Who uses shimano di...
[Closed] Who uses shimano disc brakes?
[#810754]
The newer sort with servo wave levers (and older lx - xtr)?
If you do - what replacement pads do your ecommend and whats so good about em?
The pads are the sort with an eyelet at one end and a hook at the other!
Posted : 24/08/2009 8:29 pm
I just use Shimano, seem to last well.
Posted : 24/08/2009 8:30 pm
sintered or organic?
Posted : 24/08/2009 8:31 pm
Sintered
Posted : 24/08/2009 8:32 pm
the pads that came with my SLX were a bit shitty. ok on the back but lacking ooomph on the front. stuck a sintered BBB (cheapo-ish brand) pad in there and performance is much better.
with my old deores i used to use Shimano's own and never had a problem.
Posted : 24/08/2009 8:33 pm
Shimano. Sintered.
Have SLX and XT and ride in a fairly shitty part of the country which normally eats pads all year round. I use superstar sintered, They last and work as well as any other make that I have tried and they are also not too pricey.
Posted : 24/08/2009 8:36 pm
a2z or BBB sinterd
Posted : 24/08/2009 9:05 pm
Didn't you ask this Q LAST week as well ROFL?? God i'll be glad when you've got them set up and bedded in.
Using shimano, got a set of goodridge sintered to go in when they finally wear out.
Posted : 24/08/2009 9:08 pm
always used SSC in mine, consistently good performance and last just as well as the shimano originals in them.
 Crag
I use ashima semi metallic in the rear and ebc red on the front. Seem pretty good in all conditions and the ashima last an age.
Posted : 24/08/2009 9:10 pm
Bikefridge 3x life ceramics
Posted : 24/08/2009 9:11 pm
siperstar components pads work well.
one side resin one side sintered works well.
Posted : 24/08/2009 9:13 pm
 LMT
Ive got some new deore, the 2010 ones, yep they look nice, but performance is poor, well was, i popped some discopads sintered in and loads better. Not as good as my older hayes 9's but much better!
Posted : 24/08/2009 9:14 pm
always sintered and pretty much any brand, I have a job lot of Shimano ones at the mo, but I;ve happily used Goodridge, Fibrax, Clark and a few others. I probably wouldn't buy non branded off ebay tho.
Posted : 24/08/2009 9:19 pm
Oh - EBC work fine too.
Posted : 24/08/2009 9:26 pm
Superstar organic, after several months they seem to have lost their bite but still plenty of pad left.
Putting the lack of bite down to being carted arround on a bike rack getting slowly covered in diesel fumes.
Posted : 24/08/2009 9:30 pm
I use Ashima SOS pads in my lovely XT brakes. Perreck!
Posted : 24/08/2009 9:31 pm
Any pad has worked fine for me if not contaminated.
The thing that really worked for sheer power regardless of pad was a bigger front disc.
I even chucked a 180mm on my hack bike on the front -stops brilliantly in the wet using the sintered pads.
I was a big fat guy then and now as a medium fat guy I find I can use 160mm 20kg made a difference! lol
I rode with a guy who was 6ft 6 and probably 220lbs on 160mm discs and tried different pads and thought shimano were poo as he couldnlt stop quick till he swapped to 203mm.
:mrgreen:
My organic pads had great heat resistance but lacked bite and wore out pretty quick.
I use metal type pads for the lifespan.
Posted : 24/08/2009 9:38 pm
Had Hope, had Avid, now have XT servo wave on 3 bikes & they are excellent.
Posted : 24/08/2009 9:39 pm
did you read the question dickie?
Posted : 24/08/2009 9:40 pm
Shimano ones.
Sintered in the back, Resin in the front.
Tried cheaper pads. Went back to Shimano.
SB
Posted : 24/08/2009 9:41 pm
i currently have some A2Z organic ones in as i have found the SSC sintered ones to hard in the dryer weather though they will be going back in for winter. I run xt brakes.
Posted : 24/08/2009 10:16 pm
XT M765 with Superstar organic in the front and some pads I got cheap off ebay (Disco I think) out back
Posted : 24/08/2009 10:28 pm
I have a mixture of LX, XT (180f/160r) and an XTR set with the XT servo-wave levers (200f/160r) over 5 bikes. My brother runs Deore. All of them work brilliantly. The bigger rotors make a difference, and the servo-waves do too (I ran 180 before Wotans forced the 200mm disc upon me). I run 200f/200r with XT on the DH bike.
In terms of pads, I have a supply of Superstar and A2Z blue pads, as well as other random discount pads. I never pay any attention to compound really in the UK, although I'd look for organic for big Alpine/Canadian/Spanish descents.
A simple common pad format is great, and all work very well indeed.
Posted : 24/08/2009 10:30 pm
I use Shimano deore 535 with Discobrakes sintered pads, plenty of power and modulation
Posted : 25/08/2009 12:04 am
