Worn narrow/wide ch...
[Closed] Worn narrow/wide chainrings - what are the signs?
Are there any symptoms of a worn n/w chainring?
And a follow-up question - are Superstar n/w rings notorious for not playing nicely with some makes of 10 speed chain? Had some issues with both SRAM and KNC chains 'gripping' on to the chainring and being pulled up and round the ring before springing off and causing the chain to skip (makes a horrible noise constantly too). Switched to a RaceFace n/w I had kicking around and the issue has gone.
Posted : 01/02/2016 3:03 pm
Mine (SRAM) sounds like i'm stirring gravel with a spanner at the moment as soon as i'm at either end of the cassette, it's horrible
Posted : 01/02/2016 3:05 pm
Sounds like chain suck - I had this last year. With a single chainring *all* the wear is on the one ring not spread across two or three.
You might start dropping the chain off more on stuff! Which my broken ribs can attest to from last year
Posted : 01/02/2016 3:23 pm
I started dropping chains
ime the narrow teeth start hooking even though the wide teeth look OK and the ring generally makes its presence known
also ime the bigger n/ws last longer than the smaller ones
Posted : 01/02/2016 3:26 pm
I started dropping chains when my RaceFace N/W was worn.
Fitted a top guide which stopped the problem but I quickly realised that I was treating the symptoms, rather than the cause.
Upon inspection, the narrow teeth had worn dangerously thin. I suspect I could have almost snapped them off by hand if I'd tried.
Posted : 01/02/2016 3:29 pm
scaled - Member
rocketman - Member
Sounds exactly like what I've been experiencing.
Opinions on whether I should take a punt on another Superstar ring (think they're down to 15 quid at the minute?), or shell out a bit more for something else?
Posted : 01/02/2016 4:13 pm
Have had/got 3x RF a Hope and an e13
They are all kind of expensive but for me at least the durability is acceptable. The e13 in particular feels very circular iykwim
Posted : 01/02/2016 4:18 pm
Works Components ones are cheap and running fine so far on two of my bikes
Posted : 01/02/2016 4:19 pm
Wolftooth make a stainless steel NW that's supposed to be a lot more durable than Alu ones. I've not tried it tho, my superstar one is still going strong
Posted : 01/02/2016 4:28 pm
Works last a lot better than superstar, they're about a fiver more, total bargain tbh.
Posted : 01/02/2016 4:36 pm
My Superstar N/W chain ring has been absolutely fine with a SRAM chain.
Posted : 01/02/2016 9:04 pm
Mine has been fine with a KMC
Posted : 01/02/2016 9:09 pm
Dropping chain is the sign I've had. If anything, that's the downside to them in that if you had a chain device it would go on for way longer, but the point of NW is to not need one. Well worth it though to keep a chain on without a noisy, mud clagging and chain suck/jam chain device.
p.s. Works Components I use on two bikes. Lasted two years on each, then got replaced. Aside from the dropping eventually, no issues at all and zero chain suck. KMC chains.
Posted : 01/02/2016 9:18 pm
Thanks all. Have ordered a replacement 32t from Works Components. Cheaper than Superstar as it happens.
Posted : 01/02/2016 9:46 pm
