Why are womens sadd...
[Closed] Why are womens saddles aways described as 'shorter' than the mans version ?
as above. I find it a puzzling description.
Posted : 29/06/2009 1:33 pm
I bought a Charge Ladle for the wife and it is a lot shorter than the mens Spoon... I dont understand why that would be better for women bits but can only assume they have done the research.
Posted : 29/06/2009 1:36 pm
I have guys saddles fitted on my bikes, as I find a lot of womens saddles are too wide and push me forward on the saddle. Just as well I dont have one of these 'female short' ones as I would fall off the front in the end ๐Ÿ™‚
Posted : 29/06/2009 1:38 pm
because apparently "size doesnt matter"?
๐Ÿ˜‰
Posted : 29/06/2009 1:43 pm
Funnily enough, it's because they're shorter. Women have a wider set of "sit bones" than men, which accounts for the wider saddle, and I guess without men's dangly bits they don't need so much support up front.
Posted : 29/06/2009 7:02 pm
What coatesy said. Doesn't work for all women, but generally their saddles are shorter and wider due to marked physiological differences between the sexes in the pelvic region.
Posted : 29/06/2009 7:07 pm
 rs
i thought it was so we had somewhere to rest our bits on ๐Ÿ˜€
Posted : 29/06/2009 7:24 pm
they might enjoy their riding a little too much if they were longer
Posted : 29/06/2009 7:40 pm
 Bez
"[i]I find it a puzzling description.[/i]"
What on earth is puzzling about a shorter item being described as shorter?
Posted : 29/06/2009 7:55 pm
"saddles are shorter and wider due to marked physiological differences between the sexes in the pelvic region."
I realise that many women prefer wider saddles - but I dont see why that effects the length of the saddle? Womens 'bits' are not going to hang safely off the front of a short saddle as they are too far underneath our bodies for that to happen! I use SDG and Charge spoons and I don't keep thinking 'this saddle is too long'.
Maybe some womenns frames are smaller, so they try to give more clearance between the bars and the saddle?
Posted : 30/06/2009 9:59 am
