Works Components an...
[Closed] Works Components angleset fitting
Fitted the above today, both cups are lined up with each other but are half to one degree out with the centre line of the frame.
Will that be ok, or shall I knock them out and start again?
Put bluntly will I die?
Posted : 03/12/2013 5:21 pm
Doubt you'll notice tbh but you'll always know.....
Posted : 03/12/2013 5:39 pm
Half a degree? Do you have lasers for eyes? Mine are as straight as I wanted them to be but being realistic, my tolerances are naked-eye and I wouldn't know if they were half a degree out.
Posted : 03/12/2013 7:49 pm
Tricky to fit aren't they.
But worth it 🙂
Posted : 03/12/2013 9:39 pm
Yeah a little tricky, get it all lined up and then the bloody thing moves when you put the press on it.
NW - a degree ish out between the two marks on the cup, so a fair bit further when you've drawn a line up to the seatpost.
Posted : 03/12/2013 9:51 pm
put them in the freezer for a couple of hours an you can push them in by hand and twist them with your fingers.
physics = awesome 😉
Posted : 03/12/2013 11:04 pm
I've one for sale if anyone interested. Tapered steerer, to fit long HT
[url= http://singletrackworld.com/forum/topic/fs-works-components-10degree-headset-tapered-ec44ec49 ]Clicky for details[/url]
Posted : 03/12/2013 11:30 pm
I gave up using the press for that reason and used hammer and block of wood......carefully!!
Posted : 04/12/2013 4:12 pm
 DK
b45her - Member
physics = awesome
Wish id read that a few hours ago!
granny_ring - Member
More than one way to skin a cat!! 😀 as they say
Looks neat when fitted. Bars move nice. Bearings seem a bit cheap though...
Any long term users anything to report?!
Posted : 22/08/2014 9:08 pm
 DK
Burchy1 - Member
That is of course assuming you're still alive :/
Posted : 22/08/2014 9:10 pm
 Si
I predict impending doom...
Thought you all ready had one fitted anyway?
Posted : 22/08/2014 9:22 pm
I fitted mine with a crown race from a Hope headset which has a rubber skirt, seems to have better seal against water ingress, the works one had quite a noticable gap. took it apart after the rainy season and it's pristine inside 🙂
Posted : 22/08/2014 9:56 pm
Si - I do, fitted 8 months ago when I first posted 😉
It's been great and the bearings are still smooth.
Posted : 22/08/2014 10:17 pm
DK - Member
I've had 3 now, in various bikes... They seem to go through top bearings. Now the bearings are the same and the sealing's much the same as cane creek S3s, which don't go through top bearings. But what I think is maybe the flatter top of the reducer headset lets water sit on and soak past the seals, or something.
It is a trivial irritation really, considering what it can do for a bike, but it gives me something to say apart from "good kit" so that's useful
Posted : 22/08/2014 11:02 pm
 DK
Haha cheers northwind, yeah I can see what you mean it's flat on top, and like iffoverlord said, seal seems a bit crap.
Plenty of space for grease though I guess and quick job dropping top bearing in. Cheers for the info.
...now, did I mention it's on my orange five? discuss. 😉
Posted : 22/08/2014 11:08 pm
60 degree head angle 😆
Posted : 22/08/2014 11:10 pm
I'm not very impressed with the On One/Works Components angleset. Don't know if it's something specific to my bike, but it doesn't seem to be many rides before the headset starts seizing between rides and then needs changing. I'm needing a third now in only three years, very poor considering we've had two dry summers. The bike's been used at most once a week in summer (probably more like once every 2 weeks) and it only goes out 1 or 2 rides over a winter. At £60 a shot I'd expect much better for that amount of use, not sure what to do this time round as I like what it does for the bike, probably going to have to scrap the slacker angle and go with something that lasts longer.
(had them fitted by a reliable lbs btw, so don't think the issue is anything to do with fitting error)
Posted : 23/08/2014 7:32 am
Have you got the right one for your frame (they are specific to certain head tube lengths.
Got one in the xc bike, it's been in there a few years now and had a lot of miles on it. No bother at all.
Posted : 23/08/2014 9:07 am
Replacing headset bearings once a year at a cost of a few quid isn't too bad tbh. Not ideal but does that really make you want to replace it with a different headset?
Posted : 31/08/2014 3:40 pm
