anyone find they need to run a fair bit less air that the guide ? I have read that they need a good 15 hrs plus riding out the box for the seals to free up a bit. Mine say they should be at 85 PSI for my kitted up weight, but I let a fair bit out them last night, after second ride at that pressure. Have them at about 70 now....
oh well ๐
Fitted some slants last week and similar, running them a lot lower than suggested. will pop a little more air in tonight and let scruff fiddle with the dials.
It's only ever a guideline, too many variables to be anything other than that. Don't worry about it - just have a play with your set, on your bike, with your setup and get them setup for you.
Si
thanks all
I'm running Velvet DLAs set to 80ish psi. The standard Velvets have a different pressure to DLAs however. I've a way to go before I reach the break-in threshold, but right now I'm finding them too 'divey' on anything less that 80. Generally good fork when set to 140mm travel though.
