Would you be happy ...
[Closed] Would you be happy with a 130mm hub on a Surly Long Haul Trucker Frame?
I recently ordered a 'bespoke' touring bike and went for the Surly LHT. Now I discover that the builder of the bike has fitted the basic road bike Hope Hoops with a 130mm rear hub on Mavic Open Pro rims. My local bike dealer said this would be bad if the frame wasn't made of steel but that it's still a bit naughty because the LHT is for a 135mm MTB hub. He also said the Open Pro hoops are not suitable for proper long distance touring.
Can anybody offer a second opinion on this?
Thanks.
Posted : 24/10/2013 1:48 pm
[quote=tinminerider ]I recently ordered a 'bespoke' touring bike and went for the Surly LHT. Now I discover that the builder of the bike has fitted the basic road bike Hope Hoops with a 130mm rear hub on Mavic Open Pro rims. What are you using for brakes?
It's still bad.
That's complete bollocks.
Posted : 24/10/2013 1:52 pm
I've got Deore XT caliper brakes.
And thanks ... it's the hub that concerns me the most.
Posted : 24/10/2013 2:05 pm
the builder has fitted the wrong size wheel: whilst it might work; it is a best a bit of a bodge.
open pros are a good wheel but for touring with big tyres and big loads you might have specced something more robust.
Posted : 24/10/2013 2:09 pm
You could get the frame "cold set" to reduce the drop-out width. That would make future wheel changes a damn sight easier as you'll otherwise be trying to squeeze them together by 5mm every time.
FWIW, my Van Nicholas AMazon has 132.5mm drop-outs so it'll take either 130 or 135 ๐Ÿ™‚
Posted : 24/10/2013 2:10 pm
Yep - 130mm in 135mm dropouts is OK for a bodge, and I've done it for long periods (years in one case), but it's not what you should have on a new build.
Open Pros are really pretty bombproof rims. I can only see a problem with them if you're really heavily loading the bike with luggage. Are they 32 or 36 hole?
Posted : 24/10/2013 2:11 pm
scotroutes: Surly Cross Check does the 132.5mm thing too
Posted : 24/10/2013 2:12 pm
Open pro rims are bomb proof .Never bent one rattling round the 3 peaks cx under my 16 stone .5MM wont make much difference on a steel frame I have gone up to 130mm from 126mm on old frames without a problem
Posted : 24/10/2013 2:40 pm
Thanks everybody ... they are 32 hole rims Jonathan
Posted : 24/10/2013 3:44 pm
Probably still be fine to be honest, just more bomb proof if they had been 36 hole
Posted : 24/10/2013 3:57 pm
