Why do some singles...
[Closed] Why do some singlespeed road bikes have bolts and not QR's?
[#1814058]
Just bought a second hand Langster. It does't have quick release hubs so does that mean I have to carry a spanner (heavy) around at all times for the inevitable puncture? Slightly less than convenient surely!
Presumably a new set of hubs, and wheel build, required for quick releas stuff.
Posted : 19/07/2010 2:50 pm
They have bolts on the rear to keep the wheel secure in the horizontal dropout.
a 15mm box spanner isn't very heavy. or you could get one of [url= http://www.parktool.com/products/detail.asp?cat=17&item=SS-15 ]these[/url]
Posted : 19/07/2010 2:52 pm
 Haze
QR's in track ends are a PITA for keeping chain tension right - you could probably use some tug-nuts with one, but they'd probably need a spanner anyway.
Posted : 19/07/2010 2:55 pm
pjt210 - thanks for the link, have just ordered one! My point is the 8oz it weighs.
Posted : 19/07/2010 2:57 pm
 aP
The main reason is that QRs don't exert enough pressure - and as they were originally used for winter miles and track work you really, really don't want wheels with QRs riding the track.
Posted : 19/07/2010 3:06 pm
PEDROS Trixie
is mucherer betterer :mrgreen:
Posted : 19/07/2010 3:10 pm
You're not allowed wheels with QRs on the track...
Anyway, as above, bolt on wheels hold the wheel more securely than QRs and while QRs will usually work ok with SS, if you ride it fixed (as a lot of Langsters are) then it's marginal to the point of being dodgy - the last thing you want on a fixie is the wheel moving in the dropouts.
Posted : 19/07/2010 3:11 pm
There's also a lot to be said for non-QR wheels for a bike that's likely to be left out on the street. The Langster has a split personality - it wants to be track, but most of them are pub. 🙂
Posted : 19/07/2010 3:15 pm
if you think the spanner is heavy, im guessing you dont carry a spare tube, levers, patches, pump, water, not to mention multi tool or chain tool?
so how is it then different to a qr?
besides as pointed out above, qr wheels go walkies from the pub too easily.
My Langster was a proper trackie (though it also did a lot of road) - original black model - the current ones' bbs are too low for the track.
Posted : 19/07/2010 3:16 pm
if it bothers you just bung in a hollow axle and QR . Run my single cross (same track ends) perfectly well with both SS and fixed. if you want to be really sure put a chain tug in. Careful choice will mean not spanner needed.
Posted : 19/07/2010 3:39 pm
