XTR Disc Brake leak...
[Closed] XTR Disc Brake leaking at lever (diaphragm part?)
Just went to bleed the brakes and the rear seems to squirt out a jet of oil out of the circular diaphragm bit next to the reservoir bleed screw, guessing this is some type of leak in the reservoir, can it be fixed, it's annoying as it seems to squirt out oil until the pressure is low enough that the lever gets squishy again and near the bar for operating.
Anyone had similar, is there a seal in there that needs to be replaced?
Posted : 02/07/2020 10:07 pm
Xtr has a 3 year warranty. How old are they?
Posted : 02/07/2020 10:30 pm
About a year and a bit, not original owner though
Posted : 02/07/2020 10:46 pm
