Will road bike whee...
[Closed] Will road bike wheels/tyres fit a 26'er On-One Inbred?
I want to build up a tourer and I've got an On-one inbred sat in the garage, a set of 700c disc wheels and associated gubbins. Will this work, or should I just cough up for a niner frame?
Posted : 19/06/2012 4:05 pm
Try fitting a wheel and you will find out for yourself
Posted : 19/06/2012 4:11 pm
Yes
Posted : 19/06/2012 4:17 pm
 Rik
They don't fit in a ti456 for reference - they hit the wishbone seat stay.
The answer is 'possibly'. Rim width and tyre choice might mean not, but only way to tell is to try.
Posted : 19/06/2012 4:19 pm
Sounds fair enough - I'm doing the 'sat at work day dreaming about clearing off on the bike' thing, bike is in Suffolk, I'm in Guildford so I can't check until the weekend.
Cheers for the replies
Posted : 19/06/2012 4:28 pm
700 wheel with 700x37mm CX tyre just fits in my sliding dropout Inbred with dropouts at 1/2 way point of adjustment. Would probably take a 700x32mm with mudguard clearance if adjustment.taken as far back as it can go.
Posted : 19/06/2012 10:36 pm
I've done it - 700x28s IIRC. I reckon 700x32 might work.
Posted : 19/06/2012 10:38 pm
You DON'T NEED 700C wheels/tyres to ride on the road.
https://picasaweb.google.com/lh/photo/JJzMcyeOt6mjIp1sEy6WBtMTjNZETYmyPJy0liipFm0?feat=directlink
The tyres are Schwalbe Kojacks 2.00 run tubeless on Stans Flow rims at 25-30PSI FR and 40-50PSI REAR (no need for more). I keep up with my roadie mates without any problems. Actually on bad roads it's them who needs to work harder...
[img] http://picasaweb.google.com/lh/photo/JJzMcyeOt6mjIp1sEy6WBtMTjNZETYmyPJy0liipFm0?feat=directlink [/img]
Posted : 10/07/2012 8:28 pm
Yes,they do so long as you use road tyres on it,well actually if you run the Inbred steel fork you can get a full on MTB tyre on the front as well
Posted : 10/07/2012 8:30 pm
