
Have you tried?
You don't need to spend loads of money - try twin and earth mains cable versus a cheapo 79 strand type.
I'll buy you a pint if you can't tell the difference.
Posted : 11/03/2014 11:28 pm
Ask1974 - just a little point but soundstage and imaging are nearly always linked to phase distortion or rather shift/time smear (or lack of it) amongst other things. It's not something hifi companies generally like to talk about or advertise figures for but can have a massive effect. Speaker manufacturers like to publish a lovely "flat" frequency response graph yet don't want to discuss phase.
I'm going to gracefully bog off out of this discussion now 🙂
Posted : 11/03/2014 11:35 pm
I'd argue that a pair of modern Adam, Mackie or JBL monitors are very accurate, brutally honest and non flattering in terms of reproducing all the frequencies and amplitudes of sound in the recording compared to hifi speakers.
Indeed. Which is why a lot of people think they are harsh and uncomfortable. Hi fi speakers tend to have an artificial hump in the bass to give plenty of "kick" and a nice warmth. This cuddly warmth is also why a lot of people still prefer vinyl. Accuracy is irrelevant for rock and pop because you've no idea what was on the original recording anyway - accuracy becomes a myth.
Most of my listening is classical and as a concert goer and amateur musician I have a pretty good idea what that really sounds like. So my vote is for CD, big solid state amps and properly designed, well built (old fashioned) speakers.
Posted : 11/03/2014 11:50 pm
Aspects such as sound stage and imaging are not 'measurable'...
A point source loudspeaker with perfectly omnidirectional output and linear phase response and perfect transient response will have perfect soundstaging and imaging. Any divergence from a true point source, any less than perfect polar response and any variation in phase response or delay/overhang in transient response will disrupt the soundstage/imaging. It's all measurable! It's also completely impossible to achieve those ideal goals.
Posted : 12/03/2014 12:02 am
CGG, why would a speaker cable comparison have no value?
Interested in your response.
Posted : 12/03/2014 12:09 am
I think if it's properly tested it should - but from what I've read about using cables to tweak a system tonally sounds to me like the way you'd subtly tweak a passive loudspeaker crossover to suit a given room, in which case rather than buying expensive cables isn't it better to measure the electrical effects of the cable and put those components in the crossover and use a hefty cheap cable with minimal electrical effects?
Posted : 12/03/2014 12:23 am
Funny how there never seems to be a before and after test.
Posted : 12/03/2014 12:33 am
CGG, I use cable to slightly tweak a system tonally because it's more convenient than modifying a crossover.
The cost of the cable is irrelevant, btw.
I'm still not clear if you believe that different speaker cable will affect the sound of a passive system.
You say it 'should', which would suggest you do, but I assume this is not something you've tested yourself?
Just interested in the views of someone who does this sort of thing for a living.
Posted : 12/03/2014 12:45 am
Hmmm, this goes right back to the early eighties when I used to read hifi mags regularly, 'cos I used to sell it.
HiFi News & Record Reviews was my 'bible' especially Ken Kessler's page at the back.
Anyhoo, I remember reading all sorts of stuff about fancy OFC cables, directionality, and all that stuff, but it was pointed out that using 13A solid core mains cable made just as good a speaker and interconnect cable as stuff costing tens of pounds per metre.
I'm with CGG, I enjoy listening to 6Music through a plastic Pure One tranny, and my home system is a Yamaha DSP-AX2 amp into Sony Pascal 5.1 surround speakers, with most music from my Mac Mini fed vis TOSLink ripped at 320Kb.
The speaker wire is all basically bell-wire, more or less, and I've been getting a huge amount of enjoyment from it for getting on fifteen or more years now. (Minus the Mac, that's just a couple of years old).
Truth is, I get more obsessive about my in-ear monitors, because I spend more time listening to music via an iPod or phone, and it's much more intimate, I can hear greater variation in mastering and such like because the music comes straight to my eardrums.
And I can't afford to upgrade my home audio system anyway.
Posted : 12/03/2014 12:52 am
CountZero - Member
I assume you conducted your own comparisons before reaching the conclusion that cabling is merely 'Voodoo'?
Posted : 12/03/2014 1:01 am
Here's a good website for those interested in taking this discusssion any further or if you wish to test your system or ears [url= http://www.audiocheck.net/soundtestsaudiotesttones_index.php ]Audiocheck/sound tests/tone generators/blind audio tests[/url]
It's been an entertaining thread so far, but the lack of pics and diagrams is below par for stw, so here's a nice sounding PMC MB2i tuned and custom specced by someone with 25yrs experience as a BBC Radio sound engineer, they're for sale btw,
he's also got a cracking selection of personal DAT recordings from his bbc days . Ti'z a shame i have to settle for my common/garden variety KRK Rokit 5 monitors and KRK 10s sub when i'm at home, 24bit/192kHz recordings whenever possible of course….we're all about the [url= http://www.linn.co.uk/music ]Linn Recordings[/url] here don't ya know 😉 .
Don't spend £300 on cables, spend it on room acoustics instead - that [i]will[/i] make a significant difference or if your wife/girlfriend will take offence to things hanging on the wall and big foam lumps in the corners then invest in decent quality headphones or in-ear monitors….but that's an entire thread all of it's own.
Posted : 12/03/2014 1:41 am
That's a very interesting web site - addictive too. 🙂
Don't spend £300 on cables, spend it on room acoustics instead - that will make a significant difference or if your wife/girlfriend will take offence to things hanging on the wall and big foam lumps in the corners then invest in decent quality headphones or in-ear monitors….[b]but that's an entire thread all of it's own[/b].
I'm all ears 😀
Not very good ones, admittedly.
Posted : 12/03/2014 12:00 pm
I'm with you.
Posted : 12/03/2014 12:46 pm
I do find the top end tiring depending on the kind of music.
I think van damme blue is the one I've heard being used most by pros, or in studios etc, and its cheep cheep.
Posted : 12/03/2014 6:31 pm
Page 4 / 4
