The Thule EPOS Towball Carrier is low faff, quick fitting and loading. It’s the best bike rack I have ever used. And I’ve used a lot of them.
By mark
Get the full story here:
https://singletrackworld.com/2024/01/thule-epos-towball-carrier-review/
The difference between this and Buzzrack system is in the versatility and flexibility of the retaining arms. On the Thule they are individually adjustable in both length and position rather than being attached to a fixed length rail. Also the clamps on the Buzzrack are dials that you turn to open and close the gripping jaws rather than the complete loop and ratchet system on the Thule. Being big flexible loops mean they can wrap around square sections of frames. While the Buzzrack does fold up like the Thule it's not as compact.
It sure is a lot of money for a little bit of extra convenience. In the run up to its launch I was hoping for a rack that grabbed the tyres rather than clamping onto my gritty post ride frame and blemishing the paint.
I can totally see that. I have to lug my older style Buzzrack some distance from the shed, screw the tow ball connector on then tighten it with a ratchet spanner, fumble around plugging the electrics in. Over the years a little extra convenience would be worth paying for...but £1k...I just couldn't personally
We need one that just grabs the tyres. Like the ones they get in the US of A.
it seems Thule have taken the buzzrack good points and improved upon and then trebled the price.
I was very tempted by one of these when replacing rack a few months back. Unfortunately the towball clamp doesn’t fit on the new breed of shallow profile retractable towballs as fitted to BMW EV’s.
Atera Strada it had to be.. 😞
I own 3 bikes and the Buzzrack fits all of them perfectly plus my mates various bikes. I'm not sure how much more versatility I need.
I know what you mean but my newer model has a lever rather than a nut so no tools required anymore.
The Thule might be more compact folded up but it makes no difference to my double garage.
I'm not a Thule hater, I've had loads of their stuff and it's very well designed and well built and lasts forever. The pricing now is aimed squarely at the 'money is no object' crowd and I'm surprised there's enough of those people to keep Thule afloat. Especially when all the hardware lasts so long, how often do you need to make a purchase?
Lots of other available at much more sensible prices for those of us who don't need everything to be 'the ultimate thing'.
My Atera Strada takes seconds to fit into the towball. However, with multiple bikes, it's the threading of the arms through frames that takes the time.
It's kinda hard to tell from the video - does this one have a separate uppy bit for each bike? 🙂
* I do not want to be 1400 euros lighter
edit: never mind 1665 euros !
Thanks Mark. Hmm, that does seem very convenient... I'll add it to the list of things to buy once I'm rich!
Might need them to bring out a four bike version though! The kids' bikes are nearly too big to go in the boot.
Anyone know why you don't see the US style ones which grip the tyres over here? Or indeed the vertical ones?
I’ve got the predecessor, the Thule Easyfold XT
The lower aluminium base has detached from the upper plastic runners and is now gorilla taped to the max.
Dreadful quality and poor construction for a princely sum.
Is the new design aluminium channeled into the upper plastic?
If so be interested to see how long it lasts.
Also UK road salt must be a potential nightmare for tha aluminium
Anyone know why you don’t see the US style ones which grip the tyres over here? Or indeed the vertical ones?
I'm no expert but in the UK we have tow balls and in the USA and Canada they have receiver hitches. This a big square into which you can plug all sorts of accessories (including tow balls). It gives a much stronger interface for such a high, heavy item.
Does look a great rack, but really can't see the cost uplift from something like Buzzrack E-Scorpion 2.
In the text review of the Epos, citing integrated lights, number plate and wiring is not really a differentiator, as most decent racks have this.
Whilst the arms do no adjust in length, they are central between the bikes and they can be moved in many location individually and as a pair up and down, and the clamps fit so many different profiles from big carbon box sections to skinny steel and plenty of room for XL 29ers
It folds up enough to easily put in the boot. Easy to put on the ball - holds itself level and them quick to tighten
and is less than a kilo more than the Thule (18.1kg, vs 17.3kg), will do two ebikes, and even has some little wheels and will take a 3 bike adapter
£375 from Roofbox..
Cheapest 2 bike Epos I can find is £850...
Just can't why you would shell out an extra £500 or so (and saying that as a previous Thule rack owner)
The price differential is indeed extreme for the extra benefits of the Epos over the Buzzrack. Purely on functionality the loop ratchet straps on the Epos are a revelation to use compared to the threaded jaw clamps of the Buzzrack. and indeed previous Thule racks of the same ilk. The independent arms for each bike are much more useable on a variety of bikes than the more rigid arms on previous Thule's and the Buzzrack. There is a lot of convenience been carefully considered with this new Epos over previous designs.
