As per title really? Are they tubeless compatible? I've been trying to get these sealed with very little success. Any point persisting or should I give up and go with something I know will work.
Yeh they go up tubeless. Very porous flimsy sidewalks though. Did you clean out the insides first with IPA or similar. Mine lasted a day before you could see threads on the rear sidewall.
They do go tubeless but it's not worth it. As DHdave write, the sidewalls are [u]very[/u] thin.
Sure the low weight is a big plus but it won't outlast the bitterness of going flat just as fast. I ran mine with Conti light tubes while I had them to save some weight.
As above, they are tubeless in theory but not in practice.
I exchanged mine for the Protection versions. Slightly heavier but the extra meat seems to be all in the sidewalls. They work well as tubeless.
The only models that Conti recommend for tubeless use are the Protection/Protection Apex models and the PureGrip models. Racesport models are not intended to be used tubeless.
Go Protection if you want Black Chili and tubeless compatibility.
