What's you post ride clean down routine through the winter?
Any time saving tips?
I'm spending longer cleaning the bloody thing than riding these last few weeks.
Quick rinse once a month...
Reminds me actually. I need to oil the chain. It wouldn't even back pedal before.
Acf-50 onto a clean bike, then just worry about the moving parts until the summer.
Was delighted when I learned about this stuff from the motorbike people. Works just as well on mountain bikes.
Rachel
Old towel on the chain, then oil. Wait till mud dries then poke big lumps off with a stick.
Other than that, wait till April.
Buy a cheap bike for winter then just ride it. Re-lube chain if it needs it. Clean in the spring and determine what repairs are needed ready to be abused the next winter.
Bucket of hot soapy water once a week, GT85 to decrease. Deep clean once a month which is chain off, cassette off and crank off. Roughly once every six months they get completely stripped to the bare frame, re-cabled and re-built.
Two tips.
Rigid singlespeed. Clean in September and again in April.
And an actual tip;
I bought a soft brush from Halfords that attaches to the hose, very long soft bristles with a constant jet of water. Does the trick on all the fiddly bits of the bike with minimal need to spray the bearing areas. I'm very impressed with it. I assume it's for cars but who cleans those with a brush?
Putoline on the chain ( it lasts hundreds of miles even in winter). Don't bother washing it every ride, just a hose down every now and then with plain water and a soft brush
Let it dry. Brush most of it off with a stiff brush. Apart from drivetrain and suspension maintenance this will actually cover most needs. Chain machine for chain, stiff washing up brush for the cassette and jockeys and a soft cloth for the stanchions and a little fork lube if doing a proper job.
If wanting properly clean from that point, then as usual some hot soapy water, a sponge and a gentle hose are the way forward.
AllTheGear, just been googling ACF50 as it was a new one on me, what does it actually do for you? Keep corrosion at bay or do you get some sort of muck-rejecting finish from it, too? I've heard roadies talking about hosing bikes in GT85 for similar purposes before - I just discounted it as the same roadies were happily telling me GT85 was the best bike washing and chain lubing product ever and discussing where to buy 12 packs...
lol, i have also met some roadies who like GT85 so much i almost expected them to spray themselves with it too.
We get lots of "i spray gt85/wd40 on it" riders in the shop, their next sentence is usually, the brakes squeal/aren't as good as they were"
Careful where you spray it kids
Let it dry
Nooooo ... quick wash down with the hose, dry the chain, apply Scottoiler UBS
Pretty much a daily routine for me ... takes all of 5 - 10 mins
I've got the big muc-off soft brush with a hose put on a gentle spray, just a quick brush down.
Then dry chain and lube, in the shed.
Hose down if really awful. Dustpan brush to help shift the big bits.
If proper filthy soak the chain etc in MucOff and scrub round a few times with the brush. Rinse off.
About every tenth ride replace Shimano HT II bottom bracket because deapite being careful not to aim hoses or degreaser anywhere near the bb shell, I'm clearly still getting something wrong and they're indexed / seized after not many rides . I think it's because there's no heating and i sometimes go a couple of weeks without riding so water is sitting around the seals in the shed. Something thats sealed properly needs to be ordered on payday!
I tend to ride fully rigid this time of year, saves the FS from the worst. Hosedown after ride, leave to stand for an hour if possible, spray chain & pedals with WD40, put away.
It's winter. If I was to hose the bike down each ride I'd have an ice rink for a few weeks.
Let it dry, brush the worst off.
I'm using Mucky Off wetlube so there's no yucky residue and the chain will likely get another minimal application before the next ride.
Get the Mrs/Child/Mother to do it for you.
Let it dry, brush it off, oil chain
@bikebuoy - don't you have a valet to do such things?
Can't find a link, but i have a rotating brush thing that attaches to a hose that you can fill with detergent - it's effective, but not the greenest solution.
Also lucky to have an outside hot water tap to attach the hose to, so it means little effort but sparkling results!
I've got to do 2 bikes almost every time i go out at the moment, both mine and Jnrs bike.... his doesn't take quite as long though, but it's still a good 90mins between the 2 bikes ....
quick job here, sub 10 mins - bike off car, lean against steps, quick spray with muc off (not stanchions or seal), hose on a sprinkle setting, set of muc off brushes, work top down, rinse off. That bit takes about 5 mins all in. Dry with old towel, put hose away. Some fork juice on stanchions and reverb, some silicon 3 in 1 on levers/shifters, some gt 85 on mechs and a little on chain to stop surface rust. Bike back in garage. That takes another 5 mins.
