XX crank with XTR m...
[Closed] XX crank with XTR mech ?
[#4235689]
Ello,
Building a new bike which has full XX.
Few days back i discovered the XX front mech won't work with the frame as it's hard agaisn't a linkage.
Checked out all of Srams front mechs and they are the same design so they are out.
Will the latest XTR front mech work ?
Posted : 07/08/2012 6:10 pm
Definitely. "Offroading's mystery bike about which we have absolutely no information" is top of the list of compatible frames on Shimano.com.
Posted : 07/08/2012 6:22 pm
Im not concerned about frame compatible, which i know it will be.
It's will it work on an XX crank.
Posted : 07/08/2012 6:24 pm
The issue isn't the crank, it's the shifter. Not sure an XX shifter will work properly with a Shimano mech.
Posted : 07/08/2012 8:08 pm
 DanW
Front mechs from SRAM and Shimano use the same cable pull ratio, it's just the rear mechs that differ- was this your concern Njee?
As Njee says, no issue with the crank. No issue with anything else either
Posted : 07/08/2012 9:26 pm
Even on the 10 speed? Certainly don't know they don't, but SRAM tweaked the cable pull for XX, I don't know if Shimano did the same.
Posted : 07/08/2012 9:52 pm
