Whyte MTB bottom br...
[Closed] Whyte MTB bottom bracket unscrewing itself
[#10410636]
I picked up a second hand Whyte 603 for the missus earlier this year. I believe it's the 2017 model. Really clean and looked to have done minimal work.
After a few days having it home I noticed some play in the cranks, and the bottom bracket had unscrewed itself. I removed it, greased everything and did it all back up fairly securely.
It's been used probably 10 times since the initial fix, only once slowly plodding around anything non-flat, and it's unwound itself again.
What should I be doing differently or inspecting when I take it apart again?
Posted : 29/12/2018 10:07 am
What cranks and bottom bracket?
I'd clean it up with some IPA thoroughly, an then apply a bit of blue loctite / threadlock.
Posted : 29/12/2018 10:30 am
Do it up tighter - BB shell torque is normally in the region of 35-50NM (check for your specific one) which is a fair amount of leaning on it. If you do that and it still comes loose check for stripped threads..
Posted : 29/12/2018 10:34 am
Cheers I was unsure on loctite being acceptable there, but a few dabs may be OK I guess!
It's a square taper crankset and internal bottom bracket, fairly dated design I believe. May just be I didn't tighten them up enough but hopefully that's the case.
Posted : 29/12/2018 9:12 pm
I thought BSA threaded BB's were designed such that they didn't unscrew under normal use?? Thought it was Italian threads that were more likely to unscrew?
Is there something else amiss? Cracked shell? Sticking bearings??
Posted : 30/12/2018 11:43 pm
could well be that the threads are damaged now if it's been ridden loose.
Might be worth fitting a new BB now to get fresh threads and hope the frame is okay.
Posted : 31/12/2018 1:35 am
