Worst Review In A W...
Worst Review In A While - Electronic Inflators
https://www.bikeradar.com/features/opinion/electric-inflators-are-the-future
Gushing.
Most useful part, the comments?
EDIT: Or did I just get caught by click bait 🙈
Apologies and summary of article 2 posts below.
Posted : 20/03/2025 7:14 am
Apart from improving Bikeradar “clicks” what does it say?
Posted : 20/03/2025 7:19 am
^ realised I'd fallen for it at the same time.
NOTHING of value other than they are getting better.
Comments point out they are still much heavier than a mini pump and the risk, after non-use for many months when using tubeless means the likelihood of a flattened battery due to not charging regularly, is high/very high.
Posted : 20/03/2025 7:25 am
J-R and wheelsonfire1 reacted
Personally speaking, I think they're an absolute gimmick. I would always prefer to have a manual pump as I know it's always going to work. Unless the seals have failed, I can pump up one tire or I can pump up a hundred tires so long as I have the energy.
I have the one-up component EDC pump which also contains my multi-tool, tire levers, quick links and my wiggly worm tool.
Electric pumps sound good but there's just too much to go wrong and they're relatively bulky for what you get
Posted : 20/03/2025 7:43 am
BoardinBob, Earl_Grey, fasthaggis and 4 people reacted
"E"flators, shurely?
Posted : 20/03/2025 8:21 am
nickingsley reacted
Yeah, I'll stick with my accoustic inflator, ta
Posted : 20/03/2025 8:24 am
joebristol, leffeboy, Mark and 4 people reacted
I like the idea for fatbiking in the winter, where I want to remove or add a bit of pressure multiple times on a ride due to to temperature and snow variations, but I would always still carry a pump anyway for safety.
Will likely wait until battery life and reliability get good enough to be worth the cost and weight though.
Posted : 20/03/2025 8:26 am
I think they're fine. I have one for balls (of the rugby sort) which is small and accurate. I just wish it was a similar price for a bike one. This cost only £20 is palm sized, has 4 ball type presets as well as a +/- to set a desired pressure on the LCD display... I mean it will go to 20PSI so its ok for the low pressure lovers out there, but why is it 3x more or more to get a 'bike' one?
Also to be fair to BikeRadar I think the title makes it clear its an opinion piece not a review.
Posted : 20/03/2025 8:29 am
Used mine on Sunday - blew my mates 2.6 tyre up from flat to 25psi twice and flat to 30psi once (don't ask) in a matter of seconds. No idea how much battery is left, but everyone was very impressed and wanted one.
Downside - I bought the wrong one really and it's a bulky lump. Fine if using a bag, but it's not pocketable
Posted : 20/03/2025 8:34 am
The electric pump would naturally be flat by the time I needed it. I get so few flats it's not worth bothering about, and I run tubes on all my bikes (shock horror).
Posted : 20/03/2025 8:59 am
milan b. and boriselbrus reacted
I have one and prefer it. I rarely use the track pump or mini pump.
For short rides i have a co2. For longer rides, I stick the electric one in the backpack. It stays charged as I've usually used it to check the tyres before i leave (it has a digital pressure guage).
In my experience, a mini pump sits unused until you fish it out of your bag, or get it off the frame, and it's either seized up, covered in muck, or various parts have dismantled in the bag (mountain morph).
Posted : 20/03/2025 9:05 am
This thread is a useful reminder for me to check my various pumps again. Thanks OP.
Posted : 20/03/2025 9:08 am
J-R reacted
 mert
Mine are all still A-OK.
The only ones that are *really* worth getting are one of the proper minikompressors you see in the pits at races.
Posted : 20/03/2025 9:28 am
Just the headline was enough for to not read it...the problem with e-pumps and CO2 inflators is also environmental, because they use more resources to produce (lithium battery and charging vs. one-off, smaller resource hit with a normal pump). Are CO2 canisters still single use?
