Zwift meetups and s...
Zwift meetups and social rides ?
Cheers for clarifying oop north...
I've got the invite from Robbo for Sun morning.
Posted : 03/09/2020 7:18 pm
Well I've signed on for all three weekend rides though doubt I'll make all three. Depends on what the better half has planned for me much as anything.
Posted : 03/09/2020 8:09 pm
I've signed on for all three and will try and make all three, at least that's my thinking at the moment, need a rest day tomorrow so glad there wasn't an invite in their for tomorrow as I'd have tried to make it, and really need a day off! The Saturday one looks a toughie!
Posted : 03/09/2020 9:18 pm
I'm thinking of a figure of 8 ride in the morning Forge if you fancy it?? Haha
Saturday is going to really hurt, the Alpe is hard enough on it's own, but following the KOM...ouch! For sure I wont be getting a PB 🤣🤣
Posted : 03/09/2020 9:49 pm
@opp north I am all good for not riding tomorrow I'd pass in Figure of 8 🤣🤣
Is there a way to find my previous times on climbs like the Alpe as I've not done that climb for ages, not that I expect a PB based on the route but you never know 😉
ETA - Just found PB in Zwift Power
Posted : 03/09/2020 10:08 pm
Just think of it as a tapering event for Tuesday!
https://zwiftinsider.com/watopia/
You can use Zwift insider to click on the route and then they have links to the segments in Strava to get previous times. That is assuming you use Strava!
Posted : 03/09/2020 10:10 pm
No I don't use Strava any more just Garmin, I have though found what I need in Zwiftpower though only from events.....
Posted : 03/09/2020 10:11 pm
I don't Straaaavaaa! 😁
The way I see it, the hills can only feel easier after Saturday, so Tuesday should be a breeze! 🤣🤣🤣
Posted : 03/09/2020 10:17 pm
My hope is I get sorted with whatever was messing with my cadence prior to Tuesday. I think I need to check the trainer difficulty, I can't be doing with another crazy rpm session like this week's rides (having looked my "very spinny" climb in innsbruck Yesterday morning was 168 in 48:11 which is, frankly, very silly, indeed)
Posted : 03/09/2020 10:46 pm
Are you using a seperate cadence sensor Brian or the inbuilt one? If so it might be worth trying a seperate one as I found the in built one caused issues as it would deviate wildly and the trainer wouldn’t know how to react to the cadence changes.
Posted : 03/09/2020 10:55 pm
Generally the inbuilt - though mainly as it there or there abouts agreed with the external one when I tried that (and my legs) and was one less thing to faff with.
Odd thing on Tuesday is it seemed to sort its self, ended up with 85 rpm average which is a bit high for me - I tend to churn not spin - but not too bad, was just down right odd off the start, as if I were in erg or something.
Mostly yesterday morning seemed OK if a bit spinny, just up the incline where I'd normally push hard I was spinning like mad with relatively low resistance in the pedals.
It's not the first time it's happened mind and I did wonder following weeksy's comments on the other thread if my trainer is pairing through the companion app or some such silliness on occasion and throwing a bit of a wobbly.
Either way, it's all good, I really could do with learning to sit at 90rpm in a lower gear instead of dumping straight down the block and pounding along at 60-70 anyway so maybe zwift has realised this and just decided to train me like it or no.
Posted : 03/09/2020 11:16 pm
You've not got the trainer difficulty turned right down or off have you? I tried a race with it off and it was horrible. I had to change up a gear when I went up hills to be able to generate more power.
For the TTT tonight my average cadence was 96 - I couldn't settle into a gear towards the end for some reason. I needed a gear between the two that I had!
Posted : 04/09/2020 7:24 am
You’ve not got the trainer difficulty turned right down or off have you?
Not deliberately! I'd say not though on the simple basis I ran out of legs to chase down the hill on Tuesday and with the difficulty down I should still be able to pedal as normal and not spin out on the down slope. (my first thought was I was on the small ring but obviously a quick visual discounted that.)
