Will it work..9 and...
[Closed] Will it work..9 and 10 speed together?
Will a 10 speed slx mech work on a 9 speed cassette with a 9 speed slx shifter?
A simple yes or no will do.
Thanks Nathan
Posted : 14/12/2013 8:25 pm
No.
Posted : 14/12/2013 8:27 pm
Yes...... If you have no other option. Generally speaking if the mech is more speed than the cassette then you could tune it to run most of the gears.
Posted : 14/12/2013 11:38 pm
No - cable pull is different to 6-9 speed.
Posted : 14/12/2013 11:42 pm
it'll work with a sram 9sp shifter and a small spacer on the clamp bolt, look it up
Posted : 15/12/2013 12:12 am
Aye, I've got 3 bikes running 9.5 speed with 10 speed mechs and 9-speed X9 shifters, and a wee spacer, which works absolutely perfectly- you'd never know. But anything else is a hellish bodge, 9-speed shimano on 10-speed Shimano will be out by absolutely miles, never actually tried it but if you can get more than a couple of gears to work I'd be amazed.
Posted : 15/12/2013 12:14 am
