Working out height ...
[Closed] Working out height gain without a GPS (Lyme Cage if any locals know the height)
Does anybody have an easy method (I'm mathamatically challanged) for working out height from one point to the next?
I need to know how much higher Lyme Cage in Lyme Park is from the road below it. Distance I can do aided by Cateye cycle computers, height is beyond me though.
Google was unhelpful.
Posted : 25/08/2009 3:34 pm
 Olly
get an OS map (multimap have them online) and count the contour lines.
Posted : 25/08/2009 3:40 pm
Cage Hill is 263m ASL
That's 863ft.
Posted : 25/08/2009 3:44 pm
You could draw the route into [url= http://www.mapmyride.com ]www.mapmyride.com[/url] and it can give you a profile, max height and height gain. It runs off Google maps so is better suited to roads rather than tracks...
Posted : 25/08/2009 3:45 pm
173m at the A6
263m at the cage
you do the math ๐Ÿ™‚
Posted : 25/08/2009 3:47 pm
A6 is higher than the drive road but thanks anyway ๐Ÿ™‚
I'll do the google earth/map thing later (or take Crazy Legs' - thanks James) word for it ๐Ÿ™‚
I need to know what I'm doing when I'm doing my hill reps.
Thanks again, I love you all.
Posted : 25/08/2009 3:58 pm
Actually, is that right James? 863 feet from the road into the park (for arguements sake the pay hut) to the cage? Gosh (or similar expletives)!
Posted : 25/08/2009 4:03 pm
 nbt
863 feet ASL - Above Sea Level. Not Above The Road ๐Ÿ™‚
Posted : 25/08/2009 4:07 pm
 IA
Looking at a map will be more accurate than a gps anyhow. GPS is a poor system to measure altitude with any accuracy.
Posted : 25/08/2009 4:09 pm
I'm speed reading at work. I assumed they'd put an Advanced Stop Lane in at the hut or something?
Cheers IA. I'll get the map out tonight.
Posted : 25/08/2009 4:23 pm
IA - map contours are not very accurate either. They are interpolations based on visual information and some measurements, not measurements in themselves. Spot heights on maps are accurate.
WAAs on a GPS should give you better than 7m accuracy.
http://users.erols.com/dlwilson/gpswaas.htm
Admittedly, its unlikely that a map contour would be more than 7 metres out but equally 7m is supposed to be the maximum error on the WAAS GPS ๐Ÿ™‚
Posted : 25/08/2009 4:28 pm
Steve,
263m at the summit.
173m on the A6 at Disley (the sharp corner).
That's 90m (295ft) height difference. Admittedly you drop down a bit from the corner as you go into the park so call it a nice round 100m.
I prefered your previous answer to be honest James ๐Ÿ™‚
Thanks again (all).
Posted : 25/08/2009 4:32 pm
[url= http://www.bikeroutetoaster.com/Course.aspx ]BikeRouteToaster[/url]
better import/export options.
[url= http://www.bikehike.co.uk/mapview.php ]BikeHike[/url]
with OS maps
Posted : 25/08/2009 9:34 pm
Cheers Dave
Posted : 25/08/2009 10:51 pm