As I say its happened before on and off, usually its sorted by the next ride though, - sort of like there's a gap between the zwift and elite updates messing up the input/output (though I doubt that's it).
It'll all come good in the end anyhow I'm sure.
(I did once try the difficulty right down and it was awful, like riding a dumb trainer really, also right up and it was laughable, a 5% incline felt near vertical, the alp on that would be comedy gold)
Posted : 04/09/2020 9:54 am
See if it works in the morning then Brian!
Did a practice ride up the Epic KOM at lunch time whislt doing a TR workout - averaged around 200W I reckon and took 38 mins for the KOM. I am planning on averaging about 220W tomorrow - put that into best bike split and it came out at 2hrs 35mins for the ride so hopefully our estimate is about right! Certainly wont be racing over the first two climbs and will see what I have left for the Alpe!
Posted : 04/09/2020 3:06 pm
Steady efforts tomorrow Robbo, I need to keep some in the tank to get up the Alpe, I want to complete not burn out.
At least on this route there is no radio tower!
Posted : 04/09/2020 5:01 pm
Huge respect for that one today chaps, it was tough! 1700m of climbing.
I had thoughts of going for a pb at the bottom of the Alpe but that went out of the window when I died halfway up! After that it was just a mental challenge to hit the top.
I'm wasted...time for rest and hopefully I'm good for tomorrow. Well done!
Posted : 05/09/2020 11:08 am
That was pretty horrible for the last 30 minutes. I was just trying to survive. If I suggest one of those silly routes again just tell me to shut up!
I thought taking it easy up the first climb would give me something on the alpe but I was still struggling. Prob need to fuel better for a ride like that I think - maybe stop for a picnic halfway up the alpe!
Still only 300m of climbing tomorrow and a nice quick route!
I have got a 24” monitor to run Zwift on now so can use a dual screen layout so I had Zwift gps running on the second screen but it was only showing me so I couldn’t track the others.
[url= https://i.postimg.cc/4yQjGvs7/FAA69-B06-B1-B7-4012-A7-EC-E2-FD3-C8-F50-E9.jp g" target="_blank">https://i.postimg.cc/4yQjGvs7/FAA69-B06-B1-B7-4012-A7-EC-E2-FD3-C8-F50-E9.jp g"/> [/img][/url]
Posted : 05/09/2020 11:37 am
Yeah I think fuelling was my issue too. Fasted is only good for so long...I had a gel and even considered a second one Haha
Reckon we could do the pretzel...its only the KOM twice...no alpe. But mega Pretzel etc is a no.
I even considered a Ventoux again but I've now firmly parked that one again after this morning.
Posted : 05/09/2020 11:42 am
Biggest climb done for a while I went on to get 47 miles and 1890m/6200ft climbing done all in, wanted to hit 100miles for the month so that's done.
Mega Pretzel is similar climbing today but more distance so I reckon that is in scope for a cold winters morning maybe a later start for that.
I felt good on the climb not my fastest but it wasn't horrid on reflection, bit of pain 2/3rd up but nice and consistent and picked my av wattage back up on the last 4 or so corners. Was less painful than it was the last time and we did a bit before it.
Fueling is important and I think many forget that an indoor ride is still going to need fueling like an outdoor ride it's still burning calories, I've been bitten by poor fueling and energy loss so I do keep an eye on that. During todays ride I had 2 x Gels, 1 mini bag of skittles and a banana, having had Porridge and Banana at breakfast before it.
Posted : 05/09/2020 11:58 am
See that's probably where I'm failing...I got to the bottom of the Alpe on just a coffee, then a gel. I probably need more solid food inside.
Posted : 05/09/2020 12:03 pm
It is something I have spent a bit of time looking at and I notice the difference in performance as well as what I ate the day before has an impact like big lunch light dinner not great really for a longer ride by that for me be 90+ mins
But we are all different and you have to find what works, that ride we just did is well over a 1000 calories burnt one gel is around 90 cal's so that delta has to come from somewhere and we did over 2hrs, you can do a good 1hr fasted over that need to look at something on the way to top up, at least for me.
