After a little searching I haven't found any info on this. Has anyone done it?
Thanks in advance.
There's a PDF on the X fusion website showing how it's done, but you'll also need a 170 spring if they're 160 at the moment.
Thanks, I can't seem to access it at work, but will check when I get home.
I remember something in the dim and distant past when looking up reviews of bikes - the Norco Range Killer B3 came with the (excellent) Vengeance, and someone found out how to make it 170mm from 160mm - here:
[url= http://forums.mtbr.com/27-5/long-er-travel-norco-range-killer-b-mod-850346.html ][/url]
Hope this helps.
They're adjustable internally & an easy job-I did mine the other way as they're a flipping long fork to start with.
The only part needed is a spring to match the travel, about £20 IIRC.
This is for an air fork, but the pdf's only show 100-130-160, not 170mm.
I will check that link thank you bedfordrd.
Found the link, that looks even easier! 🙂
