11+ verbal reasonin...
[Closed] 11+ verbal reasoning exams....no idea how to do this question.
16 Users
For my daughter....
688 / 8 = 25 * 5 = ?
And other similar numerical combinations.
verbal reasoning this...am I missing something obvious?
Ta
Posted : 18/10/2011 8:11 pm
 tron
It must be some sort of horribly expressed number sequence with equals signs instead of commas...
Posted : 18/10/2011 8:16 pm
That's sorted that then... ❓
Posted : 18/10/2011 8:22 pm
Well apart from recognising that 668/8 = 86 and has nothing to do with either verbal reasoning, or 25, *, or 5, what is there to miss? The answer is clearly "wrong".
Posted : 18/10/2011 8:24 pm
Short on detail on the op, this was a multiple choice with answers of 18,19,21,25.
Posted : 18/10/2011 8:28 pm
How is that a "verbal reasoning" test?
Posted : 18/10/2011 8:30 pm
Posted : 18/10/2011 8:31 pm
Good point mr woppit...and I really don't know.
Posted : 18/10/2011 8:32 pm
Is that the whole task? No question? No verbal reasoning there.
Posted : 18/10/2011 8:33 pm
 Bez
If there are two words I think completely fail to relate to that question, they're "verbal" and "reasoning".
Have you accidentally obtained a copy of the Numerical Bollocks paper?
Posted : 18/10/2011 8:36 pm
Defo verbal reasoning...daughter sat a mock test on Saturday and there was a section with 7 such questions. I told her should have just ticked answer "c".
Posted : 18/10/2011 8:37 pm
Sure it wasn't non-verbal reasoning?
Posted : 18/10/2011 8:39 pm
how is that verbal reasoning it involves numbers and symbols and most importantly no WORDS.
Posted : 18/10/2011 8:43 pm
 Bez
I'd be inclined to verbally reason with whoever set that paper.
Again, defo vr and i'm glad everyone else is as confused as me.
Posted : 18/10/2011 8:45 pm
That's hugely confusing. Usually it has absolutely nothing to do with maths but it is difficult to stop using the symbols that way. Was there nothing else or what does
mean?
That sort of question messes my head and has me reaching for the leffe
Posted : 18/10/2011 8:50 pm
Ther's a couple of ways of looking at it:
The easiest is that the second number can be dived or multiplied by the first and the result is a whole number. 2 and 1 are the only ones suggested that do.
When you do the sums given as examples you get a result that contains one or more of the original figures, 2 multipled or divided by 1 gives 2, which is one of the original figures.
Posted : 18/10/2011 8:55 pm
Whoever set these questions is just incompetent. I would question going to a school that sets such nonsense. Perhaps discuss it with the head of the school concerned or, if they won't listen, find a better school?
5 years of this kind of craziness is going to drive your daughter up the wall.
Posted : 18/10/2011 9:16 pm
Definitely go and discuss, do not send them a letter it'll be a waste of time.
Posted : 18/10/2011 9:19 pm
 Bez
Send them a letter written in numbers.
Posted : 18/10/2011 9:24 pm
leffeboy - Member
mean?
the other similar numerical combinations means 6 other similar questions. Daughter could only defo remember this one to ask me about.
Posted : 18/10/2011 9:26 pm
It's not some weird sort of punning thing is it? 688/8 could (somehow, bizarrely) be 'sick, satiate, overate'
I can't see how it could be, and I've no idea what 25*5 would be, but I just wonder if there's an alternate, non-numerical, take on this... If so I reckon 21 is the answer ('to one')
either way it's a stupid question! Is she sure she remembers it correctly?
Posted : 18/10/2011 9:54 pm
Can we have some of the other questions?
I think if it's verbal reasoning, we should be reasoning verbally....
Posted : 18/10/2011 9:58 pm
I cant give any more example questions as she can't remember any and the paper is not released after the test.
..and she is sure how she describes the question is what she saw. It's just not making any sense and I am thinking that she must have recalled it incorrectly. There is no logic or pattern to the question.
Posted : 18/10/2011 10:01 pm
Did you read my answer, Rockhopper? I identified the common factor, multiples or dvisions with the same numbers in the answer, before you posted the four choices. 100 / 10 and 100 x 10 for example . However, as there is an infinite number of answers that fit the conditions the question only made sense when you revealed the limited multiple choice responses.
Posted : 19/10/2011 4:27 am
But if the common factor is as you describe then surely the answer would be in the form yx(operator)x rather than just a two digit number.
Posted : 19/10/2011 8:26 am
Having googled 'verbal reasoning' and looked at their mathematical examples, it seems the most likely explanation. Either she's misremembering / misread it, or the question was set incorrectly.
Or, the verbal reasoning you're expected to apply is "this is nonsense" (-:
Posted : 19/10/2011 8:46 am
688 / 8 = 25 * 5 = wrong!
There you go. 🙂
Posted : 19/10/2011 8:51 am
 Bez
My computer is slow as hell this morning so I tried again whilst watching it trying to compile stuff.
Followed my thoughts from yesterday about digits being codes for letters, but after various juggling and shifting of those combinations, I can't find anthing that makes any sense.
Ended up googling in frustration.
This page supposedly lists the question types for 11+ Verbal Reasoning. None of them match the format you have up there (a couple are close, but still very distinctly different) so I'm still wondering whether it's been remembered accurately.
http://www.elevenplusexams.co.uk/advice/verbal-reasoning/gl-assessment-question-types-at-a-glance
If anyone here works in eductaion and can explain to the class how in the name of Satan question types 11, 17 or 18 are "verbal reasoning" then I'm sure we'll all sit cross-legged in silence and listen to that one.
Posted : 19/10/2011 8:59 am
From the site^^^
The type of tests that make up the 11+ are concealed by schools to prevent preparation
Tells the story really.
Sounds like the good old days when my kids were at school when the schools/teachers standard excuse was "we did not know that would be in the test so have not taught it"
Same issues exist at uni given the issues my kids had. The standard of teacher training and support is very poor according to my daughter who is 2yrs into her "career". She was astonished at the poor quality of lecturing when she did her PGCE after having done her MA in art/design. She almost gave up after being placed in one particular country school and saw what was going on. She stuck it out and actually created a change culture and the head teacher was moved on!!! Got a glowing report which gained her her first job months before finishing the course 😆
Speak to the teacher and ask what class prep was done, check home work books for examples
Posted : 19/10/2011 11:21 am