Posted : 05/09/2020 12:09 pm
I guess I was a bit deceived by how good the legs felt in the sequoias and the KOM, that's why I thought I had trainer issues...the alpe told me it wasn't the trainer Haha
Tomorrow I'll bring food
Posted : 05/09/2020 12:20 pm
LOL the Alpe is a good climb to see how your doing :).
Tomorrow is less climbing fortunately, I have a SIS delivery due today so will be stocked up and ready.
Though as it's flatter I'll have to see if I can keep up as the flats seem to be my issue, happy with hills need more work on the flat!
Posted : 05/09/2020 12:39 pm
 DrP
OK.. anyone up for MEGA PRETZEL on Thursday? After school drop off start..circa 0915?
DrP
Posted : 05/09/2020 2:15 pm
Not sure if you're trolling DrP after what I said about Mega Pretzel above....
Anyway I have an excuse...I'm at work 🙂
Posted : 05/09/2020 2:47 pm
I couldn't do Thursday, if my mate isn't Riding Friday I might give that a go as a plan b.
Posted : 05/09/2020 2:59 pm
 DrP
Nah.. no troll!
I don't work Thursday, so will be a nice way to try to get fitness back!
100 ish km, with 1800m climbing... I'll prob stop for a sandwich halfway! Hopefully won't stop through boredom, hence wanting company!
DrP
Posted : 05/09/2020 3:35 pm
Good effort gents, didn’t fancy that one this morning, might have a go next Saturday.
Neil
Posted : 05/09/2020 4:32 pm
 Nick
Cheers fellas, I'm glad I didn't google Quatch Quest before I started riding or I might have stayed in bed, but glad to have tickets that one off. Knees hurt a bit so might have to miss tomorrow morning's ride, but hope to made the late afternoon one.
Posted : 05/09/2020 6:02 pm
Good luck with that one Neil, a word of warning...all feels fine until you get halfway up the alpe and your world falls apart hahaha 😉
well done Nick for earlier! I think i'm still going to have a crack at tomorrow morning, hopefully the pace won't be crazy, I can always bail if needed.
Posted : 05/09/2020 6:06 pm
Cheers my problem is I always start of to quick, at least it misses out the radio tower, can’t make tomorrow afternoon as either at Swinley or Surrey hills.
Neil
Posted : 05/09/2020 7:56 pm
 10
I am tentatively in for the ride tomorrow DrP, I have half an idea to do something ill-thought-out and join The Herd ride up Vent top before.
Posted : 05/09/2020 8:19 pm
Thursday is a no for me. Have to work I am afraid!
Legs are feeling ok now so should be good for the morning. Won’t push it too hard though. Maybe attack the volcano but we will see. Weeksy should be driving the pace!
Nick flew up alpe du Zwift in the second half. I think I must have had about a minute on him in the first theee quarters but then could see him catching quickly and there was nothing I could do about it!
Posted : 05/09/2020 10:14 pm
 Nick
Robbo, Coffee and the realisation that I was running out of time (to take my son to lose 0-4 at football). Didn't you stop for a minute for something? Don't think I would have caught you otherwise.
Posted : 05/09/2020 11:47 pm
Can't believe how much I died second half, at the bottom of the Alpe I felt fresh and was flying but by corner 10 I was going backwards and just struggling holding 200w at times.
Maybe I just went off too hard, or as mentioned above I just didn't have enough food to keep the effort going. Looking forward to the morning for more, at least it's not much climbing but not sure if I'll have speed for flats.
Posted : 05/09/2020 11:54 pm
I’ll be on the morning ride I think though a third evening ride on reflection be a bit much & I was a optimistic on that so after the morning ride going to rest up 🙂
Posted : 06/09/2020 8:19 am
Sorry to ditch folks, trying a reinstall now but I can't see it completing the updates in time to get back on the ride.
That's a fair awful start to a Sunday but at least that's my cardio done for the day!