The main issue is that it's a ridiculous solution to a problem already solved. You have another battery to charge and therefore rely on, turning what was once a manual machine into one reliant on electricity, be that the pump or shifting (however small the amount of time between charges, it still is). That's not a road I want to go down. Partly my being a luddite, but also for real practical reasons. There is such a general and ridiculous drive to make so much stuff unnecessarily electric or connected to the internet, or phones. So much of it is just pointless consumerism and to entice a purchase. Oh, and the last time a manual pump failed? Not in the past 15 years for me, and it's not hard to keep it clean or check it once in a while.
(maybe this post will appear within the next 24 hours?)
Posted : 20/03/2025 9:52 am
twistedpencil, kimbers, Duggan and 9 people reacted
I'm sure this has all been said before but I have mine along for the ride as well as a mini pump, but instead of co2 for those situations where you want to inflate quickly with minimal faff, i.e. it's lashing down or I'm at the side of a road. I've got the small rockbros one without a gauge. Its smaller and a similar weight to the equivalent co2 carts I'd otherwise have with me.
Posted : 20/03/2025 10:10 am
I still think they're a massive extravagance for 95% of folk, at what point in capitalism do we say we should be reserving finite and fairly critical elements like copper, lithium etc. for more important things than lazy cyclists who don't like using hand pumps occasionally 🤣 (see also: e-bikes, electric gears etc. etc.).
And yes, there's always exceptions for whom they're a game changer, and yes, I'm probably equally guilty carrying around a GoPro, a Garmin and a smartphone on every ride, but I'm thinking more carefully about future purchases.
Posted : 20/03/2025 10:14 am
endoverend, kimbers, thenorthwind and 2 people reacted
Imagine if you only had electronic inflators, and then someone invented a manual pump that fit in your hip pack or attached to your frame - and didn't even need charging!
Posted : 20/03/2025 10:18 am
cakefacesmallblock, jpal, J-R and 3 people reacted
Everything is a finite resource, and 99% of MTB'ng is cycling around in a circle, so I'm pretty sure that won't make the cut of essential use of resources.
Posted : 20/03/2025 10:24 am
andywp reacted
Posted by: HoratioHufnagel
Totally, and it's the major failing in my 'old man shouting at clouds' logic up above, but still, where is the line drawn? I'm pretty sure if we already have a good solution to inflating tyres, or shifting gears, or pedalling up hills, does it really merit an improved solution that also happens to compete for resource with more critical things like EV batteries and heat pumps?
It's an impossible argument and I shouldn't have started it, but the increased gadget-ification of cycling just seems glaringly silly at times.
Posted : 20/03/2025 10:40 am
Everyone is in such a rush - I spent many a happy moment sat on a hillside repairing a puncture while having a natter with mates and taking in the view!
Posted : 20/03/2025 10:50 am
leffeboy and oldnick reacted
Absolutely love mine.
Been just as reliable as any other pump I’ve owned so far. Track pump never gets used now.
Its smaller and lighter than most mechanical pumps too
Posted : 20/03/2025 11:04 am
cooie reacted
Posted by: the-muffin-man
Kind of loses it's appeal when its 3 degrees and pissing it down
Posted : 20/03/2025 12:17 pm
TedC, jimmy748, doomanic and 1 people reacted
I’m going to keep using my Lwzyne pumps, they’re almost completely made out of metal and recyclable when the time comes (apart from the hose and seals) and the battery has never run out or needed charging. I’m trying to minimise my disposable parts in biking nowadays (it’s why I stopped using Shimano brakes, they’re almost completely don't supply spares and rebuild kits). I do have an ebike (on order) and accept some batteries are needed (but it won’t stop me riding my normal bike).  But most of these pumps are just rebadged generic stuff coming out of a factory in China and when they brake they’ll just be landfill with all of the disposable vapes.
Posted : 20/03/2025 2:35 pm
I’ve never used one, but the idea does appeal if they’re small enough. However, I don’t think I would ever leave a manual mini pump behind.
I’ve also never used a CO2 bottle. So really, I’d consider it in place of one of those. Or maybe an electric pump for short rides only. But for bigger rides, I’m going to stick with my manual pump.
Posted : 20/03/2025 3:07 pm
I love the idea, but like anything with (probably) cheap lipos in I don't trust it to still work and charge properly in 2 years.
