X9 mech and shimano...
[Closed] X9 mech and shimano hone jockey wheels
Do work! The bottom one fits a treat
£2.99 from crc
Posted : 01/05/2009 4:35 pm
Tried the top one as well?
Is it the top one that's supposed to be problematic?
Posted : 01/05/2009 4:45 pm
Thought x9 had an off-set guide wheel and the jockey was "normal" ?
Posted : 01/05/2009 4:53 pm
 jim
It's the bottom one, though it's really not too bad if you pop the seals off the bearing and put a more reasonable amount of grease in there.
Posted : 01/05/2009 5:10 pm
As i keep saying its the bushings that grind and seize NOT the bearing underneath
Posted : 01/05/2009 5:24 pm
Yes, it's the bottom one that always seizes up (and can be cured by disassembling, degreasing and re-greasing) - but I meant isn't the top one the awkward shape?
I assume that because people say the Tacx ones don't fit, but a replacement bottom wheel was fine on mine (haven;t needed to replace a top wheel yet on 3 mechs, touch wood).
Posted : 01/05/2009 5:40 pm
my solution was to get some SKF bearings with the double seal. No problems yet.
Posted : 01/05/2009 5:45 pm
BBB do replacement jockey wheel sets to fit X7/X9/X0. They're £9.99 a pair I've had one jockey seize up after a mind-bogglingly muddy ride around Bath in June a couple of years ago, when my (then) 32lb hardtail doubled in weight and the wheels stopped going round! A couple of days later I went to ride it and the gears just jumped. On dismantling them I found mud forced right behind the seals on one jockey. A quick soak in hot water and a scrubbing with a toothbrush got things moving, a squirt with a grease gun and then back on the bike. Still going round, like it has for six years.
Posted : 01/05/2009 7:14 pm
the top pulley has an eccentric bolt (i.e. it is mounted off centre) whereas the lower pully is same as shimano/BBB/Tacx etc.
strange that the X0 runs normal jockey wheels both with centre mounted bolts.
Posted : 02/05/2009 10:42 am