Definitely something zwift related, there's no way I should be spinning out in 48:11,i tried the elite app again straight after, resistance is about where it should be and I'm sitting roughly where I'd expect on power and cadence.
Will see if I can get on when the reinstall is finished and if not I'll go rooting on the loft for the external cadence sensor though as I say, there's obviously an issue in the reading on Zwift being high rather than the output from the turbo.
Posted : 06/09/2020 10:09 am
I didn't come play. Still trying to recover from crashing and lots of delicate parts still. Saving it for Tues
Posted : 06/09/2020 10:10 am
You do right weeksy - some Timo discretion is the better part of valour.
That and we all need be on best form for Robbo's Races.
Posted : 06/09/2020 11:21 am
No worries Weeksy, we needed a flat one today for sure after yesterday, it didn't stop us going for sprint and KOM PB's!
I could see u had no comms when u got back Brian, did u sort the issues?
Might try an easy one in the morning but will be saving something for Tuesday...its going to hurt.
Posted : 06/09/2020 11:35 am
Sorry - said I was gonna make this morning's ride but forgot it was my turn to take my daughter swimming...
Hope you had a good one.
Posted : 06/09/2020 11:43 am
It was a good ride even if I was living up to my moniker and having to ride one legged on the hills. I could spin properly but couldn't push through evenly.
Ah well hopefully fixed by Tuesday otherwise that could be a long old ride up the hill.
Posted : 06/09/2020 12:09 pm
I think so.
Certainly seemed a lot better when I reinstalled but then I tried a ramp test which was laughable, given it was in erg mode so I should have been able to just sit and plod through the test, I kept having to up shift then my cadence pretty much parallels the power once I'm out of gears.
In theory cadence should drop off on the ramp test as you run out of legs, instead I started climbing rpm from about 200w to hold the required watts - in part as it really doesn't like you churning along at low cadence and high torque, though that's how I tend to pedal - and at 320 I think I hit about 120rpm, ticked over to the next power block and just couldn't get the cadence to get the wattage high enough.
Oh on the upside I got a "new ftp" of about 235 or something daft,that's got to improve my handicap for Tuesday, 😂
A very brief hundred yards or so on fan flats afterwards suggests I should be sorted but I needed to have some breakfast. All being well I'll join DrP's ride this afternoon and see how that goes but it's at a bit of a rubbish time so will see.
Does anyone fancy a commute tomorrow? Nothing too silly as I'm in the office so have a real commute to do to but I really need to get back into the habit of turning my pedals most days.
Posted : 06/09/2020 12:10 pm
Good ride this mornin. I did the Richmond UCI loop after. That’s me done for the weekend on riding and probably not on Zwift till backend of the week few bits on.
Hope to join on ride again soon
Posted : 06/09/2020 1:32 pm
I can do a commute on Wednesday morning but will be doing a workout at the same time but if someone needs motivation to do something I can put on elastic band mode so we can chat as we go?
Cheers for the ride this morning. Legs felt fine so think I just run out of energy yesterday. New PB up the volcano and beat 9 mins so pretty happy with that!
Posted : 06/09/2020 1:50 pm
Oh on the upside I got a “new ftp” of about 235 or something daft
Is that right Brian? Mine is 271 and you're much faster than me! I'd of thought you were in the 300's??
Still trying to decide...if I do then it will be very chilled to just turn the legs, so I'm not too dead for Tuesday. Was thinking a ride with the pacer bot. No hills.
Posted : 06/09/2020 1:59 pm
I’d of thought you were in the 300’s??
It certainly should be! 235 for me is very silly, won't take long for it to correct it's self though.
Posted : 06/09/2020 2:20 pm
Ah alright...I thought it was serious...ignore me haha!
Posted : 06/09/2020 2:27 pm
I have upgraded my Zwifting experience. I got a 24” monitor of amazon. I have then built a foldaway shelf on the side of my unit that holds the monitor and fan for putting the laptop on. I can then run Zwift on the main screen and TrainerRoad or something else on the second screen. When not in use (as this is in a corner of the lounge) it’s good out of the way.
