would a 2.125 tube ...
[Closed] would a 2.125 tube be ok in a 3" tyre
Or would it be slack as a bag of knackers , or lose tyre width. Ta
Posted : 10/12/2010 10:56 am
Reading the set up page of the Salsa website last night they said you could get away with a normal 26" inner tube in a Surly 3.7 tyre so i suspect you will be ok (i was reading about the Mukluk Snowbike). The tube will stretch thinner though so punctures may be more common.
Posted : 10/12/2010 10:59 am
Coolio thanks 😉
Posted : 10/12/2010 11:07 am
The actual article......
Tubes:
Surly offers large volume tubes or you can try cutting weight by stretching your luck (pun intended) by using either a normal-size 26” or 29” tubes. We’ve noticed that a 29’er tube creates less of a ‘divot’ in the tire casing, than a 26” tube. The 29’er tube essentially is expanding inward toward the rim, while the 26” tube is inflating outward toward the tire.
Posted : 10/12/2010 11:15 am
Why dont you fit a 2.5"-2.7" tube ?
Posted : 10/12/2010 11:19 am
Just I have some 2.125 tubes at home and to get bigger means a trip to town . Thanks
Posted : 10/12/2010 11:31 am
You can do it, but sometimes it will just pop inexplicably, usually somewhere near the valve.
Same is true with using normal 700c tubes in 29x2.6 tyres.
Schwalbe make large volume lightweight tubes at least in 29" size (29x2.6 tube which only weighs < 170g or something), they might also do a 26" one?
Joe
Posted : 10/12/2010 11:38 am
Oh I'm not bothered about the weight I just want it not to pop or tear just can't be bothered going into Leeds with the two little ones 😉
Posted : 10/12/2010 11:41 am
have a bike through scholes to barwick and try the little bike shop opposite the fish & chip shop
Posted : 10/12/2010 12:47 pm
