XC Racing - Triple ...
[Closed] XC Racing - Triple or 2x9?
[#1796139]
I'm planning on having a go at xc racing next year and am just putting a race bike together to start training properly.
I've gone as light as I can reasonably afford - so Kinesis frame, SIDs, XT/XTR drivetrain, Mini Pros, AC hubs on Alpines, etc hopefully around the 20/21lb mark - but am wondering what people reckon is best chainset wise for the majority of races - a standard triple or a 2x9 set up?
I know the answer isn't going to be the deciding factor in whether I win or lose, but as I'm building the bike from scratch, I'm just interested in what people think is likely to serve me best.
FWIW, on my old 'xc/trail' HT, I ran 26/36 and found it fine for general trail riding...
Thanks in advance! MM
Posted : 13/07/2010 7:36 pm
i'm going to try something like 26/38 next - folk on here seem t have got on well with that.
Posted : 13/07/2010 7:38 pm
For my racing I'm going 1x10 with the new Shimano stuff arriving this month. Easily the lightest way to get most of your gear ratios with a 36t cassette.
Posted : 13/07/2010 7:42 pm
Im staying 3x9 at the moment ... I used to run 29:42 upfront but i like to ride in mtns too ... When i have 2 geared bikes ill try racing on 2 x 10 or 1 x 10
Posted : 13/07/2010 8:20 pm
Double all the way for me, 28/40 on 9 speed with an 11-34 or 28/42 with 11-36 10 speed, very similar, but spot on IMO.
Posted : 13/07/2010 9:15 pm
I am not the most physical of riders (think Ollie Beckinsale, but without the muscle 😕 ) but I race with a 29/42 Middleburn Duo set up with an 11/34 cassette without any trouble, and ride that bike on Dartmoor occasionally. Most of my racing is at Newnham, so maybe other courses have much fiercer climbs?
So I would say, yes 2x9 is the way to go if you have a lightish bike.
Posted : 13/07/2010 9:41 pm
Whatever works for you. The weight of a chainring will not matter a jot.
Posted : 13/07/2010 9:45 pm
I think you're missing the point - it's all about the look on the line. 😉
Posted : 13/07/2010 9:55 pm
 br
If I was buying new (ignoring the XT and XTR 3-ring chainsets already in my garage...) for XC, I'd be looking at a 2x9/10 setup, probably the XX.
Not strong/fit/stubborn enough for 1x9/10.
And while (lack of) weight counts, its more the ability to run the big ring across the cassette that interests me.
Posted : 13/07/2010 10:28 pm
I like 29/44 up front with a 12-27 cassette and Dura-Ace rear mech at the back.
Posted : 13/07/2010 11:04 pm
2x9. 11-32 and 26/38 Brilliant set up. If I built up a proper race bike, it would have that gearing, or maybe 26/40. 2x9 (or 2x10) is the way to go. Triples are as much use as quadruples. And you don't need to spend silly money on sram xx either. Oh, and don't use middleburn chainrings like in the picture. They're useless.
Posted : 13/07/2010 11:06 pm
footflaps likes pedalling really hard.
I can't push the pedals like him so I have gone for 40/26 on triple cranks with the 40T in the middle position.
That way I can use the cross-over gear so I effectively get an extra 2 low gears in the big ring compared with a triple setup.
I still haven't used top gear in a race this year so I might give a 38 a try.
Posted : 13/07/2010 11:22 pm
Thanks guys, that's given me food for thought - I reckon I'll try 2x9 to start with. I reckon 26/36 will probably be enough to get me started as I had a baby 3 months ago so it'll be a while before I get some proper power back, plus I have those rings in the garage! 🙂
I like the idea of less crossover, etc. so hopefully a double will work well - I can always up the rings as I get fitter/stronger.
Thanks again for the advice! MM
P.S Would most of you guys recommend an 11-32 or a 11-34 cassette for a double set up?
Cheers!
Posted : 14/07/2010 9:33 am
11-34 definitely, 11-32 is absolutely rubbish in comparison.
Posted : 14/07/2010 9:34 am
Cynic-al - are you mocking me or serious? Be nice, I can't tell!
Posted : 14/07/2010 9:40 am
Nail. Head. That's the big advantage, you just don't need to spend as much time shifting on the front and you don't get so much duplication of ratios.