But I'll end in the same manner as I started. There's a huge price premium for the amount of extra benefits. But benefits they still are.
Not a single bike (from 29ers, to road, to kids bikes) that have had any issues accommodating.
But in this case the only difference appears to be the little strap clamps, but if you think it is worth the extra £500 then fair enough.
That's not what I said really. There's more than the clamps, there's the arms, there's also the ergonomics with the convenient carry handle that makes it very easy to lift and move about. Like I said, there's lots of little refinements that make it the best rack I've ever used.. The price is off the scale. But that's immaterial to it's function.
The price is off the scale. But that’s immaterial to it’s function.
Not really as you always have to balance function and cost.
The article implies that many of the features are unique and new (The Scorpion has a centrally mounted lift handle btw), but that simply is not the case. Now if you have been using order racks of various flavors could see how such ease of use features would seem brilliant, i found the same when going from my old Thule to the Scorpion.
Anyway hope you didn't have to pay retail for it!
I'm glad you are happy with your purchase. For me though, if I had a choice between the two and didn't have to pay for either, there's no question the Thule wins. It's as good as bike racks get, right now.
We don't pay for review product.
Ahhh leave Mark alone.
i've got one of the older ones with the arms like angry geese and it's not too dissimilar, I rate it. Lot of money in one go when I bought it three years ago, but is covered in far more expensive bikes and has added flexibility.
its a lot cheaper than buying and running a van.
scaredypantsFull Member<br />I want* a vertical rack, like https://ebikespartsandaccessories.com/en-gb/products/vertical-bike-rack-4-bicycles?variant=46764386615628&utm_source=google&utm_medium=cpc&utm_campaign=Google+Shopping¤cy=EUR&country=GB&gad_source=1&gclid=Cj0KCQiAtOmsBhCnARIsAGPa5yaUXAbxuxb7UkF6xRdw9i9X5o5dfUWmlVxigcwLJU-uDGR0ACLvvFcaAsmGEALw_wcB
/p>* I do not want to be 1400 euroslighter
Well worth it IMO.
Takes seconds to load a bike. Also it doesn’t obscure the lights.
Mark (or anyone else), have you tried an Atera Strada Evo 3?
Unlike the Thule you can add a fourth bike but it’s also rated for e-bikes (but only two unless they’re lighter ones). And it’s about half the price and you can open vertical tailgates. Wondering if I’m missing anything?
I have the next model down, bought last summer, the Atera STRADA E-Bike XL 2 bike carrier. Works fine with a FS eMTB and a gravel bike, haven't tried other combinations
I'm still in shock about the price... I simply can't get past it to justify it in any way whatsoever even though I'm currently the last one in the pub as the others lob their bikes in vans or have Atera Stradas...
I had the Atera Strada Evo 3 on a Merc E class estate. It worked great when I needed to use it. Opening the tailgate was a piece of cake
I'm using a transporter now and have a DL3 to use if I'm not putting them inside
Neither fold up though, the footprint remains the same, just the vertical bar that folds down towards the horizontal bar
I have to say, I really want those racket strap arm things - I wonder if I can buy them aftermarket somewhere to put on my rack.
Look at Fiamma arms for Motorhome/caravan bike carriers. Different lengths are available. Not lockable, but who trusts bike carrier locks?
https://www.agentfiamma.co.uk/fiamma-carry-bike-accessory/
Does anyone know if these tilt enough for a VW T6 with barn doors?
Thanks
Elements of a classic ST thread:
Person 1: "This is my objective review and I have personally found this rack the easiest I have ever used"
Persons X,Y,Z: "I have never clapped eyes on this rack, it's more expensive than mine, therefore your opinion is wrong"
Can you redo this review after using said rack for 4 years every weekend with either 3 bikes or 2 ebikes. If it lasts it may be worth the investment, if not.?
With the uprights being so adjustable on every direction, doesn't the bike move forwards / backwards (from the bike's perspective) quite a bit? I know the wheel straps would stop it going too far, but still...
I think I'm probably more careful than many. With my Atera I generally put three extra straps on. One from each side in such a way that they tension against each other to limit that kind of motion plus a third straight through the frames to the rack as a worst case scenario safety net to drag the bikes along behind the car if aliens zapped half the rack out of existence. Do you guys normally add straps, or just rely on the frame clamp and wheel straps? If I trusted those on this Thule then the decrease in faff factor could well make it worth it for me...
I always use an additional lock, holding the frame to the rack. I do this on my own rack and always did so when I was carrying bikes for a living. Having said that, I've never used an additional strap or lock for roof mounted bikes, so think of it more as a security measure than a safety one.
Not once, in many years of using racks. Figured that 3 securing points would do the job.
