Press Fit BB (PF30)
[Closed] Press Fit BB (PF30)
 Haze
[#8264548]
Read quite a bit about installing these, must be a few on here who have done this so what does everyone do?
Thinking I just 'go in dry' with the cups first time...Loctite if I end up with a creaky BB.
Anyone use grease on the inside of the shell, or the outside of the cups?
Posted : 01/01/2017 8:26 pm
Loctite here
Posted : 01/01/2017 8:27 pm
Film of grease on mine no creaky BB for 18 months
Posted : 01/01/2017 8:32 pm
Loctite will help lubricate during installation plus there's a risk you'll damage the bearings try to knock them out again if they do start creaking.
They are supposed to be assembled with loctite.
 Haze
I read only to Loctite if they're a 'loose fit'
A little more info, I'm only changing the bearings...re-using the same cups, they came out dry which surprised me a little. Never had any creaking issues that were down to the cups.
Posted : 01/01/2017 8:57 pm
 Haze
Ok, pressed the cups in dry they were nice and snug.
Have Loctite 641 and primer on order just in case I need to whip them back out.
Posted : 02/01/2017 12:37 pm
If it is a carbon frame you should be using a light film of grease.
Posted : 02/01/2017 2:01 pm