The following day, apply chain lube of choice. Much of winter that, for me, is rock n roll blue, but even that has been defeated last few weeks, so muc off C3 ceramic wet currently in use. That takes maybe 2 minutes.
.I've got to do 2 bikes almost every time i go out at the moment, both mine and Jnrs bike.... his doesn't take quite as long though, but it's still a good 90mins between the 2 bikes ...
I feel your pain.
Hose down every ride. Hot soapy water. Rinse off. Microfibre towel dry - important. Sopping wet bike is not a nice sight or great to put away.
Quick TF2 or RnR.
Every few rides a bit of a wax on the frame, wheels off and clean and wax inbetween awkward bits.
Find it easier to do it constantly than leave it. Looks after bikes better too, less muck equals less scratches and easy to maintain .
I assume it's for cars but who cleans those?
FTFY 😀
One thing I've noticed with using hot water is that it causes frame protection tape to peel so cold or cool soapy water with either a j-cloth or sponge.
The acf-50 looks interesting - how long between applications?
I have found that it depends on the type of mud.
Sandy mud (swinley etc) can be left to dry and then brushed off the frame etc. Clean the chain with a baby wipe then re-oil.
Mud with a high clay content (ridgeway etc) needs to be washed off after each ride.............
Jet wash here!!!
and I know what someone is going to say but the cross bikes get jet washed at least once a weak sometimes a lot more and they are still working well.
Makes it a 5 min job 🙂
Have a watch of this, as it's an MTB you may need to add a touch more time, but I reckon 10 minutes tops.
Straight out of car/back from ride - wheels out, frame in workstand.
Gentle hose off, poke big/sticky bits with muc off brushes, rinse wheels and cassette off.
Back wheel in, old rag on chain while cycling pedals by hand, then oil, then oily rag to take excess off.
Dry(ish) cloth, maybe with some product or other on and wipe over the rest quickly.
10-15 mins.
Chain cleaner aerosol used, then a bit of spray and agitate with paint brush on the sprockets/chainwheels.
Hose down, wipe stanchions with clean rag, dropper post if you've got an exposed bit, dab of oil on the seals, run chain through a rag, possibly dry off mech pivots, lube mechs and chain, run through all the gears, wipe off excess lube from everywhere on drivetrain, bounce forks/cycle dropper post a couple of times, wipe off excess lube from these, dry any brake pivots etc. that might corrode and seize up/wear out.
That takes me about 15 mins. Quicker version just doing chain/sprockets/chainwheels is more like 10 including lubing.
If I need it super clean, I'll do that then take out wheels and cover brakes to use a silicone spray all over. Don't do that often as it tends to tempt the weather to get absolutely horrendous so that it'd need a total full clean again in no time.
Full clean... every ride... every every ride...
Top tip, if possible, is to have a bike-washing workstation to make the whole process more efficient. I find that the actually washing of the bike doesn't take that long and I'm (usually) happy to do it. What annoys me is the muddy tip-toeing inside to turn the outside tap isolator on, getting all the bike wash stuff out, filling the bucket, rinsing the mud off the back yard afterwards, putting everything away again (usually wet!)....
For the cleaning itself:
1. Hose for big chunks of mud and debris
2. Hot, soapy water and a selection of brushes* for the more awkward bits
3. Chain cleaner
4. Spray lube on fork and Reverb stanchions, cycling the travel a few times to get dirt out from the seal, then wipe down (I read somewhere not to do this with rear suspension; don't ask me why)
5. Towel down if the weather means the bike won't dry naturally
6. GT85 to displace water from chains etc
*this type of brush is superb for getting in between suspension linkages and on hubs
[img]
?v=1422307051[/img]
....and this type of soft brush is a God-send for quick cleaning of the cassette
[img]
[/img]
Only ride a hard tail during the winter which reduces the time around complicated suspension sections. If I do ride the full suss it's no big deal to clean it thoroughly as it may go another month before its ridden.
Ideally with hard tail rinse it off when the mud is still wet and then leave it to dry. Depending on the drivetrain, dry it off with a rag and then apply slathering of wet lube. Once a month of so when it gets really bad, use chain cleaner and degreaser and then reapply lube. Maybe once every two months give it a proper clean all over.
I'm sure someone has already said it, but it does depend on where you ride as to how often you need to clean. A wet Dark Peak ride, for example, can leave grit and water in all manner of moving parts on a bike. This "grinding paste" can destroy components. A few miles away in the White Peak you'll probably return home with a lot more sticky mud on your bike, but it's arguably less damaging due to not being so abrasive.
