Will this DT Swiss ...
[Closed] Will this DT Swiss Rear Wheel Thru Axle be compatible with my Frame ?
It's a Specialized bike and the current Thru Axle has stripped the thread and needs replacing immediately. Will this DT Swiss Rear Wheel Thru Axle be compatible with my Frame ?
http://www.wiggle.co.uk/dt-swiss-rws-12mm/?lang=en&curr=GBP&dest=1&sku=5360765547&kpid=5360765547&utm_source=google&utm_term&utm_campaign=UK_PLA_Components&utm_medium=base&utm_content=mkwid%7csWdz9UdVZ_dm%7cpcrid%7c67090789502%7cpkw%7c%7cpmt%7c%7cprd%7c5360765547uk
The thru axle it's replacing is a 12 x 142, which is the same as above. But the problem is, I don't know if the thread is compatible with that on the Specialized frame ? It's a Camber Evo 29er 2015.
Posted : 22/06/2017 12:58 pm
Yes, that one will work fine. Specialized frames use the Syntace X12 standard, which that axle is compatible with.
Posted : 22/06/2017 1:03 pm
Thanks
Posted : 22/06/2017 2:30 pm
