Works components th...
[Closed] Works components thick/thin chainring 32t (oval)
2 Users
Website says the bolt holes are threaded therefore will I need single ring length bolts or full outer bolts?
Posted : 09/01/2016 8:23 pm
I fitted an identical one last week. Either will work fine, I used single ring length ones because that was what was holding the old ring on.
Posted : 09/01/2016 8:34 pm
Ok great, I've got single ring ones already. So assume the threaded ring negates the need for the nut?
Posted : 09/01/2016 8:38 pm
Yep, no need for the nut.
Posted : 09/01/2016 8:43 pm
Thanks Jakd
Posted : 09/01/2016 8:44 pm
