Who actually wants ...
[Closed] Who actually wants to go 10 speed?
XTR will be 2 or 3 x10. There will be a "racers" double option available.
Posted : 19/04/2010 3:58 pm
But no racers double for SLX/XT?
I did breifly see an article last week that a google has not turned up today, but I dont remember seeing the XTR, nor 2x10 for the er, slightly more cost consious mentioned..
Posted : 19/04/2010 4:01 pm
Nah, it'll be 2x10.
Seeing as this:
Was leaked about 3 months ago and correctly predicts the 24/32/42 XT chainset I suspect it's pretty accurate with regards to the other bits.
It is just a load of synical bollocks on the bike industry merry go round of compatability issues and continual reinvention of all other sundry parts from the bloody wheel sideways to all else which will be essentialy the same, saving for the freaking expensive new tool you need to buy to fettle whatever the-not-realy-new-but-slightly-different bit.......is.
The customer does not need it. The industry does.
Ten speed chains are going to clog quicker and break easier than nine speed which clogged quicker than eight and seven, and the adjustments are going to be incrementaly finer which means they will upset easier etc etc. But eventually the industry will downcog their production of nine speed to a bare minimum of kit and you will probably be forced into it.
Progress!
Posted : 19/04/2010 4:26 pm
Once again, that's just not the case. CX bikes have been absolutely fine with 10 speed for a while now...
Posted : 19/04/2010 4:31 pm
Why have a 24T granny ring? What is wrong with 22?
WHY??????
FFFFFFFF WHY?
Why change back to a 42 Outer ring? What is wrong with 44?
It just ensures that none of your old kit is compatable.
What?
A) no one is forcing you to use it, if you don't want to, then don't!
B) why would a 22/32/44 chainset not be compatible (aside from the minute difference in chainring thickness)? There's no forced incompatibility.
C) as Clubber said they've been fine in cross, which arguably is harder on chains, there's not been an appreciable increase, and Campag have shown their 11 speed chain is actually stronger than their 10 speed chain.
Posted : 19/04/2010 4:34 pm
"The customer does not need it. The industry does"
but you could say that about suspension, index shifting, pneumatic tyres.. butted tubing..?
it's all development, it's just that now it's at the diminishing returns level as bikes get better and better each few years. 9-speed won't be discontined for ages yet so there's no need to upgrade if your 9 speed is running ok. but if it's worn out, i'd make the change.
all things equal apart from the thickness of links; the thinner the chain, the stronger the chain. thinner links mean less leverage from the centre bushes over the joining plates. we had all this 'weaker chain' when we went from 7 to 8, then 8 to 9.. it may wear a bit quicker due to less surface area, but then maybe not if the spread of gears is more useable.
"Why change back to a 42 Outer ring? What is wrong with 44?" read shimano's reasoning for Dynasis, it's about lower chain stress for a given torque through the crank, as well as better gear spreads. makes sense to me, but to be fair i've had all the shimano blurb for long enough to understand it. but honestly, it does make sense. and it doesn't render old kit useless as 9-speed XT + SLX continues for a while yet.
Posted : 19/04/2010 5:07 pm
 tron
I thought the 26 / 39 type ratios were fairly obvious - because you have a wider spread at the back, you have your double ratios move in a bit. You'll lose a bit of high end gearing but retain a decent spread.
Posted : 19/04/2010 5:17 pm
[url= http://www.theonion.com/articles/****-everything-were-doing-five-blades,11056/ ]Reminds me a little of this. substitute "Gilette" for "Shimano"; "blades" for "speed" and "5" for "10" and you're probably not far off![/url] Warning: contains the work "****".
Personally, I'm still on 8. With 7/8 speed thumbies, which I could shift onto friction to work with a 9 or 10 speed cassette. If I get a new rear wheel with a hope pro 2 hub and I can't find an 8 speed cassette with an alloy carrier, that's probably what I'll have to do.
Posted : 19/04/2010 5:20 pm
I have 10 speed on my mountain bikes and 11 speed on the road and cyclocrossers. I am a big chap and haven't snapped anything yet. It works well, and offers a great range of gears. What's not to like?
