Will 29" MTB t...
[Closed] Will 29" MTB tyres fit on 700c hybrid rims?
Mate of mine has a 2014 Whyte Caledonian hybrid/all terrain thing and fancies joining us for an MTB ride.
He doesn't want to buy another bike or rent so I've come up with the bright idea of adding MTB tyres :$
It's 700c so am I right in saying a 29" tyre would fit on the rim?
Also, anyone ever done it to a hybrid and had clearance issues with the bigger tyre and the frame/fork??!
Cheers.
Posted : 23/02/2014 5:15 pm
Depends how wide (internal) the rims are, 17mm might be a push:
Posted : 23/02/2014 6:16 pm
 mokl
Maybe do better with a cross tyre?
Posted : 23/02/2014 6:20 pm
Yeah, they'll fit. I've got the back wheel off a Whyte Malvern in my garage and I've just measured it at 0.5mm wider externally than the Mavic 717s on my MTB. They take 2,25in tyres just fine, so whatever fits between the stays of the Whyte will be OK.
Posted : 23/02/2014 6:27 pm
By that rim width chart a Mavic 717 couldn't have any more than a 1.5" tyre and an Arch Ex would be limited to a 2.0" tyre. And that's plainly nonsense.
Posted : 23/02/2014 7:37 pm
Balls, yep, agreed. ๐Ÿ™‚
Posted : 23/02/2014 7:47 pm
You'll be more limited by frame/fork clearance than rim width.
Posted : 23/02/2014 7:50 pm
Aye the rim-width-limitation is a pile of crock, unless running at low pressures.
Posted : 23/02/2014 8:01 pm
The fork clearance will be the biggest issue I'd say. Get some 42mm CX tyres link cyclo x kings and you should be fine. 1.65" of grippy off road tyre
Posted : 23/02/2014 8:04 pm
Chart is from here: http://sheldonbrown.com/tire-sizing.html. And does say the following underneath:
[i]
Note: This chart may err a bit on the side of caution. Many cyclists exceed the recommended widths with no problem.[/i]
Posted : 23/02/2014 8:14 pm
Thanks for all the replies guys, he will be pleased!!
Posted : 25/02/2014 8:04 am
There is a lot of stuff on Sheldon Brown which is very useful. It isn't the bible everyone things it is though, as some stuff is just plain wrong.
Posted : 25/02/2014 8:38 am
Agreed, that's total rubbish
Posted : 25/02/2014 8:41 am
Yup, I've had 2.0" race kings on open pros, 14.5 internal.
But looking at the Alphas now, some are saying that even though the rim is wider, there's less scope for wide tyres because of the low sidewall.
Any truth in this?
Posted : 25/02/2014 8:49 am
The bead is not held by the sidewall though, so id say its nowlt relevant - but I've not tried it.
Posted : 25/02/2014 9:36 am