[url= https://i.postimg.cc/1tkkxw7w/29-DD3-FD4-F2-E9-450-A-AC35-90-FB60-B5-F200.jp g" target="_blank">https://i.postimg.cc/1tkkxw7w/29-DD3-FD4-F2-E9-450-A-AC35-90-FB60-B5-F200.jp g"/> [/img][/url]
[url= https://i.postimg.cc/HnbfTnFK/A7881797-46-F6-476-C-8-BB9-0-B9684176102.jp g" target="_blank">https://i.postimg.cc/HnbfTnFK/A7881797-46-F6-476-C-8-BB9-0-B9684176102.jp g"/> [/img][/url]
[url= https://i.postimg.cc/5NMhn5CM/A8-EBC798-9876-4939-A9-B0-B9-D5-C2-EB433-D.jp g" target="_blank">https://i.postimg.cc/5NMhn5CM/A8-EBC798-9876-4939-A9-B0-B9-D5-C2-EB433-D.jp g"/> [/img][/url]
Load tested the shelf over night with a load of heavy books before using the laptop on it.
Posted : 06/09/2020 3:00 pm
Nice setup Robbo
Posted : 06/09/2020 4:49 pm
Better than my "shoved in the corner of the spare room with everything balanced on books" setup.
Next project is to set up a home gym with full permanent zwift setup and large wall mounted screen. Hope to get it started and done by Christmas.
First I need to find somewhere to put all the rubbish that's in there 😉
Posted : 06/09/2020 5:19 pm
 10
Well I had some technical issues there. I've tried to rejoin the meetup a few times and it's just dumped me in the sea.
Posted : 06/09/2020 6:22 pm
 Nick
Cheers Ian, sorry wasn't very chatty but companion app wouldn't connect properly to Zwift or if it did it just crapped out as soon as I started typing a message.
Posted : 06/09/2020 7:33 pm
@oop north I’m very lucky and have home gym it’s great, same wall colour as you have in your setup currently too 🙂
Posted : 06/09/2020 7:34 pm
I have sent out an invite for Wednesday morning. I have put the elastic band on to keep us together. I am doing a 3 x 12 min sweetspot session. You can use it for a recovery ride or whatever you fancy. Elastic band should mean we stay together and can chat to help pass the time. I am happy to share details of my workout if you want to do the same one (programme it into Zwift).
I have got a training programme plotted out to mountain mayhem next year! Got 45 weeks to prepare so going to make the most of it! 3 workouts a week plus race series, ttt and Sunday hills.
Posted : 06/09/2020 9:04 pm
Haute Route Virtual Ventoux running next weekend. Friday is Petit Boucle, Saturday is Ven-Top, Sunday is La Reine.
3,200M climbing in 3 days riding. I'm going to check with the boss but might try and get on this. Makes up for only 200m on the STW race league.
Posted : 09/09/2020 1:57 pm
That is some task over 3 days, usually after Ven-top or La Reine I need time off or at least an easy day. I actually found La Reine harder than Ven-top even though it's not as far up the mountain, I think it may have been the lead in and petit KOM that killed the legs first.
Not sure I could get through all that and function later in the day, especially Sunday!! I might jump on one of them though.
Posted : 09/09/2020 4:48 pm
That’s doesn’t sound too fun 3 days in a row! I might join one though!
Posted : 09/09/2020 6:46 pm
Maybe we could all join one event and do it as a Saturday or Sunday hills together?
Posted : 09/09/2020 7:09 pm
I'd be up for the Sunday one, done ven-top before and can't say I particularly want to do it again.
Posted : 09/09/2020 7:41 pm
I can't do the Friday invite, as I may do an IRL ride, Going to look at having bash at all Three Haute Route looks an interesting challenge, as what I had on that Sunday just got Covid Cancelled so am free now.
Posted : 09/09/2020 9:27 pm
The haute rides are next weekend (18th to 20th) aren’t they?
