New SRAM X0 Eagle A...
New SRAM X0 Eagle AXS: First Ride Thoughts
The new SRAM X0 Eagle AXS drivetrain requires a UDH equipped frame. Why? To enable a direct bolt-on mounting method that’s designed for robustness and ridiculous shift under-load capability.
By ben_haworth
Get the full story here:
https://singletrackworld.com/2023/03/new-sram-x0-eagle-axs-review/
Posted : 21/03/2023 3:00 pm
Looks great. Lots of good ideas and some questions.
Will they continue this alongside existing Eagle AXS or is it a total replacement? For frames without a UDH, this is a non-starter and pretty much narrows my groupset choice with my existing frame.
Posted : 21/03/2023 3:27 pm
Too cheap for me. I'm waiting for the psychic version with no shifter.
Posted : 21/03/2023 3:33 pm
durwyn, martib, wimpsworth and 4 people reacted
I'll wait for the sentient AI version that's better at gear selection than me.
Posted : 21/03/2023 3:42 pm
The rear mech is flipping well sturdy.
Lol. I'd love to test that claim here in the Lakes...
Posted : 21/03/2023 3:48 pm
durwyn reacted
You know, it'd be nice if they put any money towards an actual 'proper' sized reverb AXS. It's 4 years old now.
This new groupset does look good, I'll admit - as a current AXS owner - but my frame doesn't have a UDH so I'll never be a potential customer unless Nicolai come out with a retrofit UDH, which I can't see happening.
Posted : 21/03/2023 3:50 pm
Looks perfectly rational, but is it going to be an open standard, or are Shimano going to bring out the SDH next year and we'll be locked into whatever system the OEM choses?
Posted : 21/03/2023 4:00 pm
I'm just impressed that your chain is as filthy as mine 😀
Edit: Casette cost jumps out at me. Is there any real reason it won't work with another 12sp casette? Appreciate it may not shift as well under power but casette and chain are £535 alone. Could be a way to save some cash.
Posted : 21/03/2023 4:03 pm
Looks perfectly rational, but is it going to be an open standard, or are Shimano going to bring out the SDH next year and we’ll be locked into whatever system the OEM choses?
the "UDH" was an open standard allowing any normal mech to attach
this attaches to the place where the UDH hangar attaches (removing the need for the hangar)
current shimano will therefore work on anything (using a UDH hangar) that the new Sram stuff works on, but I dont know if Sram have patented the concept of direct mount.
Posted : 21/03/2023 4:05 pm
 cy
This completely replaces AXS. They also aren't updating the mechanical drivetrains so if you don't have UDH then it's mechanical only. It's completely not backwards compatible. Even the chainline of the cassette is different. It's wider, which means it runs into your frame if you committed to UDH Revision E 2 years ago, and they didn't properly disseminate the information for Revision G with the Transmission information in it. Not all UDH frames are equal......
Posted : 21/03/2023 4:07 pm
kelvin reacted
 cy
Transmission cassettes are 2.5mm wider chainline that any other cassette. With the direct mount rear mech, they have put the cassette effectively where the dropout cowl is on a regular frame, so that cassette will foul the dropout face plane of any other frame even if it uses a regular UDH hanger and other SRAM rear mech.
Posted : 21/03/2023 4:09 pm
kelvin reacted
So there are different versions of a Universal hanger that aren't compatible with each other? More of a Multiversal Derailleur Hanger then innit?
Posted : 21/03/2023 4:27 pm
triple_s reacted
 cy
All the versions of UDH are compatible with eachother. The direct mount transmission rear mechs are necessarily compatible with frames designed to earlier versions of UDH.
Posted : 21/03/2023 4:31 pm
benpinnick reacted
if you don’t have UDH then it’s mechanical only
I read that existing AXS was remaining in production for us non UDH types?
Posted : 21/03/2023 4:32 pm
Sounds utterly awful.
I'm sure STW will love it.
thegeneralist doesn’t like it, sounds like it could be good
Posted : 21/03/2023 4:35 pm
davros reacted
Wasn't the mech hanger there to protect the frame as well as the mech?....
Posted : 21/03/2023 4:38 pm
durwyn, kelvin and PrinceJohn reacted
I wasn’t gonna bother, but now I’ve seen this, I’ll be putting an order in.
