What penis head thought that having 0.75l bottles was a good idea?
Why so small?
Why not bigger?
Total ballauex
https://www.beronia.com/blog/en/the-origin-of-the-750ml-wine-bottle/
I'd recommend going for magnums or jeroboams if you're a thirsty type.
Because seemingly wine goes off, if you don't sink two bottles to yourself and then hit the Internet complaining about it.
two sensible glasses for a table of 4
any smaller becomes uneconomical, bigger means it doesn't get drunk and goes off. Also transport, the bigger bottles adds corresponding weight because glass is heavy.
side note: There are only about 3 (relatively small specialist) companies that can make champagne in a bottle bigger than a magnum because of the kit required and there are specific techniques, so if you are debating a methuselah etc of some big label champagne, it's not worth the bother, it will be someone else's production behind the label.
From one bottle?
A 75cl bottle has 3 glasses worth by my reckoning!
^^^ correct
From one bottle?
Two sensible glasses and two thirsty onlookers
Ah yes, that popular wine serving of 93.75ml. I blame the EU.
I presume you meant three? 125 x 6 = 750.
The trouble is that non metric quantity of 4 participants.
Now if there were 5 at the table it would make more sense.
As an afterthought what is the chance of getting 4 people to want the same wine?
75cl is a great size as it fits fine into a standard bottle cage.
Bottles? Glasses? Pfft!
I buy it by the box, put a hole in the top of it then sit in front of the telly in my pants, slurping it through one of those big curly straws, while chewing on a big block of vintage cheddar like it was a big cheesy Mars bar
Cuts down on your recycling too, so its a win/win
Eh?
Is this due to that well known phenomenon that bigger objects have a much higher surface area to volume ratio?
bigger means it doesn’t get drunk and goes off
Seriously? 🤣🤣🥴
How much can you carry? (French supermarkets)
