Worth straightening...
Worth straightening out or replacing?
A bent (warped) rotor which is thinner than Magura calipers want as is a different brand.
It does rub on off significantly which is a REAL PITA.
Not just a small bend as is noticeable in feel and noise.
Just putting this out there to those who have been successful in straightening a rotor.
Is it ok to leave rotor fitted to wheel in order to bend back in place and with what specifically?
Posted : 22/08/2022 11:39 am
Yeah just leave it on the bike, work our which part needs bent, spin the wheel so your bending it far away from the caliper, push/pull as required until happy. If it sticks grand, if it warps again then you know its new rotor time
Posted : 22/08/2022 11:42 am
I bend mine back in to shape with an adhustable spanner, seems to work really well
Posted : 22/08/2022 11:44 am
I use the PArk Tool version, but essentially it's just something that can be a bit thicker than the rotor itself.
Posted : 22/08/2022 11:46 am
Thanks guys 👍
Posted : 22/08/2022 2:15 pm
