Why does my headset...
[Closed] Why does my headset feel loose?
16 Users
That's what ti feels like anyway but I have tightened and the same amount of play still persists. What else can it be?
My immediate thought was fork seals, any other possibilities?
Posted : 24/01/2017 11:03 am
brake caliper or disc a little loose?
Posted : 24/01/2017 11:05 am
Fork bushes? Steerer too long?
Posted : 24/01/2017 11:07 am
on my gfs bike the brake padshave a little movement, and that feels similar to a loose headset
Posted : 24/01/2017 11:08 am
Needs another spacer under the top cap?
 cp
assuming disc brakes, brake pads usually have a little bit of clearance in the caliper front-back which can feel like a loose headset - the pad moves slightly with the disc when you put the brake on. Not noticeable in normal use but it is when doing the 'headset looseness' test.
Cups could be moving within the frame
What are you tightening?
i.e. should be loosen stem bolts, then tighten top cap bolt to draw it up. Then tighten stem bolts. Make sure it's all drawn together properly.
If still an issue then the immediate suspect would be the headset bearings, or at least one of them. Do you get grinding sounds or feel when rotating the bars?
Fork - grab the lower and upper and check for play (don't grab the arch). If there's play then likely fork bushing worn. Unlikely to be seal.
Another is brake calliper mount or brake disc loose.
Headset though, just apply front brake (not rear) and gently rock bike back and forwards and look closely at the headset or use fingers to feel if it's moving. If it does, then yes it's the headset.
Posted : 24/01/2017 11:10 am
As scotroutes, are you tightening the top cap fully prior to the stem bolts? Is there sufficient clearance between the top of the fork steerer and the top cap to allow it to bite down?
Any of the above but I've also had a rear shock bushing needing replaced that displayed similar symptoms, a bit of movement could be felt in the frame.
Posted : 24/01/2017 11:12 am
Thanks all
I'm following DeadKenny's instructions and it's not the distance between top cap and steerer.
I haven't checked the brake caliper and rotor so will check them tonight. Then I'll check the fork bushes.
Thanks again
Posted : 24/01/2017 11:16 am
Better way to check maybe is to turn front wheel 90 degrees and see if problem persists?
Posted : 24/01/2017 11:20 am
If you turn the bars 90 degrees and rock the bike again, it rules out brake pad movement in the calipers. Obviously you will feel a bit more tyre movement but this should be easy to separate from headset movement.
Posted : 24/01/2017 11:24 am
Try checking for movement by pushing the bike gently against a solid object as per Deadkenny, but WITHOUT using the brakes. This eliminates the pads, rotor, caliper and oddly tyre tread flex.
Posted : 24/01/2017 11:27 am
This if it's a F\S frame
Posted : 24/01/2017 12:53 pm
Some forks have (IME) a small amount of play that can feel like a loose heaset. My RS ones do unless I lock them out.
To see if it is the headset I find putting the bike on its back wheel, grabing the bars and for crown before giving it a wiggle better than other methods.
Otherwise - brakes, brak pads, forks, QR, hub, bushings/bearings could be a cause.
Posted : 24/01/2017 1:07 pm
Could be any of the above, my bet is fork bushings. One possibility not mentioned is front wheel bearings
Posted : 24/01/2017 1:26 pm