The quicker the better, gonna try a combo of a few of those I fink.
It's the gritty paste on my cassette and chain that is the killer and obviously it sleeps in my bed so needs to be clean you jokers
Hose the bike in the dark, hang up to dry indoors. Next day, spot the bits you missed, wipe chain and relube. Maybe 10 minutes all in
I'm a recent convert to the hose brush after years of hot water and soap.
It's quicker, less faffy and comes pretty close to the soap approach. OCD types won't be happy with the finish, but it terms of functional cleanliness to see damage, wear and not drop shit every where, it's perfectly fine.
Another +1 to the singlespeed here. Quick douse with the dirtworker as soon as back to the car or house and done. If you can be in the habit of doing it as soon as you finish, before you're clean and dry and warm it's less hardship than getting clean yourself and then covering your feet in mud again.
I've also got a cheap as chips rustproof BMX chain on it, so don't need to worry about that either, just add lube to it once it starts to really squeak. Occasionally i might take it off to clean the swinley / pirbright sandy grit out to reduce wear on the drivetrain - but as per another thread, the whole drivetrain can be replaced for about £12.50 - it laughs at your fancy chamfered plate chains in this weather.
I'm often out on a ride pondering whether to have another 20 minutes riding or go home earlier to clean the bike. The former often wins 🙂
Oh for a life where my MTB ride is not sandwiched tightly between other commitments.
It has to be REALLY bad for me to wash the bike. Washing is usually just hosing off the mud
Only bother thinking about the HT, the rigid bike gets wheeled into the garage and left to dry there. I pick the worst of the mud off the bike next time round
Drawing up list of who to buy bikes from and who NOT !
I know the magic sheets work wonders for my legs and arms after a night ride. I wonder whether wrapping the bike up in a duvet would help.
Rinse off with cold water hose and a brush. Liberally spray chain to remove fine grit. Towel dry. Leave next to radiator in dining room to fully dry. Lube chain and put away. This after every off road ride, and most long wet road rides. If it's on a bike i'll be riding next day, it doesn't get put away. The only exception is the trike. That doesn't really get cleaned, just the chain cleaned and lubed. And it's a long chain!
Using the chain degreaser and a paintbrush every ride really stops the gunk building up on the cassette and chainset, and it barely takes any longer than just hosing the bike off.
If you don't have a hose, arrange to have one.
Anyone use the Park Tool DH-1 dummy hub (or equivalent)? I like to remove the wheels when cleaning the bike for better access and this would allow me to still clean the chain on the bike. Worth spending £18 quid on or just clean the chain before removing the rear wheel? Or remove the chain and clean off the bike?
I remove chain with quick link and stick in cleaning stuff.
FTYFphiljunior - Member
Using the chain degreaser and a [s]paintbrush[/s] [b]cassette cleaning brush and chain cleaner[/b] every ride really stops the gunk building up on the cassette and chainset, and it barely takes any longer than just hosing the bike off.
Is engine degreaser safe to use on chains/ cassettes/ cranks?
Or what is the cheapest available?
Edit. obviously after removal
Does it make any odds whether you clean the bike straight after a relatively muddy ride, or do it before the next ride?
Silly me did another post-work ride today, glad I still had the fat wheels installed because the off-road bits by Northam Bridge and Old Cutbush Lane were a bit sloppy in places after Sunday's downpour. But stupid me left home without the Fatboard mudguard set, so the bike and I got a little mucky. 😳
Tonight I gave it a test run 🙂
Before the ride I got my 'wash station' ready 😀
Bucket
Sponges
3 different brushes
screwdriver
lubes
degreaser
Chain cleaner
Rags
Old towel
Good ride, bit dryer tonight but still came back caked in shite, it was dark and cold.
I set the clock and got to work
Warm bucket of soapy water with a stiff brush to clean the big stuff
Thin Flatbladed screwdriver to clean jockeys + anything from the cassette
Sponge down
Sprayed drivetrain with some degreaser
Change sponge to clean chain and cassette, then cassette brush
Chain cleaner device
Fresh bucket of water and sponge down
Towel for quick dry
dry rags on stanchions and quick lube
Put tools away
Hid up the broken flower pots (don't ask :oops:)
Lube chain
Bike away
42mins 🙁 It was a good'ole clean up though so plenty of room for short cuts/improving. A hose and brush would save quite a bit of my time.
I find I don't need to degrease hardly at all with r&r and lighter lubes. Just need to lube often.
Stick bike in the dishwasher, or ride through a car wash.