Posted : 21/03/2023 4:42 pm
davros reacted
So replaceable mech hangers ideally give you a cheap (UDH are only about £15) part that breaks to save both the frame and the mech. Now many times that doesn't actually work - many times over the years I've ended up with both a bust mech and a bent hanger, but sometimes it did.
This makes the replaceable part an (expensive?) part of the mech. But what protects the frame? I've heard horror stories of UDHs (and some other manufacturers more recent hangers) rotating and wrecking the seat stay. How is the frame affected if the first stage of the mech gets bashed in different directions?
Posted : 21/03/2023 4:46 pm
Honestly, what kind of wizardry justifies a well over 100 percent rise in the RRP of a chain? I know SRAM chains are supposed to last well, but still...
Posted : 21/03/2023 4:48 pm
According to the embargoed video that I watched, current AXS and mechanical drivetrains aren't going anywhere. IIRC the guy hinted at new stuff coming too. It'd be commercial suicide to stop supporting consumers that have current bikes that don't have a UDH, given that the vast majority of bikes out there don't. Maybe things will be different in 10 years time....
Posted : 21/03/2023 4:51 pm
Many things putting me off as an electric shifting convert. Overall price is obviously the biggest & also lack of cross compatibility - it's only going to work with a flat top chain, that costs how much??
Just annoying that they've opened up use of the UDH, and tried to closed options on chains and cassettes - or am I missing something.
I've axs on two bikes (and another form of electric shifting on another) and really happy with them, but I cirtainly couldn't justify the 'upgrade' for the stiffer rear mech and slightly better shifting under load. Shifter also seems like a step backwards - more like the archer components v1....
Ill wait another few years for the price to drop and compatibility to improve.
Posted : 21/03/2023 4:56 pm
According to the embargoed video that I watched, current AXS and mechanical drivetrains aren’t going anywhere. IIRC the guy hinted at new stuff coming too. It’d be commercial suicide to stop supporting consumers that have current bikes that don’t have a UDH, given that the vast majority of bikes out there don’t. Maybe things will be different in 10 years time….
Exactly. Even SRAM aren't stupid enough to stop supplying chains/cassettes/mechs etc to thousands of customers who haven't or can't upgrade to the latest AXS stuff. The 'old' Eagle AXS stuff isn't going anywhere soon.
Posted : 21/03/2023 4:58 pm
phew.. cant work on any of my bikes
massive relief that it works just as good as my xt drivetrain that cost 10% of this probably
Posted : 21/03/2023 5:03 pm
martib reacted
Just how long will a £500 cassette last?
Posted : 21/03/2023 5:21 pm
And you'll only be able to run those flat-top chains, too. Which are not great.
Posted : 21/03/2023 5:35 pm
...and I'm annoyed about dropping £70 for a new SLX cassette every year.
Really makes you think 🙄
Posted : 21/03/2023 5:43 pm
Cowman reacted
Based on how long previous iterations have lasted, kin ages.
Posted : 21/03/2023 6:08 pm
and I’m annoyed about dropping £70 for a new SLX cassette every year.
How many miles are you doing to have to replace a cassette yearly?! 😲
Yup, I don't exactly do the most miles but I've got 2000km over 3.5 years on an X01 cassette and XX1 chain and they've still got a huge amount of life left.
Posted : 21/03/2023 6:16 pm
Tbf, it's probably not yearly. It's not the miles, it's the incline. It's up or down here, very little rolling terrain. I spend most of my time climbing in gears 1-3, so they wear much faster than the rest.
Posted : 21/03/2023 6:18 pm
With now both SRAM and Shimano having 12 chains and cassettes that can shift very well under full load, why does SRAM’s top of the range cassette cost £645 and the chain is £160, where the XTR one costs £330 for the cassette and £60 for the chain. Why such a difference? It’s insane!
Posted : 21/03/2023 6:21 pm
STD. Sram transmission development
sorry feeling childish
Posted : 21/03/2023 6:27 pm
So does this stop working in a much more efficient time than the older version? 😉😂
Posted : 21/03/2023 6:43 pm
Those prices are batshit mental.
Posted : 21/03/2023 6:55 pm
a11y reacted
April 1st already?
FFS look at those prices, and it doesn't shift as well as XT?
APF 🙁
Posted : 21/03/2023 6:58 pm
a11y reacted
So the main benefit of this kit is that it allows you to do what Rapid Rise did 16 years ago?
