Would you buy a 201...
[Closed] Would you buy a 2011 Reverb with no bleed kit?
Kinda tempted at CRC's price but don't want to fork out for a bleed kit.
If it does need bleeding on arrival can this be done without then kit?
And are they [i]really[/i] unreliable or is that the winging of the vocal minority.
Any thoughts welcome.
Posted : 29/01/2012 5:26 pm
Mine came without a bleed kit and needed bleeding. Any avid bleed kit will do - inc the cheap ones off eBay.
Id say go for it - they are mint
Posted : 29/01/2012 5:29 pm
Buy it. Mine has been 100% reliable since last April. Ridden twice / three times a week all winter.
As Willber says, any bleed kit will do, but I would be surprised if you need to bleed it unless you make a hash of shortening the hose. You may not need to shorten it anyway.
Posted : 29/01/2012 5:33 pm
I bought a bleed kit last week from "epicbleedsolutions " on ebay.
Reverb specific, oil,syringes and fittings. It was only 15 quid.
http://www.ebay.co.uk/sch/epicbleedsolutions/m.html?_trksid=p4340.l2562
I actually shortened the hose without bleeding when I got the seatpost originally and it was fine all summer.
Posted : 29/01/2012 5:34 pm
Just wanna point out that a reverb uses suspension fluid not dot fluid. So any bleed kit will do as long as it has the right fluid in it.
Posted : 29/01/2012 6:28 pm
Have none of your mates got reverbs with bleed kits
Posted : 29/01/2012 6:38 pm
Would you buy a Reverb
Nope
Posted : 29/01/2012 6:58 pm
If the cost of a bleed kit is less than the price difference than one with then its still cheaper
Posted : 29/01/2012 7:24 pm
Why don't you buy from Germany? £180 for end of 2011 model - so with threaded barb, and the insert into the post, and hydraulic brake hose not plastic.
Or £205 for the 2012 model, with.... a black collar 😉
[url] http://www.bike-discount.de/shop/misearch.html?serchform=directsend&query=reverb&x=0&y=0 [/url]
I've bought two from them, and arrived in two days. Better than CRC then 😉
Also, I didn't need the bleed kit - just make sure you push the barb in a little way before screwing it back into the hose or you'll lose some fluid.
They come with the right mounting for just bar mounted, and for MMX too.
Posted : 29/01/2012 7:47 pm
except you then have to post them back to Germany to get any warranty work done if it's needed, unless you have a very friendly lbs.
Posted : 29/01/2012 8:23 pm
Fisher Outdoor Leisure / SRAM UK will service them and deal with warranty issues from what I've heard.
Posted : 29/01/2012 8:31 pm
Bugger, that discount place does the 6" travel KS shock that I'd prefer, looks like I'm going to be even poorer...
Thanks all.
Posted : 30/01/2012 7:04 pm
Ive got 2 reverbs, The first one needed bleeding straight out the box, and needs bleeding monthly. The second one is like grease lightening and hasnt been bled yet (and ive used it 2 times per week, since september).
So by my reconning, its hit and miss wether you will need to bleed or not. 🙂
Posted : 30/01/2012 7:09 pm
If you have a avid brake bleed kit then no. The only difference is the fluid used and you can buy it separately.
Posted : 01/02/2012 1:22 pm
I'm not getting it with this bleeding all the time, mine has never been bled ,but a quick puff of air revs up the return a treat, put the full 250psi into it and you'll have a permanent choristers voice, it lifts off like Apollo 13 .
Posted : 01/02/2012 2:54 pm
