Will this bolt fit?
[Closed] Will this bolt fit?
7 Users
Evening guys.
I was giving my Nomad 4 a strip down and clean last night and the bolt holding the rear shock in place rolled down the back of the bolted in cabinets never to be seen. I need to get hold of one ASAP and have found the following online, just wanted to confirm if this would work?
https://www.pro-bolt.com/aluminium-allen-bolt-m8-x-1-25mm-x-40mm-pack-x-5-7.html
I had a look on the SC diagram and it does state the bolt is M8 x 1.25 x 40 so should be OK?
Just hoping the head of the bolt fits snugly in the insert like now :/
Posted : 10/07/2018 5:13 pm
Should be ok, the cap head bit is standard, so should fit. Do you really want aluminum?
Posted : 10/07/2018 9:13 pm
I’d try calling SC Uk or Jungle and see if they can pop a genuine one in the post.
Posted : 10/07/2018 9:32 pm
You'll probably get one in Halfords quite easily. Alloy not really the best option for that job. Steel of some kind would be better.
M8 seems big for a shock bolt, that's crank bolt size.
Posted : 10/07/2018 9:37 pm
Shock bolts are 35 and 42mm according to SC diagram. I assume you'll want one with a thread on the end only for where it contacts the shock bushing?
Posted : 10/07/2018 9:47 pm
Yes 42mm is what I need. It is flat in the middle and threaded at one end to screw in to the flip chip.
Posted : 11/07/2018 12:32 am
I’d be phoning one of the shock tuning companies as they’ll more than likely hold stock, or you could try phoning the importers
Posted : 11/07/2018 1:09 am
I've always used  https://www.ebay.co.uk/itm/M4-M5-M6-M8-HEXAGON-SOCKET-HEAD-CAP-SCREW-BOLT-DIN-912-A2-STAINLESS-STEEL/151145728116?hash=item2330fcc874:m:ms9Zcad3Mxuc9R9AAFKyiTQ Krostex is the seller. Very helpful and lightning fast delivery
Posted : 11/07/2018 1:27 am