Oh, and why kudos for 1x? I'm on board with it but still not convinced it's any real kind of improvement as the manufacturers seem to spend all their time increasing range back to what we always could do with 2x or 3x!
I'll out myself as no fan of Sram though, which may cloud my judgement.
Posted : 21/03/2023 9:01 pm
it costs £1,715
How much more fun will it make my ride if I fit it instead of Deore?
Posted : 21/03/2023 9:13 pm
Oh, and why kudos for 1x? I’m on board with it but still not convinced it’s any real kind of improvement as the manufacturers seem to spend all their time increasing range back to what we always could do with 2x or 3x!
Ha! I'm sorry, I know a good amount of mtb'ers are opposed to any sort of progress or improvement in technology and bikes, but this is just utter nonsense. 1x not an improvement over 2x or 3x. Come on now... 🤣🤣🤣🤣🤣
Posted : 21/03/2023 9:15 pm
BB, fatbikeandcoffee, a11y and 1 people reacted
it costs £1,715
The launch price of X01 AXS, in 2019, was £1900.
And here we are, a few years later, with a GX AXS available for a few hundred quid.
Posted : 21/03/2023 9:22 pm
davros reacted
With cassette and chainset?
Posted : 21/03/2023 9:39 pm
I've thought for a long while that the extra reach needed on modern wide range cassettes puts significantly more leverage through a mech hanger than ever before. It seems much more involved to keep on top of mech hanger alignment.
Something like this needed to happen.
Posted : 21/03/2023 9:44 pm
rfreeman reacted
Shame I have only one bike it will fit on!
Posted : 21/03/2023 10:40 pm
utter nonsense. 1x not an improvement over 2x or 3x. Come on now… 🤣🤣🤣🤣🤣
Heavier, less range, more fragile, and far more expensive.
Posted : 22/03/2023 8:26 am
for those talking about patents, Bikerumor (sory) did a patent patrol article a few years back. Admittedly most of these articles include a large amount of speculation, but it's still good to see what's being thought of.
https://bikerumor.com/patent-patrol-direct-thru-axle-mounted-hydraulically-damped-sram-rear-derailleurs/
also a bit about the shift ramps
https://bikerumor.com/patent-patrol-shimano-sram-campagnolo-all-file-major-drivetrain-updates/
Posted : 22/03/2023 8:59 am
Depends what you buy. I run mid cage XT 12 speed and that is (Relative to 1x) lighter, less but still adequate range, definitely no more fragile and certainly less fickle and prone to derailling, and quite cheap relatively speaking.
Posted : 22/03/2023 9:17 am
Before I never spend any money on this is there an easy way of finding out if your bike has a UDH?
Posted : 22/03/2023 9:27 am
there's a lookup on sram's website
It's also usually listed in the frame spec of your bike
Posted : 22/03/2023 9:48 am
How old is your bike? Think it only appeared in 2019. The text UDH is usually printed around the driveside rear drop out if it uses UDH. mine has a UDH, but I wont be rushing to replace the drive train just yet..... cost needs to come down quite a lot.
Posted : 22/03/2023 10:14 am
I got the impression from one review that there are variations of the UDH and not all are suitable for AXS Transmission.
Posted : 22/03/2023 10:25 am
kelvin reacted
1x is a reaction to the introduction of larger wheels not transmission complexity.
Posted : 22/03/2023 10:32 am
No bash guard, constant chain drops on anything remotely bumpy, chain suck mangling frames, never in the right chainring, cluttered bars, more cables, more maintenance.
Anyway, I think the argument about 1x Vs 2x/3c has been done to death.
Posted : 22/03/2023 10:46 am
[url= https://i.ibb.co/C6xC9JF/Untitled-1.pn g" target="_blank">https://i.ibb.co/C6xC9JF/Untitled-1.pn g"/> [/img][/url]
It's the future, Get onboard old men.
Posted : 22/03/2023 10:51 am
1x has also freed up space for alternative suspension designs.
Look at high pivot bikes.
Think about anti squat and anti rise when there are 3 different chain rings (although I think it was advantageous on my old turner 6 pack).
Posted : 22/03/2023 10:52 am
nickc and kelvin reacted
Wrong, wrong, almost wrong and wrong. In my experience.
And what about the upsides?