Posted : 20/03/2025 3:14 pm
ALL the light weight Lezyne screw on pumps I have are b*****s for removing the valve core. Soooo frustrating, the only people amused have been my mates rolling around in the grass killing themselves laughing.
I now carry a Bontrager Mini Charger, sadly no longer available but brilliant, powerful and quick ... though not the lightest 🤷‍♂️
The consistency of a good quality pressure gauge on a battery/electronic inflator is something I am interested in.
Posted : 20/03/2025 7:59 pm
Both of my Topeak floor pumps have failed, nothing to do with keeping them clean or checked. just because it's mechanical or manual doesn't mean it won't ever break.
Posted : 21/03/2025 7:27 am
J-R reacted
I never give the inflation part* of the repair a second thought,however,getting the tight bar steward tyres on and off my road bike is a whole different level of pain and apprehension. If there was an electronic version of the tyre slider,I would throw money at it.
* I have never had a pump fail and end up using my old, unused Co2 in the shed
Posted : 21/03/2025 8:15 am
 mert
That was the last memorable puncture i had. Coming back over the tops on the road bikes with my ex after an early spring ride. Only about 30 minutes from home, and in the 15 minutes we were stopped it started raining, then started to freeze and turned to sleet. Which started to freeze on to anything metal.
Thankfully we were overdressed for the starting conditions, so we only got really really cold, instead of frostbite.
Buy cheap(ly made) buy twice?
My Original 1980s silca lasted decades, the SKS Rennkompressors i bought to replace it are also both over a decade old and get used heavily.
Posted : 21/03/2025 8:44 am
See for my road/gravel bike I'm debating the idea of buying a cheapy E-pump to compliment a frustrating but usable mini mini-pump or going the other way and buying a nice full sized frame pump (I can't justify a Silca though).
But it's got me thinking, is there a bit of a gap in e-pump market for a higher capacity (battery) one, using the "Form Factor" of a Frame pump (~500-560mm long) absolutely stuffed full of 18650 cells (OK four or five) so you've got like 10-12000 mAh rather than the 2600 mAh of a 'cycplus' or similar that apparently does 4 or 5 ish tyres (depending on size and pressure), so you'd have a much better chance of it delivering enough air on demand.
It would of course be very expensive and a manual pump would still probably be more reliable (and much lighter)...
Posted : 21/03/2025 4:38 pm
One powered by a 2A/12V take off from an ebike lighting circuit would be good. It wouldn't need a battery, therefore wouldn't be flat.
Posted : 22/03/2025 5:39 pm
So did you drop 5 them then? .....because short of an oring on the head that needs a light lubricant and decade esque replacement......what actually broke if it wasn't a maintenance issue ?
Posted : 22/03/2025 5:59 pm
@julians
Can't see nowt there
Posted : 22/03/2025 6:02 pm
Hmm, not sure if that's a forum problem or an amazon problem, try this
https://amzn.eu/d/jbGkEUH
Posted : 22/03/2025 6:06 pm
nickingsley reacted
In the interests of balance....and self promotion
This surprised me
More of a conclusion in this one though (unbiased review, no affiliate link or paid review as I suspect the bike radar video is)
Posted : 22/03/2025 6:12 pm
nickingsley reacted
I've got a cyplus one that the better half bought me for Christmas. Did the job nicely when I had a bit of a flat at the weekend. Yeah, I'm lazy for not using my topeak mountain morph that was in my backpack as well but, hey, it made pumping up a tyre much less unpleasant.
Posted : 22/03/2025 7:48 pm
@rOcKeTdOg
Think you fairly captured the key points wrt battery inflators vs manual pump.
Posted : 22/03/2025 8:23 pm
Cheers 👍
Posted : 22/03/2025 10:17 pm
Don't replace a pump for me but get used on rides where I would otherwise use CO2. Worth noting as well that when using it with tubeless tyres it's often more of just a top-up than a full inflation so I expect I'd get waaaay more than the three-and-a-bit inflations that I got trying it on road tubes. Being able to set the correct pressure after fixing a puncture is underrated too - no need for toot-toot-toot-squeeze-squeeze repeats.
Posted : 23/03/2025 12:38 am
If the gauge is accurate, which I doubt
Posted : 23/03/2025 6:49 pm
The gauge on the inflator I linked to reads the same as the topeak d2x digital gauge Ihave.
