Zeb/Lyrik Air Sprin...
[Closed] Zeb/Lyrik Air Springs - common parts?
Anyone know if the shaft for a Zeb Air spring is the same as a Lyrik?
I have a spare 170mm Lyrik spring - could I take the 160mm spring out of a Zeb, swap the 38mm bits with the 35mm bits and end up with a 170mm Zeb spring and a 160mm Lyrik spring?
Posted : 31/03/2021 12:58 pm
The air piston is riveted on to the air shaft.
Posted : 31/03/2021 1:39 pm
Hmm - that makes is more than a bit tricky. It'l be a new spring then.
Posted : 31/03/2021 3:48 pm
