Brake mount questio...
[Closed] Brake mount question...
[#4779913]
Can anyone tell me what type of brake mount I need for my bike please? They are hope M4 brakes with 180mm rotors. Thank you people 🙂
%5B/IMG%5D
Posted : 22/01/2013 12:16 am
That's a link to some lovely photos of some flowers. And children.
What kind of fork is it? What brakes?
Posted : 22/01/2013 12:21 am
Yea that link may be questionable. It's the E150 forks with hope m4 brakes and 180mm rotors. There are quite a few shims in between the caliper and mounts on the forks so I'm sure there must be some sort of adaptor that will do a proper job
Posted : 22/01/2013 12:24 am
Proper picture link 🙂
Posted : 22/01/2013 8:11 am
If you just want it to look neater with out all the little washers
A2z used to sell spacer tubes but not sure of the width
But you have fitted it correctly in that pic
Posted : 22/01/2013 8:14 am
Get some of these. http://www.wiggle.co.uk/avid-caliper-mounting-bracket-hardware-kit/
They will look neater and you will be able to adjust the caliper angle against the rotor. They're cheap too.
Posted : 22/01/2013 9:49 am
And won't fit as they're for post-post not IS-IS, and for Avid calipers which account for their extra thickness.
Posted : 22/01/2013 9:54 am
I meant just use the washers. Not the screws. The washers will fit.
Posted : 22/01/2013 10:00 am