Posted : 23/03/2025 6:57 pm
@rOcKeTdOg
Maybe that needs addressing in a review 😉
Posted : 23/03/2025 7:49 pm
I did 👍
This is the thing though, non of these are calibrated or validated. So the old squeeze with the fingers, ride and see how it feels, add/subtract air method works too
Posted : 24/03/2025 1:47 am
I've seen them used in roadie rides, and they're great at what they do.  But I'm not convinced everyone should go out and buy one.  Unless you're in a mad rush on solo rides there's not so much need. And on a group ride it's the sort of gadget that someone will pull out of their pocket to save the group some time/energy, it doesn't need 20 of them.  I'd happily make the same argument for frame pumps and other tools. Surely better if someone brings one decent pump on the ride than 10 crap mini-pumps, or a few decent tools spread around the group leaving more pocket space for extra layers and some food.  95% of the time the ride would have a better average speed if people fueled better, not if they brought a 10th multitool that'll not get used.
+1
But maybe more useful for roadies still using tubes. Tubeless on MTB's solved the same problem two decades ago.
That said ...... I still carry a frame pump on winter road rides, it's just the right tool for the job. And in summer a decent mini-pump is decent enough for the task, especially as tyres have got bigger and pressures lower so you need less oomph towards the end even if it still needs 500 strokes.
True-ish, but what's wrong then with being able to set your tyre pressure consistently at the start of every ride or after every puncture rather than having to faff?
My (cheap) trackpump is woefully inaccurate, it over reads by between 15 and 30%.  I could ride around faffing with a mini pump to get the bike to feel right, or just stick the SKS airchecker* on it and set it exactly how I like.
*not a recommendation, the oxford one is better
Yes ..... but my flextail camping bed pump weighs less than one of those schnozzle drybag pumps, and is probably more recyclable because you can't recycle laminated cloths.
Posted : 26/03/2025 10:36 am
Posted : 25/12/2025 4:02 pm
I had a slow puncture in a slime tube on Monday went from 40psi to flat every 30 mins,  the inflatatior meant finishing the ride without needing to change the to my spare tube.   I had a power pack to keep it fully charged.
Posted : 25/12/2025 4:15 pm
Would a normal lump not work?
Posted : 25/12/2025 6:13 pm
Pump not lump
Posted : 25/12/2025 6:19 pm
Miles easier with the inflator.   I'd put my spare tube in if I had to pump it up manually as I had to do it about 5 times with the inflator it was no hassle to keep the slime tube going an keep the spare spare
Don't actually understand how it's easier to use a pump.or a pump?
Posted : 25/12/2025 6:28 pm
you can't have a coffee and snack whilst using a pump.  30 seconds rather than several minutes. no snapping off the valve you don't have to believe me it was just miles easier./
Posted : 25/12/2025 6:51 pm
My nano fumpa is great. Tiny and works to inflate 35 psi per push and you get about six goes. I like CO2 but was worried about the sealant in my tubeless road tyres. I’ve also never had an issue with ANY Topeak mini pump and have one behind the water bottle on my best bikes. But I’ve barely used them as CO2 never fails with tubes and fumpa is great for top ups.
Only one inflator will go to the 160-200 psi for track tubs. It’s on my list but out of stock.
Posted : 27/12/2025 10:32 am
reduce reuse recycle
all these things are is another piece of capitalist tat to make you consume more and create more profits
ever thought you've been had?
Posted : 27/12/2025 10:52 am
Bruce reacted
At £150 like the first ones were I could perhaps agree with you. But at less than £50 to help get me out of a fix on a freezing cold moor then at my age I will use one. I’ll ditch the CO2 so that’s an environmental win.
I don’t have an electric bike though as I see that as unnecessary and haven’t flown since 2010, choosing to see the world through my wide screen capitalist television and my subversive left wing books!
TRUFLO for the win, supports a UK distributor and can be purchased in your local bike shop.
