Why the odd metal b...
[Closed] Why the odd metal bearing seal? - pics..
Taken apart a Mavic Crossmax ST 29er freehub and pushed out two of these 6803RS bearings, on the side that faces out they have a shiny metal seal and not the usual rubber lipped black metal one that the other side has.
When I get the new ones from from ebay (Kaese on here) should I whip out one rubber and replace with the metal?
Many thanks for any help.
Posted : 05/08/2013 3:36 pm
keeps the grease in and less friction than a rubber covered seal would be my guess.
Posted : 05/08/2013 3:38 pm
 FOG
More common on automotive bearings. Used to seem them in motorbike wheels, so no problem but probably not worth swapping to new bearings
Posted : 05/08/2013 4:39 pm
 gee
The 2RS ones have 2 rubber seals. The ones that don't have RS on the en of the code have two metal seals.
GB
Posted : 05/08/2013 4:42 pm
It could be that the rubber has worn off leaving the metal shield. Rubber seals are rarely all rubber, that metal surface is very shiny as if it has subjected to a lot rubbing.
Posted : 05/08/2013 4:50 pm
The first three replies are correct. The forth one is not.
Posted : 05/08/2013 5:07 pm
Explain plain why the fourth is incorrect.
Posted : 05/08/2013 5:36 pm
Because its a daft suggestion. If the rubber had worn off the metal wouldn't look like that, and it wouldn't stay in place, and bearings with metal deals aren't that uncommon.
Posted : 05/08/2013 5:50 pm
njee20 I know all what you are saying but the face of that metal shield looks all distorted, it may well be a metal shield but it has what appears to be surface wear
Posted : 05/08/2013 6:13 pm