Agree with 11-34, no reason to have an 11-32. Footflaps obviously lives somewhere flat or is actually Chris Hoy.
Thanks Njee!
And yes, I had worked out about the cross-over before - that's why I ran 2x9 on my trail bike, I was just wondering if people found that in racing the courses actually dictated the full range of gears. (I'm glad to hear most people feel they don't!)
26/26 x 11-34 it is then. That should certainly get me started anyway.
(Oh and btw, all good points on the tyre thread - I think I'll have to bow to your superior knowledge and experience despite what my mate says... shame he's already built the wheels with comps! Nevermind though eh, if I prove to be any good at this racing malarky I can always get them rebuilt with revs!)
Posted : 14/07/2010 9:49 am
 Sam
IME it's less about weight than having to shift less often on the front. I used to use a double since I had it on an old Cannondale and it worked very well. With much wider range cassettes available now it is only going to be better.
Posted : 14/07/2010 9:54 am
You will have a stiffer, and tougher set of wheels for using Comps, no doubt about it. I doubt you'd have had problems with Revs, but you certainly won't with Comps, I wouldn't worry!
A 12 tooth gap between rings will shift better, I'd consider 24/36 or 26/38 if I were you.
Posted : 14/07/2010 10:01 am
Yep, thanks Sam... I think Cynic-al got the wrong end of the stick as I didn't ask what would be best weight wise, I was only asking about what people found to work better.
Posted : 14/07/2010 10:02 am
Really? That's interesting! Will take your word for it and go for a 26 and 38 set up in that case.
Any recommendations on 38t chainrings?!
Yeah cheers re the wheels, I'm sure they'll do the job nicely - the rims look great!
Posted : 14/07/2010 10:05 am
TA Chinook are the best bet IMO, Starbike in Germany usually have decent stock, they can be a bit elusive over here.
I swapped over to a 40/28 setup on a triple (40 middle position) with a SLX 11-28 9 spd cassette a little while ago.
it's great, just enough gears for the downhill and roady sections and plenty of room left on the 28-28 for silly steep stuff.
seems to work here in Scotland, worked nicely for the Malverns too.
christ knows where you ride on 22-34.
Posted : 14/07/2010 10:34 am
Njee - every heard of single speeding - you don't need gears to go fast.
I have raced the NPS (stood next to you on the podium at Margam Park, the hilliest course), Southern XC, Midlands XC, riden all the 7 Stanes courses, Highlands courses, SXC courses all on 29/44 and 11-27 and my legs are very skinny.
Posted : 14/07/2010 10:41 am
It wasn't a bad thing, I just meant that that's a narrow spread of gears and one would have to be pretty strong to make it work, as you clearly are!
Of course SSers can get up plenty of stuff, but I would say for the average person, a wider cassette would be a better bet. It wasn't a personal dig, quite the opposite in fact.
Posted : 14/07/2010 10:51 am
i have 4 set ups on my mtbs....
1x9 xtr with 11-34 35 or 39 or 32 depending on the course...
2x9 with truvativ noir....ti rings 39-28
2x9 with cannondale si with ti rings 39-27
2x9 with si again....29-42
never struggle on anything....oh except 35t single round margam park...
Posted : 14/07/2010 11:07 am
I'd not have thought 36 up front would be enough to be honest. I often find myself well into the big ring on descents, but then I try and play to my strengths and hammer all the descents and flats (since I am so sh*t at climbing).
I used to have a Middleburn Duo 29/42 and that was pretty good - did all my riding on it actually and never really suffered. Having only two rings was good - because they were basically in between the usual three rings, I ended up shifting at the front much less often, which was nice when hammering.
Btw, sorry to break this to you footflaps, but singlespeeding is feasible and fun to some, but it's not efficient.
Posted : 14/07/2010 11:25 am
I think the thing I find with small cassettes is that it cancels out the advantage of the double, and the ability to use the whole cassette, you start (well I would!) needing to shift on the front far more, which for me, defeats the purpose of the object.
Posted : 14/07/2010 11:30 am
Of all the 29/44 Duos I have, the Middleburn is the worst performing - seems to offer a very poor change. The best was the Cannondale CX-2 which is no longer available, although I'm still eaking miles out of the two sets I've got left.