Posted : 27/12/2025 11:24 am
I think people should read the thread before adding comments, they're missing @thols2 's thread resurrecting contribution 😂
I still stand by my previous post though, they serve a useful purpose as one of those things that's great if one person in the group has, but a pointless extravagance for the other 90%. Likewise CO2.  A small pump and a tube (check it's not perished) is always going to be the last resort, so you may as well take it.  I can't actually remember the last time I had a MTB tubeless failure that required it.
Although I have since bought a 'big' one from Lidl that's largely replaced the track pump.  The workshop compressor does tubeless, the Crivit one does cars, motorbike, checking pressures etc.  I even hacked and bodged the head off the old track pump onto it so there was no faffing with presta addapters.
How slow is your electric pump?
Even with my least practical roadie pump the size of a sharpie and modern 32c tyres I can get the wheel out, find the thorn, swap or patch the tube, and be on the road again in about 4 minutes.
Posted : 28/12/2025 2:40 pm
Not really, the mini compressors work well, can replace a track pump and C02.
I even used mine to pop the pistons out of a set of Shimano brakes, to rebuild the calliper the other day.
Posted : 28/12/2025 5:02 pm
Can they seat tubeless mountain bike tyres?
Posted : 28/12/2025 5:47 pm
Posted by: Kramer
The one I have can, yes
Posted : 28/12/2025 6:16 pm
They are handy even for home based tasks. I had noticed today while in the garage that the good road bike tyres were quite soft,  being tubeless and not having moved for a month or so. That bike sits behind some others and it would have been a 5 plus minute faff to move stuff to attach the track pump and blow up. It took less than 2 minutes  all in to pop them both up from 15 to 65 psi with the wee Cycleplus AS2Pro, which lives on top of the drawers out there.
The pump had topped up some gravel tyres the other day, and today’s efforts took it down to 1 of 3 bars.
Posted : 28/12/2025 8:05 pm
Posted by: Kramer
Which model is that?
Posted : 29/12/2025 3:55 pm
Fumpa supply user replaceable batteries and service kits. Which is why I bought from them. I’ve never reused a CO2 cartridge. And a mini pump would struggle to seat a bead on a tubeless road tyre.
Posted : 29/12/2025 4:35 pm
tjagain reacted
Ah that's really good actually, big plus mark for Fumpa
Posted : 31/12/2025 4:49 pm
Serial mini pump killer does a video on pump lifespan.
Posted : 31/12/2025 6:32 pm
Posted by: Kramer
Posted by: Kramer
Cycplus AS2 Pro Max
Posted : 01/01/2026 2:14 pm
@Brainflex thank you for that videolink,  it was very informative
Posted : 01/01/2026 6:58 pm
Brainflex reacted
Feels like its an advertorial disguised as a review. Decent "normal" mini pumps do exist (although I'll caveat it with the fact I've had some dire ones - Topeak I'm looking at you). My little Leyzne (sp?) is excellent, didn't cost much, is tiny and lightweight and fits in my Dakine hot laps fanny pack (which I used for a lot of my riding) with ease whereas one of the leccy ones wouldn't do.
Comments about pumps "dying" at the bottom of a camelback etc - lol. What is your little electric Chinese box of magic going to do at the bottom of a camelback for a similar period of time assuming it still has charge left in it?
Feels like another way to make riding a bike that little bit more complicated.
Posted : 02/01/2026 9:19 am
 RicB
Would anyone with one of the Truflo pumps be kind enough to measure the dimensions?
I was planing to buy the AS2 Ultra with some Amazon vouchers but the Truflo is half the price.
I think this tech is positive. I’ll use it for a quick pressure check/top-up pre ride as it saves faffing with separate track pump and pressure gauge. Plus obviously using if I get a puncture; maybe I’m weedy but I find using a mini pump to get to 65psi is really hard work, and CO2 carts can easily freeze-crack a TPU tube
Posted : 02/01/2026 10:25 am
Posted by: Brainflex
Christ he is dull, I got two minutes in, and thats enough. What was the outcome?
Posted : 02/01/2026 11:02 am
@RicB I’ve just been down to the workshop in my jamas and measured mine, 70mm x 32 x 44. Add another 14mm to the 44 if you leave the adapter screwed in as I do. I carry the flexible tube also as that would enable me to help out any Schraeder users.
