XT front mech - lum...
[Closed] XT front mech - lump of green plastic question
Hi
Just bought an XT front mech (OEM so somewhat lacking in instructions). In the pack was a green plastic thingy. Anyone know what this is for? I assume it's some kind of guide...?
Thanks
jdogg
Posted : 12/08/2011 1:56 pm
Um, your tagging appears to be very thorough.
Posted : 12/08/2011 1:59 pm
 bigG
Use it when setting up the mech for the first time, read the instructions it'll tell you how.
Then toss the green thing in your plastic recycling bin
Posted : 12/08/2011 2:00 pm
It holds the mech out so it makes it easier to set up the max limit without hurting your fingers!
Posted : 12/08/2011 2:02 pm
[url= http://cycle.shimano-eu.com/media/techdocs/content/cycle/SI/Deore-XT/SI_5KA0A/SI-5KA0A-003-Eng_v1_m56577569830765731.pdf ]instructions are availble online[/url]
HTH ๐Ÿ™‚
Posted : 12/08/2011 2:07 pm
nowt to do with max limit
Posted : 12/08/2011 2:08 pm
Used in combination with the flap of transparrent plastic film stuck on the side of the cage, it helps you mount the FD in the right position.
Posted : 12/08/2011 2:15 pm
Thanks thomthumb, the instructions were really helpful.
Turns out the green plastic thing is the Pro-Set alignment block. Nice.
Posted : 12/08/2011 2:22 pm
LOLs at the tags
Posted : 12/08/2011 2:28 pm
