I have the frame and forks (separately) and am throwing around the idea of a mongrel build with a 700c alfine wheelset as a commuter. Would this throw the steering geometry way off? I'm going to go do some measuring.
edit: this would make it like a Day One right?
Posted : 02/02/2014 7:32 pm
It is rated up to 120mm forks (which I have on mine) so you should be fine
Posted : 02/02/2014 7:44 pm
It will help drop the BB again after putting 700C on and the HA won't get too silly for a 700C bike, it'll be within CX-road bike geometry range. SA may get a bit steep though. Try it..
(assuming the CX forks are ~400mm that is)
Posted : 02/02/2014 7:45 pm
Cx fork not that long, 400mm?
Posted : 02/02/2014 7:46 pm
400mm a2c on fork, hadn't thought about SA, just steering geo. Ordered the wheel so project is go. This should be interesting.
Posted : 02/02/2014 8:38 pm
So what happened then?
Posted : 27/02/2014 10:35 pm