If you object to being left behind, or don't much fancy the cost of changing, that's one thing. But to dismiss it because it's new and different seems to be becoming almost trendy on STW.
I mentioned on an earlier post around this subject that 5 speed was once considered 'new fangled'. Where do you draw the line? Who gives anybody the authority to suggest that 7 was enough, 8 was enough, or now that 9 was enough. 10 is here and it aint going away.
People need to be aware that it's not called the bike industry/bike business for nothing. Behind the enjoyment that we all get from riding, there are big corporations who are driven by profit. That fact that to us it's a leisure interest doesn't disguise the fact that we are all consumers, and the nature of big business is to try and sell us stuff. If you don't want to buy, that's fine. Vote with your wallet. But if you do, so what?
SRAM, Shimano, Hope, Pace, even the smaller boutique brands that we all love. They may be run by enthusiasts, but they only stay afloat because they sell stuff, and new product is the lifeblood of the industry. We are all being marketed to, and there are many ways of seeing that.
Buy it or don't buy it, that's your choice. I respect that choice. But others might feel differently and want to give it a go.
Be thankful for the early adopters. Without them, there would be nobody left to sell you a slow but steady stream of 8 and 9 speed kit, because that trickle of revenue wouldn't keep a bike shop afloat.
The LBS where we all like to go and socialise, meet up for rides and discuss our hobby isn't some sort of adult youth club. It's a business which has bills to pay and staff to employ. They don't do that on thin air and the pleasant chat of retro-focussed STW posters.
As Njee said, nobody is forcing you to buy it, but if you want to, why not? I wouldn't sell everything I am running now and swap if it wasn't worn out, but as stuff wears out, why not?
Posted : 19/04/2010 5:35 pm
+1 to everything solarider said.
Posted : 19/04/2010 6:09 pm
I'm up fer it.
2X10 either on the mountainbike, or road component compatibility on the crossbike sounds good to me.
Posted : 19/04/2010 6:15 pm
When I feel loaded I'll get a Middleburn Uno, some Chubb hubs, light frame and ask Jedi to teach me to ride properly. Until then 9x1/2/3 and a few pints to heal the mental bruises.
Posted : 19/04/2010 6:24 pm
slx and saint already have a double ring with bashguard option for 9 speed...
Posted : 19/04/2010 6:43 pm
Yep, and you can either lose quite a few of the gears you'd have with a triple, or have massive jumps in the cassette. 10 speed reduces that, gives you a wider range of gears on a double with smaller gaps.
Posted : 19/04/2010 7:02 pm
 devs
I'm not having it because 9 speed isn't up to the job. Until I have no choice because of enforced obsolescence of course.
Posted : 19/04/2010 7:13 pm
They're going 10 speed!
Dang! I'm only recently 'upgraded' to 8 speed!...
Posted : 19/04/2010 7:18 pm
 LAT
Apologies if this has been said above, but what I don't understand is that, with the Shimano gear, you get the same low gear (24x36) and a lower high gear.
I appreciate the arguments for closer spaced gears and smaller rings, but how much closer is an 11-36 ten speed compared to an 11-34 9 speed? As for the 42 tooth outer, I usually replace my 44 with 42s when they wear out.
With 36 tooth lows being available on 9 speed cassettes, could I not get most the benefits of a 3x10 using 24 32 42 rings and a 12-36 9 speed cassette?
Another question and slightly O.T., could an aluminium free hub take the torque generated by a 36x22 gear? I know that this isn't being offered with the Shimano's 10 speed, I'm just wondering.
Posted : 19/04/2010 8:00 pm
njee20
A 44/32/22 system needs a different front mech (deeper section at the rear of the cage to cater for the 12 tooth drop as against a 10 tooth drop) to a 42/32/24 system. You might just about get the one to work on the other system but you will never get a sweet shift out of it. They are just shiting the customer about to sell you more kit.
Posted : 19/04/2010 9:59 pm
We should all be flattered, Shimano obviously sincerely think we all need the kit the pros use.
Wouldn't want to disappoint them by wheezing up the next hill with only 27 gears now would you?
