Do "normal" folk still have light weight XC race bikes or has it all gone to longer travel slack machines? Let's see your fastest bikes!
Oooo oooo, pick me, pick me!
Sadly I can't get onto Flickr from work, so you'll just have to remember how awesomely fast it looks! If you're at SiTS at the weekend, you can be reminded in the flesh ๐
Whether I'm 'normal' though, is something else altogether.
LOL, I thought you might be first on the scene Nick. Not going to SiTS, I am actually having a weekend off after working for 28 of 31 days in July.
looking at getting another new bike mrP ?
what defines a cross country race bike?
My 140mm c456 weighs 22lbs...
swedish chef...what model is the trek and does it have bb90 bottom bracket....and if so what bb are you using?
Awaits fantasy bike weights..
๐
@ Vondally - its a 2011 9.9ssl, I had a 2009 model but the chainstay cracked so I got a new frame through Treks's lifetime warranty.
It has a tapered headtube which I found surprisingly stiffer than the older model.
Its a BB90 press-fit. I've got a spare set of "Enduro mr2437-llb" bearings for it
Here's njee20 bike at mm :)..
Wehay, cheers Stu, looks like I'm going pretty fast too, funny how photos can decieve ๐
Days off? They're not working you hard enough clearly!
swedish chef thanks work collegue is just in the process of buying a second hand 9.8 09 vintage but he/the office are struggling to finsd the correct bb to be used with shimano cranks, long shot but do you know if these will work?
KCNC BB90 Pressfit Bottom Bracket - Gold
Adapter cups and bearings for pressfit bottom bracket shell. Anodised 7075 alloy cups hold full stainless steel bearings and meet on the middle of the frame shell with o-rings to seal the crank axle and BB bearings. Compatible with Shimano 24mm cranks and KCNC K-type cranks (without insert).
designed for 89.5mm x 41mm and 92mm x 41mm frame shells
Compatible with KCNC K-Type and Shimano chainsets
weight : 95g
[img]
[/img]
all help grateful cheers
[url= http://farm6.static.flickr.com/5296/5416538103_2ae5bc0b77.jp g" target="_blank">http://farm6.static.flickr.com/5296/5416538103_2ae5bc0b77.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/59140623@N02/5416538103/ ]IMAG0228[/url] by [url= http://www.flickr.com/people/59140623@N02/ ]smoggy3[/url], on Flickr
Race duty! ๐
[url= http://farm7.static.flickr.com/6010/5997823628_b110de2a25.jp g" target="_blank">http://farm7.static.flickr.com/6010/5997823628_b110de2a25.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/59140623@N02/5997823628/ ]IMAG0917[/url] by [url= http://www.flickr.com/people/59140623@N02/ ]smoggy3[/url], on Flickr
For work and back only.
i havent flickered any pics of my bikes but nic can vouche for me when i say i have some very light bikes...my scale is 17.8lb on park tool with c-02 canister 2x10 and tubs.
@Vondally, no that won't work, Trek carbon BB90 frames just have drop in bearings, not press-in cups like the alu frames/Lappiere/those above, similar to an integrated vs internal headset.
He just needs to get in touch with any Trek dealer, they can order them. It's literally 2 bearings and a sleeve. The Shimano bearings are standard and can be picked up anywhere, although I forget the code, Trek aren't expensive though.
**Grudgingly acknowledges that Bruce's bikes are very light**
Have to weigh them on my scales, that'll add a pound or 2! ๐
[url= http://farm3.static.flickr.com/2661/5853017724_0b41223dcd.jp g" target="_blank">http://farm3.static.flickr.com/2661/5853017724_0b41223dcd.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/nzrich/5853017724/ ]P6203763[/url] by [url= http://www.flickr.com/people/nzrich/ ]Richard Munro[/url], on Flickr
Rock Lobsta 853. About 27lbs*, without my usual paraphernalia of mudguards, bottle and cage, pump, lights, etc. Comes in around 29lbs then. ๐ Even as a singlespeed!
*Real, not 'imagined' weight...
Top ten finisher in an International Mountain Biking Event so shut up.
See those rims Njee? They're about 550-600g each! ๐
**convulses on the floor**
That means your rims are nearly as heavy as my entire wheelset ๐
cheers njee20
I knew you'd be impressed! ๐
Got 2 both weigh 21lbs without going stupid ......
Merida flx 3000 frame with sid teams with wc intermals , xtr and carbon bits and xc sp3 on 355s rides well but constantly reminds you its an xc race bike - requires good fitness and bike handling to get the speed it can give
My ragley td-1 is rigid ss and 29er but you can amble on it an it still goes quick and doesnt shout quicker quicker and flog you to death like the merida . Rigid really isnt a hinderance either
Either has to be super steep hills or very flat not before i reach for merida ......
Google image search "njee trek" and it's the second pic ๐
[img] http://t3.gstatic.com/images?q=tbn:ANd9GcTSKqpOCG-ek2OdCDv6SaL0FnhKYbqk_q4Z9FVAX-pDxAKlC2am6HXmo93ASw [/img]
So how many of these XC race bikes get XC raced ?
Strangely that's not mine - I must've commented on it or something! Good shout though - it did also come up with a picture of mine further down:
Yep mine does. Does yours? I thought you did one XC race and commented how fast it was!?
XC race bike
[url= http://farm5.static.flickr.com/4132/4846711323_f85b2af833.jp g" target="_blank">http://farm5.static.flickr.com/4132/4846711323_f85b2af833.jp g"/> [/img][/url]
Racing
[url= http://farm5.static.flickr.com/4078/4894673936_a9bee4a182.jp g" target="_blank">http://farm5.static.flickr.com/4078/4894673936_a9bee4a182.jp g"/> [/img][/url]
Yeah, I think I was 51st/53 or something like that in the 4 lap veterans race. ๐ณ
Although, in my defence, I think would have been top half in the 3 lap open class. I never realised the old duffers were so fast. ๐
Anyway, I always think of "XC Racing" as including multi lap marathons like Mountain Mayhem and single loops like Brecon Beast, even if that's not the strict definition.
So "who races their bike" would've been more accurate, but I'm just being pedantic ๐
See you Saturday for a non-XC race!
Used to have this (raced it)
[url= http://farm1.static.flickr.com/211/506357532_c16f329d70.jp g" target="_blank">http://farm1.static.flickr.com/211/506357532_c16f329d70.jp g"/> [/img][/url]
now have this (will race it)
[url= http://farm7.static.flickr.com/6131/5966979568_dd142455fc.jp g" target="_blank">http://farm7.static.flickr.com/6131/5966979568_dd142455fc.jp g"/> [/img][/url]
That saddle has to go!
Pah.
I've raced a stock Genesis Altitude and come 5th.
Its not about the bike. Much.
after seeing all that carbon lovelyness at the weekend i am quite tempted to build one ๐
