I've demo'ed a number of bikes and settled on the Yeti SB66. Discussed with the bike shop and have gone for 3x10 set up. I can't find much on the Yeti site to see whether the 3x10 or 2x10 set up is preferred. Most but not all the builds on the Yeti site are 3x10 and the LBS say that as I have mainly ridden a 3x10 set up to stay with that. The only 2x10 setup was on a Whyte 146 before I sent it back in a hissy fit.
Is there any benefit going 2x10 or should I stay 3x10? Would I miss the upper range of 3x10 set up?
Don't run a SB66, I own an ASR5A, but have you asked the Yetifan forum? Loads of guys with the lovely SB66 on there...
Hope that helps.
2x10 is plenty enough. I would say 3x10 is pointless on most bikes now, perhaps more so on bike like the SB66.
I run mine as a 1x10.
I run mine 2x9, and I think it's pretty much fine that way.
With a 36t cassette, a 24/26 chainring is going to get you up anything, as always, rider is limiting factor.
Top end, i 1x10, 32t ring, i dont hang about, yet to find the need for more gear off-road, spin out easily on road descents. A normal double will have a 36-40t chainring, more than enough, that's bigger than the likes of gwin on their dh bike.
Benefits of 2x10
.Less chainring to gauge your leg on
.Lighter
.Cleaner
.Less front shifts
.Better chainline
.Better q-factor
.Shorter mech
.Shorter chain
.Better chain management
.Better ground clearance
.The list goes on
3x10 is pretty pointless, especially a bike like the SB, which i see (i own one) as mini DH bike which just so happens to climb like a mountain goat. If you're planning on using it as an xc bike with safety suspension, get a shorter travel bike and fork out for skills coaching (not saying i've assumed this is your situation, just saying just in case since the sb66 confuses a lot of people).
I'm running 2x10 X9 on mine. Is spot on.
Cheers Dean - I'm planning on this being an AM/aggressive trail bike that can also cope with all day xc rides rather than a mini DH.
I must admit to it being my mid-life crisis purchase, rather than the usual sports car. So yes I'm sure that I will not get maximum use of the bike, but it will see riding at the likes of all the welsh trail centres including the uplift at Antor-Stinog (or however you spell it), 7 Staines, the Peak District, Cannock Chase etc. and even the likes of Sherewood Pines and Hicks Lodge.
2x10 seems to make sense in a 26/38 combo but I'm sure I saw somewhere that the suspension was designed around 32 teeth therefore the 2x10 combo was not optimal. But I can't find that artical now.
2x10 on my ASR5, would happily go 1x11 if I could afford it, never miss 3 on the front,.
nobody runs three rings anymore do they?
