will manitou spring...
[Closed] will manitou springs fit a coil dhx 5?
this one to be more precise. cannot tell if the internal diameter is oversize or not ( ie 31mm or 36mm) Need 36 mm.
http://www.chainreactioncycles.com/Models.aspx?ModelID=15335
Posted : 15/12/2010 10:44 pm
I think manitou springs have a slightly bigger ID than a coil dhx so it might rattle a wee bit depending on how much preload you are using. According to the TF Tuned website "Manitou or BOS springs will fit Fox DHX/Van R shocks in most cases and are less expensive". See [url= http://www.tftunedshox.com/info/spring_calculator.aspx ]here[/url]
Posted : 15/12/2010 11:02 pm
thanks
Posted : 15/12/2010 11:53 pm
 GW
they won't rattle unless you don't tighten the preload collar, they can sometimes squeak tho
Posted : 15/12/2010 11:56 pm
ok. cheers. Just ordered one. Free length is going to a bit tight, but should be ok. Should be undersprung a little so some preload is fine. Had to get a slightly longer one for my required spring rate and nukeproof don't do this either.
Posted : 16/12/2010 12:04 am
they dont fit over a certain poundage on the 2.75" stroke shocks
Posted : 16/12/2010 12:10 am
cheers. got a nukeproof 2.25 400lb already which fits fine, but want softer option ( possibly) too.
got 2.5 350lb
Posted : 16/12/2010 12:14 am
haven't used either yet. want to do a static sag test back to back
Posted : 16/12/2010 12:37 am
whats the shock?
i2i and stroke?
where have you ordered from?
Posted : 16/12/2010 12:40 am
