Will these forks be...
[Closed] Will these forks be okay on my 29er scandal
http://www.merlincycles.com/kinesis-maxlight-ix-29er-carbon-fork-tapered-steerer-57540.html
Those are the forks I'm after purely for the 15mm axle. The only difference with them is that they are 470mm axle to crown. I would have a look on the on-one website but cant find the scandal anywhere.
Any help would be much appreciated.
Posted : 11/03/2014 10:54 pm
It depends on your headtube, I'm not sure what the Scandal has, if it's a 1-18th external headset like an Inbred then it won't fit because its a tapered steerer on the forks, if it's a 44mm semi integrated or tapered headtube then it will fit with the right headset.
The axle to crown length will be fine..
Posted : 11/03/2014 11:10 pm
If you only have one set of bottle bosses on your Scandal it's a V2 so it will fit.
If you have 2 sets then no it won't fit!
Posted : 12/03/2014 9:28 am