[quote=rone ]I find I don't need to degrease hardly at all with r&r and lighter lubes. Just need to lube often.
This thread does have me wondering just how much lube folk are using.
iainc - Member
philjunior - Member
Using the chain degreaser and a paintbrush cassette cleaning brush and chain cleaner every ride really stops the gunk building up on the cassette and chainset, and it barely takes any longer than just hosing the bike off.
FTYF
Nope, tried cassette cleaning brushes in the past, not found them much cop, an article on the BC website by one of their mechanics recommended the paintbrush, it really works well (I've assumed unused paintbrushes are best!)
[quote="theocb"]
It's the gritty paste on my cassette and chain that is the killer and ...........
Use putoline chain wax on your chain. Once the excess is wiped off the chain remains clean and well lubricated for many rides even in the worst conditions and your chain and cassette does not gum up
42 minutes!!
Get a rigid singlespeed, that's torture in this weather.
Rigid bike with Rohloff here. Change oil annually and chain and rear sprocket at approximately 3 year intervals. Add gear box oil to chain as and when enough mud has been washed of it by the rain.
water will kill your bike quicker than anything so....
...find a warm dry place and leave it to dry...
...remove persistent dirt by hand/brush...
...relube as necessary
Once a year repeat the above process but USE A VACCUUM CLEANER WITH THE SOFT BRUSH ATTACHMENT WOHHHHHHHHHHHHHHHHH
I'll put this on here as well.
I am so evangelical about putoline being so much better than any other lube for longevity and cleanliness that I will offer to treat anyones chain if they want - Edinburgh based
Rohloff and belt drive. Takes the hassle out of things. I find myself riding more as I worry less about maintenance and just get on with riding whatever the weather.
When the weather is dry and my bike is clean, i polish all the paintwork with car wax, then lube the drive train.
When i get back from a muddy ride i just spray it with the garden hose & the mud just flies off due to the car wax.Then i dry the chain + re-lube it.
10 mins tops.
Only wash it when you have to. Keep the chain and stanchions clean and lubed, forget the rest. Water will wreck all the bearings much quicker than mud will.
If you do wash it, ride it the next day. A clean but wet bike is a corroding bike.
Get a mudhugger on the rear, a crud catcher on the downtube and a fork mounted mudguard on the front.
After each ride, clean it straight way (while the mud is still wet) with a Mobi Jet Washer. These are mobile so if your ride ends at the car, it is still not a problem. it does however require the full 17 litres of water if you want to clean everything including the wheels and frame.
The Jet Washer in itself cleans everything, sometimes spray some washing up liquid on the bike to speed things up.
The only thing that requires additional attention is the drive train.
Going 1x10 also seems to help with the gears, gets much less problems, as there is less moving parts for the mud to wreck.
That's all I ever do and thats with a full suspension bike and it doesn't usually need much replacing over the Winter. 200-300 miles per month November-March.
So then, anyone brave enough to google
"lube vacuum cleaner attachment rigid torture belt spray quickie"
at work? 😆
Wash, wipe, WD40/Gt?? (avoiding disks) and re-lube after every ride at this time of year
Full brush and deep clean every 2-3 weeks
Crap and tech stuff but good at cleaning!!
My Jetwash is my best friend through the long wet muddy claggy Kentish winters ,used 3 times a week -job done in 5mins makes it almost pleasure not a chore. Quick towel dry and re-lube and bikes ready for another round . 🙂
Tap water and a soft brush.
Spray with Scottoiler FS365 (water-soluble rust-inhibitor).
Kettle on.
Total time - a couple of minutes, max.
Rone, I thought you were using a "clean by air" machine. Is that still in use k has it been retired? I seem to remember Chipps saying the mag was getting one to test. Did anything ever come of that?
My most ecellent washing routine for those who hate washing bikes but like them to look nice and shiney...
Buy a big 5ltr bottle of no nonsense degreaser from screwfix for £5 This dilutes down to 1 capfull per litre.
Buy one of those big garden sprayer things and fill with the diluted soltion. This shouls last a few washes depending on size of sprayer.
When faced with a dirty bike...
Hose bike
Spray bike
Leave 5 mins
Hose again
Leave to dry
Quick re lube.
Minimum effort and you have an "as new" bike waiting for you in the shed every time.
Re. the water in bearings thing, I will sometimes spray some wd40 or GT85 at bits I don't want staying wet, but tap water is going to corrode a lot less than salty water that you will often end up with this time of year.
speaking from experience that will strip the grease out of your bearings!
