Would I be able to ...
[Closed] Would I be able to mount a tektro caliper on an avid or hayes mount?
Hi everyone, I'm thinking of upgrading my disc brake (tektro auriga comp) rotors to 8 inch from 7 but I'm wondering if the tektro caliper would fit to an avid/Hayes mount. Thanks for your help
Posted : 15/01/2012 12:27 am
 OCB
In principle, [modern] calipers will fit suitable brackets from anyone else. I've certainly got a mix of stuff on mine.
Unusual I know, but sizing standards do seem to be adhered to with brakes.
In practice however, you'll maybe/probably end up trying different things to get it to work, but you can use pretty much any manufacturers bracket/adapter to get you there. The actual size of the caliper might limit what you can do, but going upwards should be [more] doable.
Assuming you are using a 'post-to-tab' mount (depending on your forks), Hope's HS20 bracket is a quick way of gaining an extra 20mm tab-to-tab (or just swap the whole bracket for one with an extra 20mm I guess).
A decent LBS will be good for this kinda thing.
Posted : 15/01/2012 11:05 am
Oh thanks for that OCB, I'm currently using is to post mount from tektro that came stock on my bike, so does that mean that if I upgrade my rotor to 8 inch and get a Hayes is to post mount for 203mm rotors I would be able to mount my tektro caliper on it?
Posted : 16/01/2012 3:18 pm
 OCB
Sorry, I missed your reply ...
In theory (!) that sounds ok, but you'll need to be clear on the [i]actual[/i] rotor size, and get the bracket to fit that size. You'll find what get called "8 inch rotors" could be 200mm [i]or[/i] 203mm, and tho' not much difference, it's enough to be a PITA.
If you want to check, the standard is 74mm for the post mountings (ie between the posts measured C-T-C) and 51mm for the tab mountings. If that all checks out, it's [i]usually[/i] just a case of getting the bracket with the right stand-off spacing, ie 180mm, 183mm, 200mm 203mm ... (as long as they are all the same 'standard', you are really only buying the manufacturers etching / logo at this point).
That said, some (mostly DH) forks are specific, I think Boxxers may have their own mounting, and some early suspension forks had a different standard (but that was 10+ years ago maybe now).
Not directly relevant, but maybe something else to have in mind of you read stuff online that brings it up, but some calipers have a rotor size constraint if you swap them front to back (and back to front of course). It's not necessarily a problem, just needs thinking through.
Take this at face value, but I think I read somewhere that there are maybe 31 different flavors of mounting bracket!
Posted : 21/01/2012 11:25 am
Thank you for your amazing advice OCB! that makes so much sense now, sorry that I missed your reply. ๐Ÿ™
Posted : 22/08/2012 11:18 pm