Posted : 09/09/2020 9:33 pm
Yep.
Posted : 09/09/2020 10:58 pm
 DrP
I abandoned my mega pretzel ride idea!
Had physio on the upper back yesterday, which gave me a terrible headache through the night! Then BOTH kids came into my bed!
Feel rough, so just chilling! Might head out for an hour on the mtb and see how wrist is.. but no mega ride online!
DrP
Posted : 10/09/2020 11:01 am
Sorry I didn't make this morning folks. I made it as far as turning on the turbo but my legs were (are) mince, no way I'd have managed a ride with you folks then the commute today. As it was the ride to the office was bloody hard work and saw my breakfast necessarily upgraded from porridge to a sausage roll from the pie man.
Posted : 11/09/2020 9:58 am
No worries Brian, we had a chilled one anyway testing the rubber band feature.
Posted : 11/09/2020 10:33 am
Did it work better than when we tried on the volcano?
Posted : 11/09/2020 10:37 am
So who is up for a zwift ride this weekend? Speaking with Robbo this morning and we have a couple of options...
Watopia Pretzel - 72km, 1300m of elevation, basically the KOM and hilly KOM in both directions, thankfully no Alpe.
France Tire-Bouchon - 61km, a lot flatter with 400m of elevation, all the routes of the France map in both directions, thankfully no Ventoux.
Thoughts or preferences? Saturday or Sunday preferred?
Let me know the consensus today and I'll set it up later this afternoon.
Posted : 11/09/2020 10:38 am
It worked Brian, I put out some speed at one point and went nowhere! 🙂
Posted : 11/09/2020 10:40 am
No different to normal then 😉
Posted : 11/09/2020 10:45 am
Haha true
Posted : 11/09/2020 10:58 am
Meow.
Don't think I'm likely for any this weekend sorry, I'm going to try for a quick early one tomorrow, builder is due at 8am so need to be finished by then if I plan on showering, and I really do.
With luck the weather Sunday should be conducive to getting out side.
Posted : 11/09/2020 11:01 am
 DrP
Just ridden up the Alpe ( still in the saddle actually)... knocked 4min off my PB... think it's a combo of new frame/wheels/2kg lighter, but also got an SUPER new fan and just cruising up at 260w is waaaay more comfortable.
Better heat loss ability =better power production..
Anyway... can't ride zwift this weekend... got the kids and gonna take the lad out on the e bike, with me dragging a tag-along!
I should stick the tag-along behind HIM! But he'll topple over!
Have fun!
DrP
Posted : 11/09/2020 1:45 pm
Mega Pretzel ticked off, one stop at 35 miles for 12 mins.
After 10 miles I did think gone wrong way it didn’t seem to match Zwift insider, kept going and then it did seem to hit the right points and it was an nice ride, turned out all good.
Bar a mental wobble at 52 miles where I was rationalising in mind if could finish it, convinced I could, head down to the end.
Four different Spotify playlists helped.
Posted : 11/09/2020 2:21 pm
 DrP
Bravo!
DrP
Posted : 11/09/2020 2:23 pm
That's crazy talk right there.
Posted : 11/09/2020 2:24 pm
Good effort forge. Onto the mega pretzel next.
Anything works for me over the weekend oop north. Got a covid test for my son at 4 today so will be isolated inside waiting for the results to come through! Fingers crossed it is negative and just a back to school bug.
Posted : 11/09/2020 2:36 pm
Well done DrP and Forge, those are some big rides for a Friday.
Right not much response so I'm just going to put an invite out, we are going flatish (only 400m over 60km) French route on Sunday. Join if you can, cancel if you can't!
Have a good one all.
Posted : 11/09/2020 2:40 pm
I'll make a late call for Sunday, not sure which day I'm doing proper riding this weekend. And I need to get up the alpe whilst I appear to have climbing legs.
Remember that Tire gives you the extra bonus climb before it starts too. It's the route that keeps on giving.
Posted : 11/09/2020 2:53 pm
Page 35 / 63