Posted : 19/04/2010 10:01 pm
I'm going either 1 x 10 or 2 x 10 on my new bike, though only because I'm buying a new bike. Sure it will be just as good as 9 speed which i didnt have a problem with before
Posted : 19/04/2010 10:16 pm
This will help to keep bike shops in business 🙂
Cogs are getting down to tin can thicknesses. Shimano must be rubbing their hands at the thought of all those skinny cogs grinding through mud.
Posted : 19/04/2010 10:26 pm
Are you American? Nothing on a bike should be described as 'sweet'!
It'll be fine, mechs are not that intolerant, they're not gonna totally redesign the mechs to be reverse incompatible, calm down!
Posted : 19/04/2010 11:25 pm
10 speed only if its 2x5 like the road bike I had when I was a kid?
7 speed was fine for me but you can't buy it anymore so I had to downgrade to 8 speed. I've seen how weak 9 speed is. So when 8 speed becomes unavailable I'll be getting a hub gear.
Posted : 20/04/2010 8:11 pm
In what way is it not up to the job? Geniunely interested!
It's been the 'standard' for 11 years, in that time I'd be pretty confident that the vast majority, if not all, of the world cup and world championship races in DH, XC, 24 hour racing etc etc, have been won on 9 (or 10 speed) transmissions!
Posted : 20/04/2010 8:24 pm
because it isn't.
picture the scene; i've been away biking for the weekend, i get home late on sunday. So late it's nearly monday. i throw my bag under the stairs, i drop the bike in the cellar, and go to bed.
18 hours later when i get home from work, i'll clean my bike if i'm feeling energetic. but in the few hours in the cellar, the chain and gear cable and whatever have gone a little bit rusty, and now my lovely indexing has a little bit of friction, and doesn't really work anymore.
fewer gears in the same space would mean a little bit of normal 'out of tune-ness' would be less of a problem.
9-speed is a pain, and stops working nicely after a little bit of neglect, 10-speed will be worse.
world cup racers have mechanics to prepare their bikes before every race, i don't. i would be genuinely excited to see a system developed to help normal lazy bikers like me.
Posted : 20/04/2010 8:25 pm
because it isn't.
STW at its finest there! I find if you lube your bike properly then it won't go rusty in the first place...
Posted : 20/04/2010 8:40 pm
Had a look at the XX range at Merlin cycles, whilst speccing my new bike...Christ that rear cassette is HUGE
njee20 - Member
i'm cleaning and oiling (pedros stuff) my chain about 3 times a week, i have middleburn cable oilers, which i use about twice a week, i really don't know what else i should be doing.
help?
(it's appreciated, really. But patronising comments aren't so much)
Posted : 20/04/2010 8:45 pm
 juan
Well I don't see the point, a 2x9 what plenty enough. If you can't get to the top on the 22x34 you might as well push as lower gear will give you too much torque and you'll probably just do backflips.
If I can still get the choice of buying 9 speed or 10 speed I wouldn't object to it, but I very much doubt, so in a year or two I will be bound to buy 10 gear. And to be fair I don't want 10 gears I want 9. 9 is find by me, actually as I don't race I don't even need a 22/32/36 front gearing, a double 22/32 is just enough so why would I want to go 10 gears? I don't. What I want though is being able to buy decent (like Lx or XT) 9 gears chain and cassettes for the next 5-6 years.
FFS I still use square taper and 5 bold chain rings...
Posted : 20/04/2010 8:54 pm
It's already been done. Single speed or hub gear.
Posted : 20/04/2010 8:55 pm
 juan
Humm, you do know indeed that 7 gear on the rear is fairly common with DH bike... And lets not talk about trial that probably still run 1x5. And what about SSS who rode the yack on a singlespeed.
Posted : 20/04/2010 8:58 pm
Well if you're finding it's going rusty between rides, and you're not gonna get a chance to clean it in between, I'd just dribble some thick chain lube (I really rate like White Lightning Wet Ride) on the chain when you get home. I've personally never had any real problems with skipping transmissions other than in truly horrific conditions!
Posted : 20/04/2010 9:08 pm
I like the idea of 11-36t cassettes. I think I might manage with one chainring in the front using that...
Posted : 20/04/2010 9:37 pm
I really could got give a flying ****.
Posted : 20/04/2010 9:54 pm
Page 2 / 2
