Why won't my M...
[Closed] Why won't my Maxle Lite (2010 Revs) tighten enough to get rid of play?
The Maxle on my Pikes was fine with the same hub.....
Posted : 01/10/2009 10:36 am
check your bearings in the hub - do NOT overtighten the maxle
Posted : 01/10/2009 10:41 am
Make sure there is enough grease on the wedges inside the maxle. Rock Shox rarely put enough grease on them, so they bind in, rather than expand the maxle.
99% of the time this will cure any play issues.
Posted : 01/10/2009 10:48 am
Thanks twohats, will give it a go
Posted : 01/10/2009 10:49 am
@gdr - Is that a voice of experience speaking? Did the dropout crack?
Posted : 01/10/2009 10:50 am
pro II ??
there's lots of threads on the subject
Yeap. Pro II
Posted : 01/10/2009 11:05 am
bearings worn on a pro 2 change em problem solved
Posted : 01/10/2009 12:42 pm
bearings it was. all changed and now sorted. thanks guys and thanks to Robby at Psyclewerx
Posted : 01/10/2009 2:06 pm
