Will the older style levers run the newer style servo wave calipers ok or do they have to match?
Thinking about upgrading the mrs levers as have spotted a cheap set of integrated levers on the bay.
Posted : 23/08/2010 11:23 am
Yes they will be fine. The levers should come with hoses that are banjos at each end where as 775 and 975 calipers use the straight in fitting so you may need to buy a couple of the correct fittings.
Posted : 23/08/2010 11:32 am
It's not the callipers that are servowave it's the levers.
You can mix and match without problems though.
Posted : 23/08/2010 11:38 am
Ah, brilliant, thanks guys.
Posted : 23/08/2010 11:39 am
