Wrong depth foam ri...
[Closed] Wrong depth foam rings in a rockshox coil recon. Will it make any difference?
A while ago I got sent some foam rings for a rockshox recon coil u turn. They were the smaller yellow ones rather than the 10mm deep one in the fork. At the time I just cleaned and refitted the old foam rings as the seals were my more pressing concern.
Now I think I need to swap the foam rings, can I just fit the wrong ones, or will they move within the recess, fold and disintegrate?
Again, any advice gratefully accepted.
Posted : 11/05/2014 7:30 pm
I figured it out!
The kit I got from TF has the newer style oil seal then a thinner foam ring. Just finished and reassembled bike before dark and it pissed down.
Those oil seals seem like a good idea, but damn they are a tight fit. I ended up having to tap them in like a cartridge bearing, I don't think I've damaged the lip of the seal, though.
Time will tell, but the fork seems nice and plush.
Posted : 11/05/2014 9:39 pm