Posted : 22/03/2023 10:57 am
kelvin reacted
I've always said, the time to launch a £3k groupset is in the middle of huge financial strain around the world and massive inflation
Posted : 22/03/2023 11:54 am
The sorts of folks that'll buy this groupset now; aren't personally really suffering massive inflation or financial strain
Posted : 22/03/2023 12:08 pm
I don't think the photos really sell it for me, they remind me of this (takes hybrid commuter out of shed, fills watering can, takes photo)... 😀
IMG-20230322-121738
Yeah nothing like it, but whatever. The photos look like it's covered gunk.
edit: yes the kit has been used for review, but the colour scheme of the kit bleuuuighhhrrrr, gunk, but it really doesn't matter because it's waaaaaay out of my price range.
Posted : 22/03/2023 1:23 pm
Apologies if others have mentioned this, but I get that the mech is strong and will take a whack, or a fat bloke mysteriously jumping up and down on it, and also I have personally experienced that mech hangers do not save mechs but they do save frames when things really go south.
I've bent a few hangers with whacks and thumps, but I've only snapped them, and mangled mechs, from sticks in spokes. I think 3x over teh years. mech mangled, hanger snapped, frame ticket boo.
I'm not buying AXS yet, but what happens with a stick in the spoke? with a big tough mech do I now say bye bye to mech and frame?
Posted : 22/03/2023 2:15 pm
So why is does the mech look bent form behind ?
I heard 'dont worry about it' buy not the why ?
Also doent this system rely on the frame manufacturers getting their tolerances spot on from the factory - mech hanger alignment tool is not going to help anymore
Posted : 22/03/2023 4:39 pm
there's plenty of videos of fat blokes standing on the mech (well, not so fat) but a lot heavier than id be happy with on any of my kit
it looks bent from behind so the top pulley aligns with the cassette sprocket, lower pulley aligns with the chainring
only tolerance the frame manufacturer would need to get right is the size of the through hole, and thickness of the axle flange itself that the mech sits on. as the cassette butts to the mech hanger part.. the tolerances then all become SRAMS issue.
Posted : 22/03/2023 5:19 pm
anyone remember the derailuer hanger savers that kind of mounted the derailuer to the frame in the same way as this direct mount derailuer is - ie it resulted in the derailluer being cantilevered off the axle rather than hung from a hanger?
I had one on a specialized enduro in about 2007 - I'm trying to google for a photo.
edit:
this is the best I can find, it wasnt one of these, but worked in the same way, was made by shimano I think
https://www.ebay.co.uk/itm/194300340992?hash=item2d3d33eb00:g:eb4AAOSwZd1Vbthv&amdata=enc%3AAQAHAAAAwFldwu4EaoQJGMcQyNF9zeSNwZ3JPD1%2F3tuozNJG%2Bso3QMpDWlwJvXQhiiPz%2F4lq8FRr3u2eHQtBpuOx%2BXyeV0AumdCeUSSxnO7Cgwh7OAAEd18j3N6%2F%2B1i5JMTEMxWbikmKS9V%2BCVX4211QAofoUAQhnsGPIRou0b%2BlxcDzVtBx0fHOvxQjMLXRDblhXXqqu2SKkjXcFNbkuNTykJrNhd4dOM4RM3HuMavO5YBLHIcPiDHZ709Cz3OH5thMA%2F%2B%2ByQ%3D%3D%7Ctkp%3ABk9SR6aTsqPhYQ
Posted : 22/03/2023 5:33 pm
kelvin reacted
Got to touch the groupset in my LBS today, didn't jump up and down on it but was surprised how big and heavy the mech is and how light the "cheap" cassette is. The shifter looks like a tiny speedplay pedal
https://flic.kr/p/2ooDHEf
Posted : 22/03/2023 5:44 pm
found it ! it wasnt made by shimano, was made by specialized
https://www.certini.co.uk/components/service-parts/specialized-demoenduro-derailleur-guard--black__19437
protector
Posted : 22/03/2023 5:50 pm
All the videos I've seen of people standing on mechs they're standing on the axle, which seems kinda pointless to me. I'm glad it's strong there, but the most vulnerable point will always be the bottom of the cage, near the bottom jockey wheel.
I'm disappointed, but not surprised by Cy's comments that not all UDH frames will accept this new groupset.
Posted : 22/03/2023 6:16 pm
