XTR 11 speed query&...
[Closed] XTR 11 speed query's??
[#6774532]
thinking of up grading to 11 speed after my 3x9 kit has finally died after a trip to Afan on the weekend.....
I have got XTR M970 cranks can I put an XTR9000 11 speed ring on those cranks???? surley.... if not how do I get around this as I really do not want to replace the whole crankset?
direct mount rear mech will that fit on a cotic soda frame
how do ispec shifters differ from bar mountand how do they fit to your bars
any help on those little query's would be grand cheers all
Posted : 12/01/2015 8:44 pm
You should be able to stick a single ring on as long as you don't want smaller than 32t from cog. I could be wrong though.
Posted : 12/01/2015 8:47 pm
thanks mafiafish
does it have to be a shimano specific ring??
Posted : 12/01/2015 8:50 pm
No the new xtr ring won't fit as will be different BCD to your old cranks. As they will be 104bcd, you can use a raceface or similar narrow wide ring.
Ispec just means shifters can mount to brakes etc so still clamp to bars.
Posted : 12/01/2015 8:56 pm
ha sorry wiggles abit of a non techhead what does BCD mean so the hope narrow wide ring will be compatible with xtr 11speed??
thanks
Posted : 12/01/2015 9:01 pm
Bolt circle diameter, just means the four holes on the chainring will line up with the 4 on your cranks.
Pretty much all (including yours) shimano cranks are 104mm BCD, the new xtr cranks are 96mm so not interchangeable.
Posted : 12/01/2015 9:12 pm
thanks
Posted : 12/01/2015 9:31 pm
The 11spd XTR rear mechs come with the bit for non-direct mount frames… well mine did, so don't worry about that.
Agree with the others, grab a narrow/wide ring and off your go… easy.
(I got a Superstar one cheap, but the Hope are finished far better)
Posted : 13/01/2015 6:18 pm
 rob2
You can just get a 30t on an xtr970 chainset. Needs careful alignment though!
Posted : 13/01/2015 7:27 pm