As for SS, never said it was efficient, although I was always tempted to enter an NPS on one just to see how I did, but never had the balls - would have been dropped like a stone on the line, but I reckon would have caught back up on the hills. Sadly I'm no longer fit enough to stay with the bunch on gears, let alone SS.
Posted : 14/07/2010 11:56 am
Not sure I'd use a Middleburn Duo again after having used XTR to be honest. Wasn't much lighter, and wasn't as stiff. Plus the spider's just a bit of alu so the rings aren't that stiff either resulting in not great shifting under power etc.
Posted : 14/07/2010 12:08 pm
People did, I'm struggling to think of names, but I know I've seen people do it.
Posted : 14/07/2010 12:13 pm
I use a triple up front with a 22 32 44 and a 9 speed on the back 11-25 which i think saves a bit of weight off the cassette compared to an xt or xtr cassette.Works for me.
Posted : 14/07/2010 12:19 pm
I assume with all this talk of 2x9 it still uses the std shifters? Just adjust the screws for Hi and Lo so that chain can't come off?
Never tried 2x9 etc but interested in trying.
I notice people saying 40 on middle ring location, is that the largest? Could a 44 go there?
Posted : 14/07/2010 1:13 pm
Aye, that saves more weight than just running a 2x9. I used to run a 12-27 cassette, but got annoyed with shifting on the front the whole time, sure that wastes significantly more time than the weight loss saves!
Cassettes are cheap though!
Posted : 14/07/2010 1:18 pm
 cp
yeah a 44 could go there... BUT you need to be careful on inner ring size, simply as shimano states a max diff between ring sizes for shifting/fit in the front mech - it's something like 12 or 15 teeth difference between rings
Posted : 14/07/2010 1:21 pm
I just don't really have the legs to use a 44 off road, find a smaller big ring a lot more usable.
Posted : 14/07/2010 1:27 pm
I've been using 2x9 for many years now, since like Sam, being introduced to 2x9 on an old Cannondale hardtale. Currently using a 42/30 with a 11-32. It's used for everything from general trail to XC to 24hr solo. A 36/26 seems very low to me, as you're talking of XC racing here. I'd struggle to spin that gear fast enough to keep up with pack on descents. But if you've already got 36/26 rings, and are a spinner rather than a pusher, then just give them a go and see...
Posted : 14/07/2010 2:27 pm
 cp
talk here has pretty much convinced me to give 2x9 a go on my xc racer resurrection- really like the concept of something like a 38 or 40 in the middle at the front, and a 26 inner ring, allowing full use of the cassette in the 38/40.
That's whatt I run, I like it.
Posted : 14/07/2010 2:33 pm
36/11 is still a pretty high gear, you're unlikely to be handicapped much! One tends not to be spinning on the descents at all, it's only really off the start that a higher gear can be of use! Some of the top World Cup guys are running single rings around that size, it's not really an issue.
Posted : 14/07/2010 2:35 pm
There are some courses where 36/11 might not be enough. I use the big ring a lot say at Margam, coming down the last hill. Of course, a lot of people just coast down there... 😉
Posted : 14/07/2010 2:36 pm
It's not sufficiently big that you'd spin out 36/11, it just isn't. Maybe the very top bit on the grass you'd be using it, same with the bottom bit, but not spinning it out.
You would spend a lot more time down at the bottom of the block with a smaller chain ring though, cassette would wear quicker.
Posted : 14/07/2010 2:43 pm
I said I use the big ring, not that I'd spin out 36/11 🙂 Part of it is that if you just lose the big ring, the chain line could well end up less than ideal in 36/11. Hence why I use the big ring.
I'm sure I've used 46/11 in races on downhills. Quite possibly on Margam. Definitely 46/12 or 46/13 tho.
Posted : 14/07/2010 2:48 pm
Do you still use a std front mech for 2x9?
Posted : 14/07/2010 3:11 pm
Fair enough, I used to use a 48, back in XTR M952 days. I used to go whole races without using it! No way I'd even consider a 46 myself.
Chain line should be alright in 36/11, like I say though I'd just be thinking about the cassette wear.
Posted : 14/07/2010 3:12 pm