I’m not a great user of electronic aids but the TRUFLO pump with my limited fatbike testing is superb! It has the advantage that you can buy from a physical shop too.
Posted : 02/01/2026 12:18 pm
@alanl the outcome of the in depth testing was more nuanced than some reviews that state “this is good, this is $hit”.
I enjoyed it as it tested a lot of pumps and tried to solve the problem that some of us have with limited life, disposable electronics.
You’ll just have to watch it or see whether AI will read it for you!
Posted : 02/01/2026 12:24 pm
 RicB
Posted by: wheelsonfire1
Legend- thank you!
Posted : 02/01/2026 3:38 pm
Yeah Click bait, but they kind of cover a more interesting topic in the first line for me:
Back when bikes all shared a double-diamond frame with a horizontal top tube, the frame-fit pump ruled.
Full-sized, Frame Pumps FTW (IMO), I use one on my Road/Gravel bike(s), everything else falls short on either the volume of air it moves or the probability of failure on demand. Looking like a dork is a secondary concern, I'm a tubby, middle-aged man in Lycra riding a childs toy (by most people's estimation), Bike aesthetics be damned...
I can also foresee, in the age of ever increasing "integration" and downtube storage hatches, more built-in solutions to air squirting. Either a full sized pump that sits up inside a profiled top tube out of view, but available when needed without ruining the looks of your Dandyhorse. I'm also sure I saw a frame once (prototype?) with an integrated air tank and air line, what could go wrong?
Perhaps full-sized manual pumps are one thing that the industry should be trying harder to accommodate on modern bikes. mini-motorised inflators have a place more as replacement to CO2, but they're still the less reliable timesaving supplemental option, where a manual pump will always have a higher probability of function on demand.
Mini leccy pumps are great, but they will always be constrained by Battery technology, even if I get one, you'll never convince me to bin the manual version.
Posted : 09/01/2026 12:06 pm
I agree, mostly.  I used to carry a full size frame pump, and it still lives on my commuter.  But these days modern tyres are so much more puncture proof (as long as you don't insist on being at the top of the BRR leader board) that it doesn't seem worthwhile.  My little topeak mini pump works well enough once every 1000miles or so.
The commuter does do the occasional winter ride though, and like an electric pump the frame pump is a great luxury to have within the group on a cold night, but overkill to expect everyone to carry one.
Posted : 09/01/2026 4:58 pm
To be honest, even pretty fast lightweight tires these days are quite good. I think I had one puncture in a couple of thousand miles on  tubed GP5000s. Similar since switching to the tubeless S version, but that sealed when I pulled the hawthorn out. I swear I got more punctures with gatorskins!
Posted : 10/01/2026 8:07 am
And my mum who is in her late 70s has an electric pump as she struggled with the hand strength for mini pumps (and apparently frame pumps would ruin the look of her bike!). She loves it. The noise really puts me off, but she is half deaf so doesn't notice!
So certainly great as an aid for the elderly and infirm. A bit like electric bikes then? 😛 (though she insists she doesn't need one of those as she hasn't given up on life yet!)
Posted : 10/01/2026 8:48 am
So Stainypants carries a power bank for the inflator...wow. That's proper commitment to pointless electrical evangelism, and using a proverbial sledgehammer to crack a nut. Spaffing natural resources for reasons of laziness. Mine some lithium to save a few of your precious minutes. Congratulations.
Every benefit rolled out in this thread seems to revolve around time and faff, proving it's just trying to justify convenience over anything else. The price of your convenience isn't truly measured in time though, is it? Electric pumps are just a sidestep from the wastefulness of CO2 inflators.
Posted : 10/01/2026 9:05 am
Posted by: faustus
Haven't you got some yoghurt to knit?
Posted : 10/01/2026 9:26 am
citizenlee reacted
Good substance free response. Touched a truth nerve clearly. Off to put some air in a tyre with the magic of bodily power alone.
Posted : 10/01/2026 9:38 am
Nah, unless you live in a mud hut, I can't be arsed with the sanctimonious waffle when someone uses a device that you choose not to but feel the need to chastise them about under the veil of saving the planet
Posted : 10/01/2026 9:46 am
